Files | |
| file | execvp.c |
| execvp() - POSIX 1003.1b 3.1.2 | |
| file | key.c |
| POSIX Keys Manager Initialization. | |
| file | keyrundestructors.c |
| Thread-Specific Data Key Create. | |
| struct | POSIX_Keys_Key_value_pair |
| Represents POSIX key and value pair. More... | |
| struct | POSIX_Keys_Control |
| The data structure used to manage a POSIX key. More... | |
| #define | POSIX_KEYS_RBTREE_NODE_TO_KEY_VALUE_PAIR(node) RTEMS_CONTAINER_OF( node, POSIX_Keys_Key_value_pair, Key_value_lookup_node ) |
| void | _POSIX_Key_Manager_initialization (void) |
| POSIX key manager initialization. More... | |
| RBTree_Compare_result | _POSIX_Keys_Key_value_compare (const RBTree_Node *node1, const RBTree_Node *node2) |
| POSIX keys Red-Black tree node comparison. More... | |
| void | _POSIX_Keys_Run_destructors (Thread_Control *thread) |
| Create thread-specific data POSIX key. More... | |
| void | _POSIX_Keys_Free_memory (POSIX_Keys_Control *the_key) |
| Free a POSIX key table memory. More... | |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Free (POSIX_Keys_Control *the_key) |
| Free a POSIX keys control block. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Allocate (void) |
| Allocate a keys control block. More... | |
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control * | _POSIX_Keys_Get (pthread_key_t id, Objects_Locations *location) |
| Get a keys control block. More... | |
| POSIX_Keys_Key_value_pair * | _POSIX_Keys_Key_value_pair_allocate (void) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Key_value_pair_free (POSIX_Keys_Key_value_pair *key_value_pair) |
| RTEMS_INLINE_ROUTINE RBTree_Node * | _POSIX_Keys_Find (pthread_key_t key, Thread_Control *thread) |
| RTEMS_INLINE_ROUTINE void | _POSIX_Keys_Free_key_value_pair (POSIX_Keys_Key_value_pair *key_value_pair) |
| POSIX_EXTERN Objects_Information | _POSIX_Keys_Information |
| The information control block used to manage this class of objects. | |
| RBTree_Control | _POSIX_Keys_Key_value_lookup_tree |
| The rbtree control block used to manage all key values. | |
| POSIX_EXTERN Freechain_Control | _POSIX_Keys_Keypool |
| This freechain is used as a memory pool for POSIX_Keys_Key_value_pair. | |
| void _POSIX_Key_Manager_initialization | ( | void | ) |
This routine performs the initialization necessary for this manager.
References _Objects_Initialize_information(), and _POSIX_Keys_Information.
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control* _POSIX_Keys_Allocate | ( | void | ) |
This function allocates a keys control block from the inactive chain of free keys control blocks.
References _Objects_Allocate().
Referenced by pthread_key_create().
| RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free | ( | POSIX_Keys_Control * | the_key | ) |
Free a keys control block.
This routine frees a keys control block to the inactive chain of free keys control blocks.
| [in] | the_key | is a pointer to the POSIX key to free. |
References _Objects_Free(), and POSIX_Keys_Control::Object.
| void _POSIX_Keys_Free_memory | ( | POSIX_Keys_Control * | the_key | ) |
This memory frees the key table memory associated with the_key.
| [in] | the_key | is a pointer to the POSIX key to free the table memory of. |
find the smallest thread_id node in the rbtree.
delete all nodes belongs to the_key from the rbtree and chain.
| RTEMS_INLINE_ROUTINE POSIX_Keys_Control* _POSIX_Keys_Get | ( | pthread_key_t | id, |
| Objects_Locations * | location | ||
This function maps key IDs to key control blocks. If ID corresponds to a local keys, then it returns the_key control pointer which maps to ID and location is set to OBJECTS_LOCAL. if the keys ID is global and resides on a remote node, then location is set to OBJECTS_REMOTE, and the_key is undefined. Otherwise, location is set to OBJECTS_ERROR and the_key is undefined.
References _Objects_Get().
| RBTree_Compare_result _POSIX_Keys_Key_value_compare | ( | const RBTree_Node * | node1, |
| const RBTree_Node * | node2 | ||
This routine compares the rbtree node
if either of the input nodes's thread_id member is 0, then it will only compare the pthread_key_t member. That is when we pass thread_id = 0 node as a search node, the search is done only by pthread_key_t.
| [in] | node1 | The node to be compared |
| [in] | node2 | The node to be compared |
| positive | if first node has higher key than second |
| negative | if lower |
| 0 | if equal,and for all the thread id is unique, then return 0 is impossible |
| void _POSIX_Keys_Run_destructors | ( | Thread_Control * | thread | ) |
This function executes all the destructors associated with the thread's keys. This function will execute until all values have been set to NULL.
| [in] | thread | is a pointer to the thread whose keys should have all their destructors run. |
NOTE: This is the routine executed when a thread exits to run through all the keys and do the destructor action.
remove key from rbtree and chain. here Chain_Node *iter can be convert to POSIX_Keys_Key_value_pair *, because Chain_Node is the first member of POSIX_Keys_Key_value_pair structure.
run key value's destructor if destructor and value are both non-null.
