Internal Information about POSIX Signals.
More...
| #define | _States_Is_interruptible_signal(_states) |
#define | SIGACTION_TERMINATE { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Abnormal_termination_handler} } |
#define | SIGACTION_IGNORE { 0, SIGNAL_ALL_MASK, {SIG_IGN} } |
#define | SIGACTION_STOP { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Stop_handler} } |
#define | SIGACTION_CONTINUE { 0, SIGNAL_ALL_MASK, {_POSIX_signals_Continue_handler} } |
#define | SIG_ARRAY_MAX (SIGRTMAX + 1) |
#define | _POSIX_signals_Acquire(lock_context) _Thread_queue_Acquire( &_POSIX_signals_Wait_queue, lock_context ) |
#define | _POSIX_signals_Release(lock_context) _Thread_queue_Release( &_POSIX_signals_Wait_queue, lock_context ) |
#define | _POSIX_signals_Stop_handler NULL |
#define | _POSIX_signals_Continue_handler NULL |
void | _POSIX_signals_Manager_Initialization (void) |
| | POSIX signals manager initialization.
void | _POSIX_signals_Action_handler (Thread_Control *executing, Thread_Action *action, Per_CPU_Control *cpu, ISR_Level level) |
bool | _POSIX_signals_Unblock_thread (Thread_Control *the_thread, int signo, siginfo_t *info) |
| | Unlock POSIX signals thread.
bool | _POSIX_signals_Check_signal (POSIX_API_Control *api, int signo, bool is_global) |
| | Check POSIX signal.
bool | _POSIX_signals_Clear_signals (POSIX_API_Control *api, int signo, siginfo_t *info, bool is_global, bool check_blocked, bool do_signals_acquire_release) |
| | Clear POSIX signals.
int | killinfo (pid_t pid, int sig, const union sigval *value) |
void | _POSIX_signals_Set_process_signals (sigset_t mask) |
| | Set POSIX process signals.
void | _POSIX_signals_Clear_process_signals (int signo) |
void | _POSIX_signals_Abnormal_termination_handler (int signo) |
sigset_t | _POSIX_signals_Pending |
const struct sigaction | _POSIX_signals_Default_vectors [SIG_ARRAY_MAX] |
struct sigaction | _POSIX_signals_Vectors [SIG_ARRAY_MAX] |
Thread_queue_Control | _POSIX_signals_Wait_queue |
Chain_Control | _POSIX_signals_Inactive_siginfo |
Chain_Control | _POSIX_signals_Siginfo [SIG_ARRAY_MAX] |
◆ _States_Is_interruptible_signal
| #define _States_Is_interruptible_signal |
_states | ) |
Value:( ((_states) & \
#define STATES_WAITING_FOR_SIGNAL
This macro corresponds to a task waiting for a signal.
Definition: statesimpl.h:70
#define STATES_INTERRUPTIBLE_BY_SIGNAL
This macro corresponds to a task which is in an interruptible blocking state.
Definition: statesimpl.h:93
