The following records define the POSIX Configuration Table. More...
#include <config.h>
Data Fields | |
uint32_t | maximum_threads |
This field contains the maximum number of POSIX API threads which are configured for this application. | |
uint32_t | maximum_mutexes |
This field contains the maximum number of POSIX API mutexes which are configured for this application. | |
uint32_t | maximum_condition_variables |
This field contains the maximum number of POSIX API condition variables which are configured for this application. | |
uint32_t | maximum_timers |
This field contains the maximum number of POSIX API timers which are configured for this application. | |
uint32_t | maximum_queued_signals |
This field contains the maximum number of POSIX API queued signals which are configured for this application. | |
uint32_t | maximum_message_queues |
This field contains the maximum number of POSIX API message queues which are configured for this application. | |
uint32_t | maximum_message_queue_descriptors |
This field contains the maximum number of POSIX API message queue file descriptors which are configured for this application. More... | |
uint32_t | maximum_semaphores |
This field contains the maximum number of POSIX API semaphores which are configured for this application. | |
uint32_t | maximum_barriers |
This field contains the maximum number of POSIX API barriers which are configured for this application. | |
uint32_t | maximum_rwlocks |
This field contains the maximum number of POSIX API read/write locks which are configured for this application. | |
uint32_t | maximum_spinlocks |
This field contains the maximum number of POSIX API spinlocks which are configured for this application. | |
uint32_t | number_of_initialization_threads |
This field contains the number of POSIX API Initialization threads listed in User_initialization_thread_table. | |
posix_initialization_threads_table * | User_initialization_threads_table |
This field contains the list of POSIX API Initialization threads. | |
The information contained in this table is required in all RTEMS systems which include POSIX threads support, whether single or multiprocessor. This table primarily defines the following:
uint32_t posix_api_configuration_table::maximum_message_queue_descriptors |
