This structure is used to return information to the application about the objects configured for a specific API/Class combination. More...
#include <object.h>
Data Fields | |
rtems_id | minimum_id |
This field is the minimum valid object Id for this class. More... | |
rtems_id | maximum_id |
This field is the maximum valid object Id for this class. More... | |
uint32_t | maximum |
This field is the number of object instances configured for this class. More... | |
bool | auto_extend |
This field indicates if the class is configured for auto-extend. More... | |
uint32_t | unallocated |
This field is the number of currently unallocated objects. More... | |
bool rtems_object_api_class_information::auto_extend |
uint32_t rtems_object_api_class_information::maximum |
rtems_id rtems_object_api_class_information::maximum_id |
rtems_id rtems_object_api_class_information::minimum_id |
uint32_t rtems_object_api_class_information::unallocated |
