Files | Functions
POSIX Timers
Collaboration diagram for POSIX Timers:
file  timercreate.c
 Create a Per-Process Timer.
file  timergetoverrun.c
 Get Overrun Count for a POSIX Per-Process Timer.
void _POSIX_Timer_Manager_initialization (void)
 POSIX Timer Manager Initialization. More...
int timer_create (clockid_t clock_id, struct sigevent *evp, timer_t *timerid)
int timer_delete (timer_t timerid)
 Delete a Per-Process Timer.
int timer_settime (timer_t timerid, int flags, const struct itimerspec *value, struct itimerspec *ovalue)
 Set a Per-Process Timer.
int timer_gettime (timer_t timerid, struct itimerspec *value)
int timer_getoverrun (timer_t timerid)
 Get overrun count for a Per-Process Timer. More...
◆ _POSIX_Timer_Manager_initialization()
void _POSIX_Timer_Manager_initialization ( void  )
This routine performs the initialization necessary for this manager.
◆ timer_getoverrun()
int timer_getoverrun ( timer_t  timerid)
The expiration of a timer must increase by one a counter. After the signal handler associated to the timer finishes its execution, _POSIX_Timer_TSR will have to set this counter to 0.
References _POSIX_Timer_Get().
