RTEMS Run-Time Linker Object Support. More...
#include <rtems.h>#include <rtems/chain.h>#include <rtems/rtl/rtl-sym.h>#include <rtems/rtl/rtl-unresolved.h>
| struct | rtems_rtl_loader_format_s |
| Loader format definition. More... | |
| struct | rtems_rtl_loader_table_s |
| Table for supported loadable formats. More... | |
| struct | rtems_rtl_obj_sect_s |
| An object file is made up of sections and the can be more than one of a specific type of sections. More... | |
| struct | rtems_rtl_obj_s |
| RTL Object. More... | |
| #define | RTEMS_RTL_FMT_ELF (1 << 0) |
| Loader format flags. | |
| #define | RTEMS_RTL_FMT_COMP (1 << 1) |
| #define | RTEMS_RTL_FMT_PRIVATE (1 << 16) |
| #define | RTEMS_RTL_OBJ_SECT_TEXT (1 << 0) |
| Flags for the various section types. More... | |
| #define | RTEMS_RTL_OBJ_SECT_CONST (1 << 1) |
| Section holds program text. More... | |
| #define | RTEMS_RTL_OBJ_SECT_DATA (1 << 2) |
| Section holds program data. More... | |
| #define | RTEMS_RTL_OBJ_SECT_BSS (1 << 3) |
| Section holds program bss. More... | |
| #define | RTEMS_RTL_OBJ_SECT_EH (1 << 4) |
| Section holds exception data. More... | |
| #define | RTEMS_RTL_OBJ_SECT_REL (1 << 5) |
| Section holds relocation records. More... | |
| #define | RTEMS_RTL_OBJ_SECT_RELA (1 << 6) |
| Section holds relocation addend records. More... | |
| #define | RTEMS_RTL_OBJ_SECT_SYM (1 << 7) |
| Section holds symbols. More... | |
| #define | RTEMS_RTL_OBJ_SECT_STR (1 << 8) |
| Section holds strings. More... | |
| #define | RTEMS_RTL_OBJ_SECT_ALLOC (1 << 9) |
| Section allocates runtime memory. More... | |
| #define | RTEMS_RTL_OBJ_SECT_LOAD (1 << 10) |
| Section is loaded from object file. More... | |
| #define | RTEMS_RTL_OBJ_SECT_WRITE (1 << 11) |
| Section is writable, ie data. More... | |
| #define | RTEMS_RTL_OBJ_SECT_EXEC (1 << 12) |
| Section is executable. More... | |
| #define | RTEMS_RTL_OBJ_SECT_ZERO (1 << 13) |
| Section is preset to zero. More... | |
| #define | RTEMS_RTL_OBJ_SECT_LINK (1 << 14) |
| Section is link-ordered. More... | |
| #define | RTEMS_RTL_OBJ_SECT_CTOR (1 << 15) |
| Section contains constructors. More... | |
| #define | RTEMS_RTL_OBJ_SECT_DTOR (1 << 16) |
| Section contains destructors. More... | |
| #define | RTEMS_RTL_OBJ_SECT_LOCD (1 << 17) |
| Section has been located. More... | |
| #define | RTEMS_RTL_OBJ_SECT_TYPES |
| Section types mask. More... | |
| #define | RTEMS_RTL_OBJ_LOCKED (1 << 0) |
| Object file descriptor flags. More... | |
| #define | RTEMS_RTL_OBJ_UNRESOLVED (1 << 1) |
| The object file has unresolved external symbols. More... | |
Typedefs | |
| typedef struct rtems_rtl_loader_format_s | rtems_rtl_loader_format_t |
| Loader format definition. | |
| typedef bool(* | rtems_rtl_loader_check) (rtems_rtl_obj_t *obj, int fd) |
| The type of the format loader check handler. More... | |
| typedef bool(* | rtems_rtl_loader_load) (rtems_rtl_obj_t *obj, int fd) |
| The type of the format loader load handler. More... | |
| typedef bool(* | rtems_rtl_loader_unload) (rtems_rtl_obj_t *obj) |
| The type of the format loader unload handler. More... | |
| typedef rtems_rtl_loader_format_t *(* | rtems_rtl_loader_sig) (void) |
| The type of the format loader signature handler. More... | |
| typedef struct rtems_rtl_loader_table_s | rtems_rtl_loader_table_t |
| Table for supported loadable formats. | |
| typedef bool(* | rtems_rtl_obj_sect_handler_t) (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_t *sect, void *data) |
| A section handler is called once for each section that needs to be processed by this handler. More... | |
| rtems_rtl_obj_t * | rtems_rtl_obj_alloc (void) |
| Allocate an object structure on the heap. More... | |
| bool | rtems_rtl_obj_free (rtems_rtl_obj_t *obj) |
| Free the object structure and related resources. More... | |
| bool | rtems_rtl_obj_unresolved (rtems_rtl_obj_t *obj) |
| Does the object file have unresolved external references ? If it does the results of executing code is unpredictable. More... | |
| bool | rtems_rtl_parse_name (const char *name, const char **aname, const char **oname, off_t *ooffset) |
| Parses a filename and returns newly allocated strings with the archive name, object name, and the object's offset. More... | |
| bool | rtems_rtl_match_name (rtems_rtl_obj_t *obj, const char *name) |
| Check of the name matches the object file's object name. More... | |
| bool | rtems_rtl_obj_find_file (rtems_rtl_obj_t *obj, const char *name) |
| Find an object file on disk that matches the name. More... | |
| bool | rtems_rtl_obj_add_section (rtems_rtl_obj_t *obj, int section, const char *name, size_t size, off_t offset, uint32_t alignment, int link, int info, uint32_t flags) |
| Add a section to the object descriptor. More... | |
| void | rtems_rtl_obj_erase_sections (rtems_rtl_obj_t *obj) |
| Erase the object file descriptor's sections. More... | |
| rtems_rtl_obj_sect_t * | rtems_rtl_obj_find_section (const rtems_rtl_obj_t *obj, const char *name) |
| Find the section given a name. More... | |
| rtems_rtl_obj_sect_t * | rtems_rtl_obj_find_section_by_index (const rtems_rtl_obj_t *obj, int index) |
| Find a section given a section's index number. More... | |
| size_t | rtems_rtl_obj_text_size (const rtems_rtl_obj_t *obj) |
| The text section size. More... | |
| uint32_t | rtems_rtl_obj_text_alignment (const rtems_rtl_obj_t *obj) |
| The text section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_const_size (const rtems_rtl_obj_t *obj) |
| The const section size. More... | |
| uint32_t | rtems_rtl_obj_const_alignment (const rtems_rtl_obj_t *obj) |
| The const section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_eh_size (const rtems_rtl_obj_t *obj) |
| The eh section size. More... | |
| uint32_t | rtems_rtl_obj_eh_alignment (const rtems_rtl_obj_t *obj) |
| The eh section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_data_size (const rtems_rtl_obj_t *obj) |
| The data section size. More... | |
| uint32_t | rtems_rtl_obj_data_alignment (const rtems_rtl_obj_t *obj) |
| The data section alignment for the object file. More... | |
| size_t | rtems_rtl_obj_bss_size (const rtems_rtl_obj_t *obj) |
| The bss section size. More... | |
| uint32_t | rtems_rtl_obj_bss_alignment (const rtems_rtl_obj_t *obj) |
| The bss section alignment for the object file. More... | |
| bool | rtems_rtl_obj_relocate (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Relocate the object file. More... | |
| void | rtems_rtl_obj_synchronize_cache (rtems_rtl_obj_t *obj) |
| Synchronize caches to make code visible to CPU(s) More... | |
| bool | rtems_rtl_obj_relocate_unresolved (rtems_rtl_unresolv_reloc_t *reloc, rtems_rtl_obj_sym_t *sym) |
| Relocate an object file's unresolved reference. More... | |
| bool | rtems_rtl_obj_load_symbols (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Load the symbols from the object file. More... | |
| bool | rtems_rtl_obj_load_sections (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_handler_t handler, void *data) |
| Load the sections that have been allocated memory in the target. More... | |
| void | rtems_rtl_obj_run_ctors (rtems_rtl_obj_t *obj) |
| Invoke the constructors the object has. More... | |
| void | rtems_rtl_obj_run_dtors (rtems_rtl_obj_t *obj) |
| Invoke the destructors the object has. More... | |
| bool | rtems_rtl_obj_load (rtems_rtl_obj_t *obj) |
| Load the object file, reading all sections into memory, symbols and performing any relocation fixups. More... | |
| bool | rtems_rtl_obj_unload (rtems_rtl_obj_t *obj) |
| Unload the object file, erasing all symbols and releasing all memory. More... | |
| #define RTEMS_RTL_OBJ_LOCKED (1 << 0) |
Lock the object file so it cannot be unloaded.
Referenced by rtems_rtl_obj_free().
| #define RTEMS_RTL_OBJ_SECT_ALLOC (1 << 9) |
| #define RTEMS_RTL_OBJ_SECT_BSS (1 << 3) |
Referenced by rtems_rtl_obj_synchronize_cache().
| #define RTEMS_RTL_OBJ_SECT_CONST (1 << 1) |
Referenced by rtems_rtl_elf_unwind_dw2_parse(), and rtems_rtl_obj_synchronize_cache().
| #define RTEMS_RTL_OBJ_SECT_CTOR (1 << 15) |
| #define RTEMS_RTL_OBJ_SECT_DATA (1 << 2) |
| #define RTEMS_RTL_OBJ_SECT_DTOR (1 << 16) |
| #define RTEMS_RTL_OBJ_SECT_EH (1 << 4) |
| #define RTEMS_RTL_OBJ_SECT_EXEC (1 << 12) |
| #define RTEMS_RTL_OBJ_SECT_LINK (1 << 14) |
| #define RTEMS_RTL_OBJ_SECT_LOAD (1 << 10) |
| #define RTEMS_RTL_OBJ_SECT_LOCD (1 << 17) |
| #define RTEMS_RTL_OBJ_SECT_REL (1 << 5) |
| #define RTEMS_RTL_OBJ_SECT_RELA (1 << 6) |
| #define RTEMS_RTL_OBJ_SECT_STR (1 << 8) |
| #define RTEMS_RTL_OBJ_SECT_SYM (1 << 7) |
| #define RTEMS_RTL_OBJ_SECT_TEXT (1 << 0) |
| #define RTEMS_RTL_OBJ_SECT_TYPES |
Section types mask.
| #define RTEMS_RTL_OBJ_SECT_WRITE (1 << 11) |
| #define RTEMS_RTL_OBJ_SECT_ZERO (1 << 13) |
| #define RTEMS_RTL_OBJ_UNRESOLVED (1 << 1) |
Referenced by rtems_rtl_obj_unresolved().
| typedef bool(* rtems_rtl_loader_check) (rtems_rtl_obj_t *obj, int fd) |
This handler checks the format and if it is detected as suitable it returns true.
| typedef bool(* rtems_rtl_loader_load) (rtems_rtl_obj_t *obj, int fd) |
This handler loads the specific format.
| typedef rtems_rtl_loader_format_t*(* rtems_rtl_loader_sig) (void) |
This handler checks the format signature.
| typedef bool(* rtems_rtl_loader_unload) (rtems_rtl_obj_t *obj) |
This handler unloads the specific format.
| typedef bool(* rtems_rtl_obj_sect_handler_t) (rtems_rtl_obj_t *obj, int fd, rtems_rtl_obj_sect_t *sect, void *data) |
| obj | The object file's descriptor the section belongs too. |
| fd | The file descriptor of the object file beling loaded. |
| sect | The section the handler is being invoked to handle. |
| data | A user supplied data variable. |
| true | The operation was successful. |
| false | The operation failed and the RTL has been set. |
| bool rtems_rtl_match_name | ( | rtems_rtl_obj_t * | obj, |
| const char * | name | ||
| obj | The object file's descriptor. |
| name | The name to match. |
References rtems_rtl_obj_s::oname.
| bool rtems_rtl_obj_add_section | ( | rtems_rtl_obj_t * | obj, |
| int | section, | ||
| const char * | name, | ||
| size_t | size, | ||
| off_t | offset, | ||
| uint32_t | alignment, | ||
| int | link, | ||
| int | info, | ||
| uint32_t | flags | ||
| section | The section's index number. |
| name | The name of the section. |
| size | The size of the section in memory. |
| offset | The offset of the section in the object file. |
| alignment | The alignment of the section in memory. |
| link | The section's link field (from the ELF format). |
| info | The section's info field (from the ELF format). |
| flags | The section's flags. |
| true | The section has been added. |
| false | The section has not been added. See the RTL error. |
| rtems_rtl_obj_t* rtems_rtl_obj_alloc | ( | void | ) |
| NULL | No memory for the object. |
References rtems_rtl_obj_s::format, rtems_chain_initialize_empty(), rtems_rtl_alloc_new(), RTEMS_RTL_ALLOC_OBJECT, and rtems_rtl_obj_s::sections.
| uint32_t rtems_rtl_obj_bss_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first bss type section loaded the bss section.
You can assume the alignment is a positive integral power of 2 if not 0 or
Referenced by rtems_rtl_obj_load_sections().
| size_t rtems_rtl_obj_bss_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's bss area.
| uint32_t rtems_rtl_obj_const_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first const type section loaded the const section.
| size_t rtems_rtl_obj_const_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's const area. The consts sections are included in this section.
| uint32_t rtems_rtl_obj_data_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first data type section loaded the data section.
| size_t rtems_rtl_obj_data_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's data area.
| uint32_t rtems_rtl_obj_eh_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
| size_t rtems_rtl_obj_eh_size | ( | const rtems_rtl_obj_t * | obj | ) |
| void rtems_rtl_obj_erase_sections | ( | rtems_rtl_obj_t * | obj | ) |
References rtems_rtl_obj_sect_s::name, rtems_chain_extract(), rtems_chain_first(), rtems_chain_is_tail(), rtems_chain_next(), rtems_rtl_alloc_del(), RTEMS_RTL_ALLOC_OBJECT, and rtems_rtl_obj_s::sections.
| bool rtems_rtl_obj_find_file | ( | rtems_rtl_obj_t * | obj, |
The object descriptor is fill in with the various parts of a name. A name can have archive, object file and offset components. The search path in the RTL is searched.
| name | The name to locate on disk. |
| true | The file has been found. |
| false | The file could not be located. The RTL error has been set. |
| rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section | ( | const rtems_rtl_obj_t * | obj, |
| name | The name of the section to find. |
| NULL | The section was not found. |
References rtems_rtl_obj_sect_finder_t::name, and rtems_rtl_obj_sect_finder_t::sect.
Referenced by rtems_rtl_elf_unwind_dw2_deregister(), and rtems_rtl_elf_unwind_dw2_register().
| rtems_rtl_obj_sect_t* rtems_rtl_obj_find_section_by_index | ( | const rtems_rtl_obj_t * | obj, |
| int | index | ||
| index | The section's index to find. |
Referenced by rtems_rtl_obj_relocate_unresolved().
| bool rtems_rtl_obj_free | ( | rtems_rtl_obj_t * | obj | ) |
| obj | The object file's descriptor to free. |
| false | The object has dependences. |
| true | The object has been freed. |
References rtems_rtl_obj_s::bss_base, rtems_rtl_obj_s::const_base, rtems_rtl_obj_s::data_base, rtems_rtl_obj_s::eh_base, rtems_rtl_obj_s::flags, rtems_rtl_obj_s::link, rtems_chain_extract(), rtems_chain_is_node_off_chain(), rtems_rtl_alloc_module_del(), RTEMS_RTL_OBJ_LOCKED, rtems_rtl_set_error(), rtems_rtl_symbol_obj_erase(), rtems_rtl_obj_s::text_base, and rtems_rtl_obj_s::users.
| bool rtems_rtl_obj_load | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has been loaded. |
| false | The load failed. The RTL error has been set. |
| bool rtems_rtl_obj_load_sections | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| rtems_rtl_obj_sect_handler_t | handler, | ||
| void * | data | ||
The bss type section does not load any data, it is set to 0. The text and data sections read the detault data from the object file into the target memory.
| fd | The object file's file descriptor. |
| handler | The object file's format specific load handler. |
| data | User specific data handle. |
| true | The object has been sucessfully loaded. |
References rtems_rtl_obj_s::bss_base, rtems_rtl_obj_s::bss_size, rtems_rtl_obj_s::const_base, rtems_rtl_obj_s::data_base, rtems_rtl_obj_s::eh_base, rtems_rtl_obj_s::eh_size, rtems_rtl_obj_s::exec_size, rtems_rtl_alloc_module_new(), rtems_rtl_obj_bss_alignment(), rtems_rtl_obj_bss_size(), rtems_rtl_obj_const_alignment(), rtems_rtl_obj_const_size(), rtems_rtl_obj_data_alignment(), rtems_rtl_obj_data_size(), rtems_rtl_obj_eh_alignment(), rtems_rtl_obj_eh_size(), rtems_rtl_obj_text_size(), rtems_rtl_set_error(), rtems_rtl_trace(), rtems_rtl_obj_s::text_base, and rtems_rtl_obj_s::text_size.
| bool rtems_rtl_obj_load_symbols | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| void * | data | ||
Only the exported or public symbols are read into memory and held in the global symbol table.
| handler | The object file's format specific symbol handler. |
| true | The object file's symbol where loaded. |
| false | The symbol loading failed. The RTL error is set. |
| bool rtems_rtl_obj_relocate | ( | rtems_rtl_obj_t * | obj, |
| int | fd, | ||
| void * | data | ||
The object file's section are parsed for any relocation type sections.
| handler | The object file's format specific relocation handler. |
| true | The object file was relocated. |
| false | The relocation failed. The RTL error is set. |
| bool rtems_rtl_obj_relocate_unresolved | ( | rtems_rtl_unresolv_reloc_t * | reloc, |
| rtems_rtl_obj_sym_t * | sym | ||
| rec | The unresolved relocation record. |
| sym | The unresolved relocation's referenced symbol. |
| true | The object file record was relocated. |
References rtems_rtl_unresolv_reloc_s::flags, rtems_rtl_unresolv_reloc_s::obj, rtems_rtl_unresolv_reloc_s::rel, REL_R_OFFSET, rtems_rtl_obj_find_section_by_index(), rtems_rtl_set_error(), rtems_rtl_unresolv_reloc_s::sect, and rtems_rtl_obj_sym_s::value.
| void rtems_rtl_obj_run_ctors | ( | rtems_rtl_obj_t * | obj | ) |
Constructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain constructors.
Referenced by rtems_rtl_run_ctors().
| void rtems_rtl_obj_run_dtors | ( | rtems_rtl_obj_t * | obj | ) |
Destructors are a table of pointers to "void (*)(void);" where NULL pointers are skipped. The table's size is taken from the section's size. The objet ELF specific code is responisble for flagging which sections contain destructors.
| void rtems_rtl_obj_synchronize_cache | ( | rtems_rtl_obj_t * | obj | ) |
References rtems_cache_get_instruction_line_size(), rtems_cache_get_maximal_line_size(), rtems_rtl_chain_iterate(), RTEMS_RTL_OBJ_SECT_BSS, RTEMS_RTL_OBJ_SECT_CONST, RTEMS_RTL_OBJ_SECT_DATA, RTEMS_RTL_OBJ_SECT_EH, RTEMS_RTL_OBJ_SECT_EXEC, RTEMS_RTL_OBJ_SECT_TEXT, and rtems_rtl_obj_s::sections.
| uint32_t rtems_rtl_obj_text_alignment | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. The section alignment is the alignment of the first text type section loaded the text section.
| size_t rtems_rtl_obj_text_size | ( | const rtems_rtl_obj_t * | obj | ) |
Only use once all the sections has been added. It includes alignments between sections that are part of the object's text area. The consts sections are included in this section.
| bool rtems_rtl_obj_unload | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has been unloaded. |
| false | The unload failed. The RTL error has been set. |
| bool rtems_rtl_obj_unresolved | ( | rtems_rtl_obj_t * | obj | ) |
| true | The object file has unresolved externals. |
| false | The object file has all external references resolved. |
References rtems_rtl_obj_s::flags, and RTEMS_RTL_OBJ_UNRESOLVED.
| bool rtems_rtl_parse_name | ( | const char * | name, |
| const char ** | aname, | ||
| const char ** | oname, | ||
| off_t * | ooffset | ||
| name | The filename of the object |
| aname | Address of a string pointer that holds the archive name |
| oname | Address of a string pointer that holds the object name |
| ooffset | Address of an int that holds the object offset |
| true | The parsing was successful |
| false | The parsing was unsuccessful |
Referenced by rtems_rtl_find_obj().
