_rtems_rfs_file_system Struct Reference
RFS File System data. More...
#include <rtems-rfs-file-system.h>
Collaboration diagram for _rtems_rfs_file_system:
Collaboration graph
[legend]
uint32_t flags
 Flags to control the file system. More...
size_t blocks
 The number of blocks in the disk. More...
size_t block_size
 The size of a block. More...
int device
 The file descriptor for device I/O.
size_t size
 The number of blocks in the file system.
uint32_t inodes
 Inode count.
uint32_t bad_blocks
 Bad block blocks. More...
uint32_t max_name_length
 Maximum length of names supported by this file system.
rtems_rfs_groupgroups
 A disk is broken down into a series of groups.
int group_count
 Number of groups.
size_t group_blocks
 Number of blocks in a group.
size_t group_inodes
 Number of inodes in a group.
size_t inodes_per_block
 Number of inodes in each block.
size_t blocks_per_block
 Number of block numbers in a block.
size_t block_map_singly_blocks
 Block map single indirect count. More...
size_t block_map_doubly_blocks
 Block map double indirect count. More...
uint32_t max_held_buffers
 Number of buffers held before releasing back to the cache.
rtems_chain_control buffers
 List of buffers attached to buffer handles. More...
uint32_t buffers_count
 Number of buffers held on the buffers list.
rtems_chain_control release
 List of buffers that need to be released when the processing of a file system request has completed.
uint32_t release_count
 Number of buffers held on the release list.
rtems_chain_control release_modified
 List of buffers that need to be released modified when the processing of a file system request has completed.
uint32_t release_modified_count
 Number of buffers held on the release modified list.
rtems_chain_control file_shares
 List of open shared file node data. More...
void * user
 Pointer to user data supplied when opening.
Field Documentation
◆ bad_blocks
uint32_t _rtems_rfs_file_system::bad_blocks
Bad block blocks.
This is a table of blocks that have been found to be bad.
◆ block_map_doubly_blocks
size_t _rtems_rfs_file_system::block_map_doubly_blocks
This is the block number per block squared and multiplied by the slots in the inode. It is the maximum number of blocks a map (file/directory) can have.
◆ block_map_singly_blocks
size_t _rtems_rfs_file_system::block_map_singly_blocks
This is the block number per block multiplied but the slots in the inode.
◆ block_size
size_t _rtems_rfs_file_system::block_size
This must be a multiple of the disk's media block size.
◆ blocks
size_t _rtems_rfs_file_system::blocks
The size of the disk is the number of blocks by the block size. This should be within a block size of the size returned by the media driver.
◆ buffers
rtems_chain_control _rtems_rfs_file_system::buffers
Allows sharing.
◆ file_shares
rtems_chain_control _rtems_rfs_file_system::file_shares
The shared node data such as the inode and block map allows a single file to be open more than once.
◆ flags
uint32_t _rtems_rfs_file_system::flags
Some can be controlled via the ioctl.
