The global RTL data. More...
#include <rtl.h>
Data Fields | |
rtems_id | lock |
The RTL lock id. | |
rtems_rtl_alloc_data_t | allocator |
The allocator data. More... | |
rtems_chain_control | objects |
List if loaded object files. More... | |
const char * | paths |
Search paths for archives. More... | |
rtems_rtl_symbols_t | globals |
Global symbol table. More... | |
rtems_rtl_unresolved_t | unresolved |
Unresolved symbols. More... | |
rtems_rtl_obj_t * | base |
Base object file. More... | |
rtems_rtl_obj_cache_t | symbols |
Symbols object file cache. More... | |
rtems_rtl_obj_cache_t | strings |
Strings object file cache. More... | |
rtems_rtl_obj_cache_t | relocs |
Relocations object file cache. More... | |
rtems_rtl_obj_comp_t | decomp |
The decompression compressor. More... | |
int | last_errno |
Last error number. More... | |
char | last_error [64] |
Last error string. More... | |
This structure is allocated on the heap when the first call to the RTL is made and never released.
The global symbol table is a hash table held in this structure and the actual symbols are part of the object's structure. If this is a problem we could look at a hash table per object file.
rtems_rtl_alloc_data_t rtems_rtl_data_s::allocator |
The allocator data.
rtems_rtl_obj_t* rtems_rtl_data_s::base |
Base object file.
rtems_rtl_obj_comp_t rtems_rtl_data_s::decomp |
Referenced by rtems_rtl_obj_comp().
rtems_rtl_symbols_t rtems_rtl_data_s::globals |
Referenced by rtems_rtl_global_symbols().
int rtems_rtl_data_s::last_errno |
Last error number.
char rtems_rtl_data_s::last_error[64] |
Last error string.
rtems_chain_control rtems_rtl_data_s::objects |
Referenced by rtems_rtl_check_handle(), and rtems_rtl_find_obj().
const char* rtems_rtl_data_s::paths |
rtems_rtl_obj_cache_t rtems_rtl_data_s::relocs |
Referenced by rtems_rtl_obj_caches(), and rtems_rtl_obj_caches_flush().
rtems_rtl_obj_cache_t rtems_rtl_data_s::strings |
rtems_rtl_obj_cache_t rtems_rtl_data_s::symbols |
rtems_rtl_unresolved_t rtems_rtl_data_s::unresolved |
Unresolved symbols.
Referenced by rtems_rtl_unresolved().
