This handler encapsulates functionality which is related to managing threads in a multiprocessor system configuration. More...
Files | |
file | threadmp.c |
Distributed MP Support. | |
#define | _Thread_MP_Is_receive(_the_thread) ((_the_thread) == _MPCI_Receive_server_tcb) |
This function returns true if the thread in question is the multiprocessing receive thread. More... | |
void | _Thread_MP_Handler_initialization (uint32_t maximum_proxies) |
Initialize MP thread handler. More... | |
Thread_Control * | _Thread_MP_Allocate_proxy (States_Control the_state) |
Allocate a MP proxy control block from the inactive chain of free proxy control blocks. More... | |
Thread_Control * | _Thread_MP_Find_proxy (Objects_Id the_id) |
Removes the MP proxy control block for the specified id from the active chain of proxy control blocks. More... | |
RTEMS_INLINE_ROUTINE void | _Thread_MP_Free_proxy (Thread_Control *the_thread) |
This routine frees a proxy control block to the inactive chain of free proxy control blocks. | |
SCORE_EXTERN Chain_Control | _Thread_MP_Active_proxies |
Manage the active set MP proxies. More... | |
SCORE_EXTERN Chain_Control | _Thread_MP_Inactive_proxies |
Manage the inactive set of MP proxies. More... | |
This handler must manage proxies which represent remote threads blocking on local operations.
#define _Thread_MP_Is_receive | ( | _the_thread | ) | ((_the_thread) == _MPCI_Receive_server_tcb) |
Thread_Control* _Thread_MP_Allocate_proxy | ( | States_Control | the_state | ) |
This allocates a proxy control block from the inactive chain of free proxy control blocks.
References _Chain_Get(), _Thread_Is_null(), and _Thread_MP_Inactive_proxies.
Thread_Control* _Thread_MP_Find_proxy | ( | Objects_Id | the_id | ) |
This function removes the proxy control block for the specified id from the active chain of proxy control blocks.
References _Addresses_Subtract_offset(), _Chain_First(), _Chain_Is_tail(), _ISR_Disable, and _Thread_MP_Active_proxies.
void _Thread_MP_Handler_initialization | ( | uint32_t | maximum_proxies | ) |
This routine initializes the multiprocessing portion of the Thread Handler.
References _Chain_Initialize(), _Chain_Initialize_empty(), _Thread_MP_Active_proxies, _Thread_MP_Inactive_proxies, and _Workspace_Allocate_or_fatal_error().
SCORE_EXTERN Chain_Control _Thread_MP_Active_proxies |
The following chain is used to manage the active set proxies.
Referenced by _Thread_MP_Find_proxy(), and _Thread_MP_Handler_initialization().
SCORE_EXTERN Chain_Control _Thread_MP_Inactive_proxies |
The following chain is used to manage the inactive set of proxies.
Referenced by _Thread_MP_Allocate_proxy(), and _Thread_MP_Handler_initialization().
