RTEMS Run-Time Linker Unwind DWARF Support. More...
#include "rtl-elf.h"
Typedefs | |
typedef long | rtems_rtl_elf_unwind_dw2_sleb128 |
typedef unsigned long | rtems_rtl_elf_unwind_dw2_uleb128 |
bool | rtems_rtl_elf_unwind_dw2_parse (const rtems_rtl_obj_t *obj, const char *name, uint32_t flags) |
Architecture specific handler to check if a section contains exception handler data. More... | |
bool | rtems_rtl_elf_unwind_dw2_register (const rtems_rtl_obj_t *obj) |
Architecture specific handler to add an object file's unwind information to the base image. More... | |
bool | rtems_rtl_elf_unwind_dw2_deregister (const rtems_rtl_obj_t *obj) |
Architecture specific handler to remove an object file's unwind information from the base image. More... | |
const uint8_t * | rtems_rtl_elf_unwind_dw2_read_uleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_uleb128 *val) |
Read signed and unsigned LEB128 values. | |
const uint8_t * | rtems_rtl_elf_unwind_dw2_read_sleb128 (const uint8_t *data, rtems_rtl_elf_unwind_dw2_sleb128 *val) |
bool | rtems_rtl_elf_unwind_dw2_relocate (const Elf_Addr *where, Elf_Word value, Elf_Word mask) |
bool rtems_rtl_elf_unwind_dw2_deregister | ( | const rtems_rtl_obj_t * | obj | ) |
obj | The object file. |
true | The unwind information has been deregistered. |
false | The unwind information could not be deregistered. |
References rtems_rtl_obj_sect_s::base, rtems_rtl_obj_find_section(), and rtems_rtl_obj_sect_s::size.
Referenced by rtems_rtl_elf_unwind_deregister().
bool rtems_rtl_elf_unwind_dw2_parse | ( | const rtems_rtl_obj_t * | obj, |
const char * | name, | ||
uint32_t | flags | ||
name | The section's name. |
uint32 | flags The object file's flags. |
true | The section contains unwind information. |
false | The section does not contain unwind information. |
References RTEMS_RTL_OBJ_SECT_CONST.
Referenced by rtems_rtl_elf_unwind_parse().
bool rtems_rtl_elf_unwind_dw2_register | ( | const rtems_rtl_obj_t * | obj | ) |
true | The unwind information has been registered. |
false | The unwind information could not be registered. |
Referenced by rtems_rtl_elf_unwind_register().
