RTEMS POSIX API definitions and modules. More...
Modules | |
| utsname Service | |
| POSIX Asynchronous I/O Support | |
| POSIX Asynchronous Input and Output. | |
| POSIX Barriers | |
| This encapsulates functionality which implements the RTEMS API Barrier Manager. | |
| POSIX Condition Variables | |
| POSIX Key | |
| Message Queues Private Support | |
| POSIX Mutex Support | |
| Private Support Information for POSIX Mutex. | |
| POSIX Priority Support | |
| Interface to the POSIX Priority Implementation. | |
| POSIX Signals Support | |
| Internal Information about POSIX Signals. | |
| POSIX Threads Support | |
| Private Support Information for POSIX Threads. | |
| POSIX Timers | |
| POSIX RWLock Manager | |
| Constants and Structures Associated with the POSIX RWLock Manager. | |
| POSIX Semaphore Private Support | |
| This defines the internal implementation support for POSIX semaphores. | |
| POSIX Spinlock Support | |
| Constants and Structures Associated with the POSIX Spinlock Manager. | |
| POSIX Thread API Extension | |
| POSIX Time Types | |
| POSIX Timer Private Support | |
| POSIX Semaphores Support | |
| Private Support Information for POSIX Semaphores. | |
Files | |
| file | _execve.c |
| execve() | |
| file | adjtime.c |
| Adjust the Time to Synchronize the System Clock. | |
| file | aio_error.c |
| Returns the error status for the Asynchronous I/O request. | |
| file | aio_fsync.c |
| Syncing of all Outstanding Asynchronous I/O Operations. | |
| file | aio_misc.c |
| Actual request being processed. | |
| file | aio_read.c |
| Asynchronously reads Data from a File. | |
| file | aio_return.c |
| Final return status for Asynchronous I/O request pointed to by aiobcp. | |
| file | aio_suspend.c |
| Suspends Process until Asynchronous I/O Operation completes. | |
| file | aio_write.c |
| Function queues I/O request described by buffer pointed by aiocb. | |
| file | alarm.c |
| System Generates Signal for process after realtime seconds elapsed. | |
| file | barrierattrdestroy.c |
| Function shall Destroy a Barrier Attribues Object. | |
| file | barrierattrgetpshared.c |
| Barrier Attributes Get Process Shared. | |
| file | barrierattrinit.c |
| Initialize the Barrier Attributes Object. | |
| file | barrierattrsetpshared.c |
| Set the Process-Shared Attribute of the Barrier Attributes Object. | |
| file | cancel.c |
| Canceling Execution of a Thread. | |
| file | canceleval.c |
| POSIX Function Evaluates Thread Cancellation and Enables Dispatch. | |
| file | cancelrun.c |
| Executes a thread's cancellation handlers. | |
| file | cleanuppop.c |
| Removes Routine from Top of Calling Thread's stack and Invoke it. | |
| file | cleanuppush.c |
| Establishing Cancellation Handlers. | |
| file | clockgetcpuclockid.c |
| Function Returns Clock ID of CPU-time Clock of process specified. | |
| file | clockgetenableattr.c |
| Clock get Enable Attribute Access. | |
| file | clockgetres.c |
| Function Returns the Resolution of any Clock. | |
| file | clockgettime.c |
| Retrieves the Specified Clock Time. | |
| file | clocksetenableattr.c |
| Clock set Enable Attribute Access. | |
| file | clocksettime.c |
| Set Time of Clock. | |
| file | condattrdestroy.c |
| Destroy Condition Attribute. | |
| file | condattrgetpshared.c |
| Get the Process-Shared Condition Variable Attributes. | |
| file | condattrinit.c |
| Initialization of Conditional Attributes. | |
| file | condattrsetpshared.c |
| Initialize Condition Variable Attributes. | |
| file | condbroadcast.c |
| Broadcast a Condition. | |
| file | conddefaultattributes.c |
| Condition variable Attributes structure. | |
| file | conddestroy.c |
| Destroy a Condition Variable. | |
| file | condinit.c |
| Initialize a Condition Variable. | |
| file | condsignal.c |
| Signal a Condition. | |
| file | condtimedwait.c |
| Waiting on a Condition. | |
| file | condwait.c |
| file | execl.c |
| Process will get Executed and then Terminated by execl. | |
| file | execle.c |
| Execute a File. | |
| file | execlp.c |
| execlp() | |
| file | execv.c |
| Inoperable implementation of execv for POSIX threads. | |
| file | execve.c |
| Execute a Program. | |
| file | fork.c |
| Inoperable implementation of fork() for POSIX threads. | |
| file | getitimer.c |
| Function Gets Value of an Interval Timer. | |
| file | keycreate.c |
| Thread-Specific Data Key Create. | |
| file | keydelete.c |
| Deletes Thread-specific Data Key Previously Returned by keycreate.c. | |
| file | keyfreememory.c |
| POSIX Function Keys Free Memory. | |
| file | keygetspecific.c |
| Thread-Specific Data Management. | |
| file | keysetspecific.c |
| Set Specific Key. | |
| file | kill.c |
| Send a Signal to a Process. | |
| file | kill_r.c |
| file | killinfo.c |
| file | lio_listio.c |
| Function Initiates a List of I/O Requests with Single Function Call. | |
| file | mprotect.c |
| Change Memory Protection12.2.3 Change Memory Protection, P1003.1b-1996, p. | |
| file | mqueueclose.c |
| Function closes the Message Queue. | |
| file | mqueuegetattr.c |
| Message Queue Attributes. | |
| file | mqueueopen.c |
| Creates a new POSIX Message Queue or Opens an Existing Queue. | |
| file | mqueuesend.c |
| Adds Message Pointed by msg_ptr to Message Queue Reffered by mqdes. | |
| file | mqueuesendsupp.c |
| POSIX Message Queue and Send Support. | |
| file | mqueuetimedreceive.c |
| Receive Message from Message Queue. | |
| file | mqueuetranslatereturncode.c |
| POSIX Error Translation in Message Queue. | |
| file | mutexattrdestroy.c |
| Destroy Mutex Attributes Object. | |
| file | mutexattrgetprioceiling.c |
| Mutex Initialization Scheduling Attributes. | |
| file | mutexattrgetprotocol.c |
| Get protocol Attribute of Mutex Attribute Obect. | |
| file | mutexattrgetpshared.c |
| Obtaining process-shared Attribute Value from the Attributes Object. | |
| file | mutexattrgettype.c |
| Function gets the Mutex Type Attribute. | |
| file | mutexattrinit.c |
| Mutex Initialization Attribute. | |
| file | mutexattrsetprioceiling.c |
| file | mutexattrsetprotocol.c |
| file | mutexattrsetpshared.c |
| Function sets Current pshared Attribute for Mutex Attributes Object. | |
| file | mutexattrsettype.c |
| Set a Mutex Type. | |
| file | mutexdestroy.c |
| Initializing and Destroying a Mutex. | |
| file | mutexget.c |
| Convert POSIX Mutex ID to local object pointer. | |
| file | mutexgetprioceiling.c |
| Returns the Current Priority Ceiling of the Mutex. | |
| file | mutexinit.c |
| Initialize a Mutex. | |
| file | mutexlock.c |
| Call to function enables locking of Mutex Object referenced by mutex. | |
| file | mutexlocksupp.c |
| Support Call to function Enables Locking of Mutex Object. | |
| file | mutexsetprioceiling.c |
| Changes the Priority Ceiling of a Mutex and Releases it. | |
| file | mutextimedlock.c |
| Mutex Timed Lock. | |
| file | mutextrylock.c |
| Try to Lock Mutex. | |
| file | mutexunlock.c |
| Locking and Unlocking a Mutex. | |
| file | nanosleep.c |
| Suspends Execution of calling thread until Time elapses. | |
| file | pause.c |
| Suspend Process Execution. | |
| file | pbarrierdestroy.c |
| Destroy a Barrier Object. | |
| file | pbarrierinit.c |
| Call to Function Enables Reinitializing of the Barrier. | |
| file | pbarriertranslatereturncode.c |
| Function Translates POSIX Barrier Status Code. | |
| file | pbarrierwait.c |
| Wait at a Barrier. | |
| file | prwlockdestroy.c |
| Destroy a RWLock. | |
| file | prwlockinit.c |
| Allocate resources to use the read-write lock and Initialize it. | |
| file | prwlockrdlock.c |
| Obtain a Read Lock on a RWLock Instance. | |
| file | prwlocktimedrdlock.c |
| Attempt to Obtain a Read Lock on a RWLock Instance. | |
| file | prwlocktimedwrlock.c |
| Function applies a Write lock to RWLock referenced by rwlock. | |
| file | prwlocktryrdlock.c |
| file | prwlocktrywrlock.c |
| Attempt to Obtain a Write Lock on a RWLock Instance. | |
| file | prwlockunlock.c |
| Function Releases a lock held on RWLock object referenced by rwlock. | |
| file | prwlockwrlock.c |
| Obtain a Write Lock on a RWlock Instance. | |
| file | psignalclearprocesssignals.c |
| POSIX_signals clear_process_signals. | |
| file | pspindestroy.c |
| Destroy a Spinlock. | |
| file | pspininit.c |
| POSIX Function Initializes a Spinlock Instance. | |
| file | pspinlock.c |
| Wait at a Spinlock. | |
| file | pspintrylock.c |
| file | pspinunlock.c |
| Function Unlocks a Spin Lock Object. | |
| file | psxnametoid.c |
| POSIX Name to ID. | |
| file | pthreadatfork.c |
| Register Fork Handlers. | |
| file | pthreadattrdestroy.c |
| Thread Creation Attributes. | |
| file | pthreadattrgetaffinitynp.c |
| Pthread Attribute Get Affinity. | |
| file | pthreadattrgetdetachstate.c |
| Function gets the detachstate Attribute in the attr Object. | |
| file | pthreadattrgetguardsize.c |
| file | pthreadattrgetinheritsched.c |
| Thread Creation Scheduling Attributes. | |
| file | pthreadattrgetschedparam.c |
| Returns Scheduling Parameter Attributes of Thread Attributes Object. | |
| file | pthreadattrgetschedpolicy.c |
| Get The Schedpolicy Attribute. | |
| file | pthreadattrgetscope.c |
| Function gets the Contentionscope Attribute in the attr object. | |
| file | pthreadattrgetstack.c |
| Function Gets the Thread Creation Stack Attributes in the attr. | |
| file | pthreadattrgetstackaddr.c |
| file | pthreadattrgetstacksize.c |
| file | pthreadattrinit.c |
| Thread Attributes Creation. | |
| file | pthreadattrsetaffinitynp.c |
| Pthread Attribute Set Affinity. | |
| file | pthreadattrsetdetachstate.c |
| file | pthreadattrsetguardsize.c |
| file | pthreadattrsetinheritsched.c |
| Function sets the inheritsched Attribute in the attr Argument. | |
| file | pthreadattrsetschedparam.c |
| Thread Creation Scheduling Parameters. | |
| file | pthreadattrsetschedpolicy.c |
| Sets Scheduling policy Attributes of Thread Attributes Object. | |
| file | pthreadattrsetscope.c |
| Function Sets the Contentionscope Attribute in the attr Object. | |
| file | pthreadattrsetstack.c |
| Function Sets Thread Creation Stack Attributes in the attr object. | |
| file | pthreadattrsetstackaddr.c |
| Sets the Thread Creation stackaddr Attribute in the attr Object. | |
| file | pthreadattrsetstacksize.c |
| Sets the Thread Creation Stacksize Attribute in the attr object. | |
| file | pthreadcreate.c |
| Function Starts a New Thread in The Calling Process. | |
| file | pthreaddetach.c |
| Detaching a Thread. | |
| file | pthreadequal.c |
| Compare Thread IDs. | |
| file | pthreadgetaffinitynp.c |
| Pthread Get Affinity. | |
| file | pthreadgetattrnp.c |
| Pthread Get Attribute. | |
| file | pthreadgetcpuclockid.c |
| Returns Clock ID for CPU time clock of the thread. | |
| file | pthreadgetschedparam.c |
| Gets Scheduling Policy and Parameters of Individual Threads. | |
| file | pthreadjoin.c |
| Suspends Execution of Calling Thread until Target Thread Terminates. | |
| file | pthreadkill.c |
| Sends a signal Asynchronously directed to a thread. | |
| file | pthreadonce.c |
| Call to function by Thread will call init_routine with no Arguments. | |
| file | pthreadself.c |
| Function returns the ID of the Calling Thread. | |
| file | pthreadsetaffinitynp.c |
| Pthread Set Affinity. | |
| file | pthreadsetschedparam.c |
| Function sets scheduling policy and parameters of the thread. | |
| file | pthreadsigmask.c |
| Examine and/or change the calling thread's signal mask. | |
| file | ptimer.c |
| Process Timer. | |
| file | rwlockattrdestroy.c |
| Function Destroys a read-write lock Attributes object. | |
| file | rwlockattrgetpshared.c |
| Get the Process-Shared Attribute of the RWLock. | |
| file | rwlockattrinit.c |
| Initialises a RWLock Attributes object attr with the default value. | |
| file | rwlockattrsetpshared.c |
| RWLock Attributes Set Process Shared. | |
| file | sched_getparam.c |
| Set Scheduling Parameters. | |
| file | sched_getprioritymax.c |
| Returns the Appropriate Maximum for Scheduling policy. | |
| file | sched_getprioritymin.c |
| Get the Minimum Priority Limit. | |
| file | sched_getscheduler.c |
| Function Returns Scheduling Policy of the process specified by pid. | |
| file | sched_rr_get_interval.c |
| Limits for Scheduling Parameter. | |
| file | sched_setparam.c |
| Sets Scheduling Parameters Associated with Scheduling Policies. | |
| file | sched_setscheduler.c |
| Set Scheduling Policy and Scheduling Parameters. | |
| file | sched_yield.c |
| Yield Processor. | |
| file | semaphore.c |
| POSIX Function Initializes Semaphore Manager. | |
| file | semaphorecreatesupp.c |
| Function does Actual creation and Initialization of POSIX Semaphore. | |
| file | semaphoretranslatereturncode.c |
| POSIX Semaphore Code Translation Error. | |
| file | seminit.c |
| Initializing of an Unnamed Semaphore. | |
| file | semopen.c |
| Function Creates New POSIX semaphore or Opens an existing Semaphore. | |
| file | setcancelstate.c |
| Setting Cancelability State. | |
| file | setcanceltype.c |
| Sets the Cancelability Type of Calling Thread to value given in type. | |
| file | setitimer.c |
| Set the Timer. | |
| file | sigaction.c |
| Allows calling process to examine action of a Specific Signal. | |
| file | sigaddset.c |
| Function Adds Signal from Set. | |
| file | sigdelset.c |
| Deleted Signal from Set. | |
| file | sigemptyset.c |
| Manipulate Signal Sets. | |
| file | sigfillset.c |
| file | sigismember.c |
| file | signal_2.c |
| POSIX Function Installs signal Handler. | |
| file | sigpending.c |
| Examine Pending Signals. | |
| file | sigprocmask.c |
| Examine and Change Blocked Signals. | |
| file | sigqueue.c |
| Queue a Signal to a Process. | |
| file | sigsuspend.c |
| Replacing signal mask with *sigmask and suspending calling process. | |
| file | sigtimedwait.c |
| Wait for Queued Signals. | |
| file | sigwait.c |
| Synchronously Accept a Signal. | |
| file | sysconf.c |
| Get Configurable System Variables. | |
| file | testcancel.c |
| Setting test on Cancelability State. | |
| file | timerdelete.c |
| Deletes a POSIX Interval Timer. | |
| file | timergettime.c |
| Function Fetches State of POSIX Per-Process Timers. | |
| file | timerinserthelper.c |
| Helper Routine for POSIX TIMERS. | |
| file | timersettime.c |
| Function Arms or Disarms the Timer Identified by timerid. | |
| file | ualarm.c |
| Schedule Alarm. | |
| file | vfork.c |
| Creates Child process Of The Calling process. | |
| file | wait.c |
| Wait for Process to Change State. | |
| file | waitpid.c |
Enumerations | |
| enum | POSIX_Fatal_domain { POSIX_FD_PTHREAD, POSIX_FD_PTHREAD_ONCE } |
| POSIX API Fatal domains. More... | |
| void | _POSIX_Fatal_error (POSIX_Fatal_domain domain, int eno) |
| POSIX API Fatal error. More... | |
| void | _POSIX_API_Initialize (void) |
| Initialize POSIX API. More... | |
| int | _POSIX_Name_to_id (Objects_Information *information, const char *name, Objects_Id *id, size_t *len) |
| Queries the object identifier id for a name. More... | |
| enum POSIX_Fatal_domain |
| void _POSIX_API_Initialize | ( | void | ) |
This method is responsible for initializing each of the POSIX API managers.
References _Objects_Information_table.
| void _POSIX_Fatal_error | ( | POSIX_Fatal_domain | domain, |
| int | eno | ||
A common method of rasing a POSIX API fatal error.
| [in] | domain | The POSIX error domain. |
| [in] | eno | The error number as defined in errno.h. |
References _Terminate(), and INTERNAL_ERROR_POSIX_API.
| int _POSIX_Name_to_id | ( | Objects_Information * | information, |
| const char * | name, | ||
| Objects_Id * | id, | ||
| size_t * | len | ||
| [in] | information | Object information. |
| [in] | name | Zero terminated name string to look up. |
| [out] | id | Pointer for identifier. The pointer must be valid. |
| [out] | len | Pointer for string length. The pointer must be valid. |
| 0 | Successful operation. |
| EINVAL | The name pointer is NULL or the name string has zero length. |
| ENAMETOOLONG | The name string length is greater than or equal to NAME_MAX. |
| ENOENT | Found no corresponding identifier. |
Referenced by _POSIX_Message_queue_Name_to_id(), and _POSIX_Semaphore_Name_to_id().
