Typedefs | Functions
Score Timestamp
This handler encapsulates functionality related to manipulating SuperCore Timestamps. More...
Collaboration diagram for Score Timestamp:
typedef struct bintime Timestamp_Control
 Define the Timestamp control type.
RTEMS_INLINE_ROUTINE void _Timestamp_Set (Timestamp_Control *_time, time_t _seconds, long _nanoseconds)
 Set timestamp to specified seconds and nanoseconds. More...
RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero (Timestamp_Control *_time)
 Sets the timestamp to zero. More...
RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs)
 Less than operator for timestamps. More...
RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs)
 Greater than operator for timestamps. More...
RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs)
 Equal to than operator for timestamps. More...
RTEMS_INLINE_ROUTINE time_t _Timestamp_Add_to (Timestamp_Control *_time, const Timestamp_Control *_add)
 Adds two timestamps. More...
RTEMS_INLINE_ROUTINE void _Timestamp_Subtract (const Timestamp_Control *_start, const Timestamp_Control *_end, Timestamp_Control *_result)
 Subtracts two timestamps. More...
RTEMS_INLINE_ROUTINE void _Timestamp_Divide (const Timestamp_Control *_lhs, const Timestamp_Control *_rhs, uint32_t *_ival_percentage, uint32_t *_fval_percentage)
 Divides a timestamp by another timestamp. More...
RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds (const Timestamp_Control *_time)
 Get seconds portion of timestamp. More...
RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds (const Timestamp_Control *_time)
 Get nanoseconds portion of timestamp. More...
RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_as_nanoseconds (const Timestamp_Control *_time)
 Get the timestamp as nanoseconds. More...
RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec (const Timestamp_Control *_timestamp, struct timespec *_timespec)
 Convert timestamp to struct timespec. More...
RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval (const Timestamp_Control *_timestamp, struct timeval *_timeval)
 Convert timestamp to struct timeval. More...
SuperCore Timestamps may be used to represent time of day, uptime, or intervals.
The key attribute of the SuperCore Timestamp handler is that it is a completely opaque handler. There can be multiple implementations of the required functionality and with a recompile, RTEMS can use any implementation. It is intended to be a simple wrapper.
This handler can be implemented as either struct timespec or unsigned64 bit numbers. The use of a wrapper class allows the the implementation of timestamps to change on a per architecture basis. This is an important option as the performance of this handler is critical.
◆ _Timestamp_Add_to()
RTEMS_INLINE_ROUTINE time_t _Timestamp_Add_to ( Timestamp_Control _time,
const Timestamp_Control _add
This routine adds two timestamps. The second argument is added to the first.
Parameters
[in]_timepoints to the base time to be added to
[in]_addpoints to the timestamp to add to the first argument
Return values
Thismethod returns the number of seconds time increased by.
◆ _Timestamp_Divide()
RTEMS_INLINE_ROUTINE void _Timestamp_Divide ( const Timestamp_Control _lhs,
const Timestamp_Control _rhs,
uint32_t *  _ival_percentage,
uint32_t *  _fval_percentage
This routine divides a timestamp by another timestamp. The intended use is for calculating percentages to three decimal points.
Parameters
[in]_lhspoints to the left hand number
[in]_rhspoints to the right hand number
[in]_ival_percentagepoints to the integer portion of the average
[in]_fval_percentagepoints to the thousandths of percentage
Return values
Thismethod fills in result.
References _Timespec_Divide().
◆ _Timestamp_Equal_to()
RTEMS_INLINE_ROUTINE bool _Timestamp_Equal_to ( const Timestamp_Control _lhs,
This method is the is equal to than operator for timestamps.
Parameters
[in]_lhspoints to the left hand side timestamp
[in]_rhspoints to the right hand side timestamp
Return values
Thismethod returns true if _lhs is equal to _rhs and false otherwise.
◆ _Timestamp_Get_as_nanoseconds()
RTEMS_INLINE_ROUTINE uint64_t _Timestamp_Get_as_nanoseconds ( const Timestamp_Control _time)
This method returns the timestamp as nanoseconds.
Parameters
[in]_timepoints to the timestamp
Return values
Thetime in nanoseconds.
References _Timespec_Get_as_nanoseconds().
◆ _Timestamp_Get_nanoseconds()
RTEMS_INLINE_ROUTINE uint32_t _Timestamp_Get_nanoseconds ( const Timestamp_Control _time)
This method returns the nanoseconds portion of the specified timestamp
Parameters
Return values
Thenanoseconds portion of _time.
◆ _Timestamp_Get_seconds()
RTEMS_INLINE_ROUTINE time_t _Timestamp_Get_seconds ( const Timestamp_Control _time)
This method returns the seconds portion of the specified timestamp
Parameters
Return values
Theseconds portion of _time.
◆ _Timestamp_Greater_than()
RTEMS_INLINE_ROUTINE bool _Timestamp_Greater_than ( const Timestamp_Control _lhs,
This method is the greater than operator for timestamps.
Parameters
Return values
Thismethod returns true if _lhs is greater than the _rhs and false otherwise.
◆ _Timestamp_Less_than()
RTEMS_INLINE_ROUTINE bool _Timestamp_Less_than ( const Timestamp_Control _lhs,
This method is the less than operator for timestamps.
Parameters
Return values
Thismethod returns true if _lhs is less than the _rhs and false otherwise.
◆ _Timestamp_Set()
RTEMS_INLINE_ROUTINE void _Timestamp_Set ( Timestamp_Control _time,
time_t  _seconds,
long  _nanoseconds
This method sets the timestamp to the specified _seconds and _nanoseconds value.
Parameters
[in]_timepoints to the timestamp instance to validate.
[in]_secondsis the seconds portion of the timestamp
[in]_nanosecondsis the nanoseconds portion of the timestamp
Referenced by adjtime().
◆ _Timestamp_Set_to_zero()
RTEMS_INLINE_ROUTINE void _Timestamp_Set_to_zero ( Timestamp_Control _time)
This method sets the timestamp to zero. value.
Parameters
[in]_timepoints to the timestamp instance to zero.
◆ _Timestamp_Subtract()
RTEMS_INLINE_ROUTINE void _Timestamp_Subtract ( const Timestamp_Control _start,
const Timestamp_Control _end,
Timestamp_Control _result
This routine subtracts two timestamps. result is set to end - start.
Parameters
[in]_startpoints to the starting time
[in]_endpoints to the ending time
[in]_resultpoints to the difference between starting and ending time.
Return values
Thismethod fills in _result.
◆ _Timestamp_To_timespec()
RTEMS_INLINE_ROUTINE void _Timestamp_To_timespec ( const Timestamp_Control _timestamp,
struct timespec *  _timespec
This method returns the seconds portion of the specified _timestamp.
Parameters
[in]_timestamppoints to the timestamp
[in]_timespecpoints to the timespec
Referenced by _TOD_Set_with_timestamp().
◆ _Timestamp_To_timeval()
RTEMS_INLINE_ROUTINE void _Timestamp_To_timeval ( const Timestamp_Control _timestamp,
struct timeval *  _timeval
Parameters
[in]_timevalpoints to the timeval
