Files | Data Structures | Macros | Functions | Variables
Time of Day Handler
The following constants are related to the time of day and are independent of RTEMS. More...
Collaboration diagram for Time of Day Handler:
file  tod.h
 Time of Day Handler API.
file  todimpl.h
file  coretod.c
 Initializes the Time of Day Handler.
file  coretodadjust.c
 Adjust the Time of Time.
file  coretodset.c
 Set Time of Day Given a Timestamp.
file  coretodtickle.c
 Increments time of day at each clock tick.
file  coretodtickspersec.c
 Convert Ticks To Seconds.
struct  TOD_Control
 TOD control. More...
#define TOD_SECONDS_PER_MINUTE   (uint32_t)60
 This constant represents the number of seconds in a minute.
#define TOD_MINUTES_PER_HOUR   (uint32_t)60
 This constant represents the number of minutes per hour.
#define TOD_MONTHS_PER_YEAR   (uint32_t)12
 This constant represents the number of months in a year.
#define TOD_DAYS_PER_YEAR   (uint32_t)365
 This constant represents the number of days in a non-leap year.
#define TOD_HOURS_PER_DAY   (uint32_t)24
 This constant represents the number of hours per day.
#define TOD_SECONDS_PER_DAY
 This constant represents the number of seconds in a day which does not include a leap second. More...
#define TOD_SECONDS_PER_NON_LEAP_YEAR   (365 * TOD_SECONDS_PER_DAY)
 This constant represents the number of seconds in a non-leap year.
#define TOD_MILLISECONDS_PER_SECOND   (uint32_t)1000
 This constant represents the number of millisecond in a second.
#define TOD_MICROSECONDS_PER_SECOND   (uint32_t)1000000
 This constant represents the number of microseconds in a second.
#define TOD_NANOSECONDS_PER_SECOND   (uint32_t)1000000000
 This constant represents the number of nanoseconds in a second.
#define TOD_NANOSECONDS_PER_MICROSECOND   (uint32_t)1000
 This constant represents the number of nanoseconds in a mircosecond.
#define TOD_TICKS_PER_SECOND   TOD_TICKS_PER_SECOND_method()
 Gets number of ticks in a second. More...
void _TOD_Handler_initialization (void)
 Initializes the time of day handler. More...
void _TOD_Set_with_timestamp (const Timestamp_Control *tod_as_timestamp)
 Sets the time of day from timestamp. More...
void _TOD_Tickle_ticks (void)
 Increments time of day at each clock tick. More...
uint32_t TOD_TICKS_PER_SECOND_method (void)
RTEMS_INLINE_ROUTINE void _TOD_Get_timeval (struct timeval *time)
 This routine returns a timeval based upon the internal timespec format TOD.
void _TOD_Adjust (const Timestamp_Control timestamp)
 Adjust the Time of Time. More...
RTEMS_INLINE_ROUTINE bool _TOD_Is_set (void)
 Check if the TOD is Set. More...
SCORE_EXTERN TOD_Control _TOD
This handler encapsulates functionality used to manage time of day.
◆ TOD_SECONDS_PER_DAY
Value:
(uint32_t) (TOD_SECONDS_PER_MINUTE * \
Definition: todimpl.h:50
Definition: todimpl.h:45
Definition: todimpl.h:65
◆ TOD_TICKS_PER_SECOND
This method exists to hide the fact that TOD_TICKS_PER_SECOND can not be implemented as a macro in a .h file due to visibility issues. The Configuration Table is not available to SuperCore .h files but is available to their .c files.
Referenced by _Timespec_To_ticks().
◆ _TOD_Adjust()
void _TOD_Adjust ( const Timestamp_Control  timestamp)
This method is used to adjust the current time of day by the specified amount.
Parameters
[in]deltais the amount to adjust
References _Thread_Disable_dispatch().
Referenced by _TOD_Get_timeval(), and adjtime().
◆ _TOD_Handler_initialization()
void _TOD_Handler_initialization ( void  )
Performs the initialization necessary for the Time Of Day handler.
◆ _TOD_Is_set()
RTEMS_INLINE_ROUTINE bool _TOD_Is_set ( void  )
◆ _TOD_Set_with_timestamp()
void _TOD_Set_with_timestamp ( const Timestamp_Control tod_as_timestamp)
The tod_as_timestamp timestamp represents the time since UNIX epoch. The watchdog seconds chain will be adjusted.
Parameters
[in]tod_as_timestampis the constant of the time of day as a timestamp
References _Thread_Disable_dispatch(), and _Timestamp_To_timespec().
◆ _TOD_Tickle_ticks()
void _TOD_Tickle_ticks ( void  )
This routine increments the ticks field of the current time of day at each clock tick.
References _Watchdog_Ticks_since_boot.
Referenced by _Watchdog_Tick().
◆ TOD_TICKS_PER_SECOND_method()
uint32_t TOD_TICKS_PER_SECOND_method ( void  )
This method returns the number of ticks in a second.
Note
If the clock tick value does not multiply evenly into a second then this number of ticks will be slightly shorter than a second.
References TOD_MICROSECONDS_PER_SECOND.
