RTL Object. More...
#include <rtl-obj.h>
Data Fields | |
rtems_chain_node | link |
The node's link in the chain. More... | |
uint32_t | flags |
The status of the object file. More... | |
uint32_t | users |
References to the object file. More... | |
int | format |
The format of the object file. More... | |
const char * | fname |
The file name for the object. More... | |
const char * | oname |
The object file name. More... | |
const char * | aname |
The archive name containing the object. More... | |
off_t | ooffset |
The object offset in the archive. More... | |
size_t | fsize |
Size of the object file. More... | |
rtems_chain_control | sections |
The sections of interest in the object file. More... | |
rtems_rtl_obj_sym_t * | local_table |
Local symbol table. More... | |
size_t | local_syms |
Local symbol count. More... | |
size_t | local_size |
Local symbol memory usage. More... | |
rtems_rtl_obj_sym_t * | global_table |
Global symbol table. More... | |
size_t | global_syms |
Global symbol count. More... | |
size_t | global_size |
Global symbol memory usage. More... | |
uint32_t | unresolved |
The number of unresolved relocations. More... | |
void * | text_base |
The base address of the text section in memory. More... | |
size_t | text_size |
The size of the text section. More... | |
void * | const_base |
The base address of the const section in memory. More... | |
void * | eh_base |
The base address of the eh section in memory. More... | |
size_t | eh_size |
The size of the eh section. More... | |
void * | data_base |
The base address of the data section in memory. More... | |
void * | bss_base |
The base address of the bss section in memory. More... | |
size_t | bss_size |
The size of the bss section. More... | |
size_t | exec_size |
The amount of executable memory allocated. | |
void * | entry |
The entry point of the module. More... | |
uint32_t | checksum |
The checksum of the text sections. More... | |
uint32_t * | sec_num |
The sec nums of each obj. More... | |
uint32_t | obj_num |
The count of elf files in an rtl obj. More... | |
struct link_map * | linkmap |
For GDB. More... | |
void * | loader |
The file details specific to a loader. More... | |
RTL Object.
There is one for each object module loaded plus one for the base kernel image.
const char* rtems_rtl_obj_s::aname |
NULL means the object is not in a lib
void* rtems_rtl_obj_s::bss_base |
Referenced by rtems_rtl_obj_free(), and rtems_rtl_obj_load_sections().
size_t rtems_rtl_obj_s::bss_size |
Referenced by rtems_rtl_obj_load_sections().
uint32_t rtems_rtl_obj_s::checksum |
A zero means do not checksum.
void* rtems_rtl_obj_s::const_base |
void* rtems_rtl_obj_s::data_base |
void* rtems_rtl_obj_s::eh_base |
size_t rtems_rtl_obj_s::eh_size |
void* rtems_rtl_obj_s::entry |
uint32_t rtems_rtl_obj_s::flags |
Referenced by rtems_rtl_obj_free(), and rtems_rtl_obj_unresolved().
const char* rtems_rtl_obj_s::fname |
int rtems_rtl_obj_s::format |
Referenced by rtems_rtl_obj_alloc().
size_t rtems_rtl_obj_s::fsize |
size_t rtems_rtl_obj_s::global_size |
size_t rtems_rtl_obj_s::global_syms |
rtems_rtl_obj_sym_t* rtems_rtl_obj_s::global_table |
Referenced by rtems_rtl_symbol_obj_erase().
rtems_chain_node rtems_rtl_obj_s::link |
Referenced by rtems_rtl_obj_free().
struct link_map* rtems_rtl_obj_s::linkmap |
For GDB.
void* rtems_rtl_obj_s::loader |
Referenced by rtems_rtl_elf_unwind_deregister().
size_t rtems_rtl_obj_s::local_size |
Referenced by rtems_rtl_symbol_obj_erase_local().
size_t rtems_rtl_obj_s::local_syms |
Local symbol count.
rtems_rtl_obj_sym_t* rtems_rtl_obj_s::local_table |
Local symbol table.
uint32_t rtems_rtl_obj_s::obj_num |
const char* rtems_rtl_obj_s::oname |
off_t rtems_rtl_obj_s::ooffset |
Referenced by rtems_rtl_elf_file_check(), rtems_rtl_elf_file_load(), and rtems_rtl_rap_file_load().
uint32_t* rtems_rtl_obj_s::sec_num |
rtems_chain_control rtems_rtl_obj_s::sections |
Referenced by rtems_rtl_obj_alloc(), rtems_rtl_obj_erase_sections(), and rtems_rtl_obj_synchronize_cache().
void* rtems_rtl_obj_s::text_base |
size_t rtems_rtl_obj_s::text_size |
uint32_t rtems_rtl_obj_s::unresolved |
uint32_t rtems_rtl_obj_s::users |
