rtems_rtl_obj_sect_s Struct Reference
An object file is made up of sections and the can be more than one of a specific type of sections. More...
#include <rtl-obj.h>
Collaboration diagram for rtems_rtl_obj_sect_s:
Collaboration graph
[legend]
rtems_chain_node node
 The node's link in the chain. More...
int section
 The section number. More...
const char * name
 The section's name. More...
size_t size
 The size of the section in memory. More...
off_t offset
 Offset into the object file. More...
uint32_t alignment
 Alignment of this section. More...
int link
 Section link field. More...
int info
 Secfion info field. More...
uint32_t flags
 The section's flags. More...
void * base
 The base address of the section in memory. More...
int load_order
 Order we load sections. More...
All sections and grouped together in memory.
Field Documentation
◆ alignment
uint32_t rtems_rtl_obj_sect_s::alignment
◆ base
void* rtems_rtl_obj_sect_s::base
◆ flags
uint32_t rtems_rtl_obj_sect_s::flags
◆ info
int rtems_rtl_obj_sect_s::info
Secfion info field.
◆ link
int rtems_rtl_obj_sect_s::link
Section link field.
◆ load_order
int rtems_rtl_obj_sect_s::load_order
◆ name
const char* rtems_rtl_obj_sect_s::name
The section's name.
Referenced by rtems_rtl_obj_erase_sections().
◆ node
rtems_chain_node rtems_rtl_obj_sect_s::node
◆ offset
off_t rtems_rtl_obj_sect_s::offset
Relative to the start of the object file.
◆ section
int rtems_rtl_obj_sect_s::section
The section number.
◆ size
size_t rtems_rtl_obj_sect_s::size
Referenced by rtems_rtl_elf_unwind_dw2_deregister(), and rtems_rtl_elf_unwind_dw2_register().
