rtl-trace.c File Reference
RTEMS Run-Time Link Editor Trace. More...
#include "rtl-trace.h"
Include dependency graph for rtl-trace.c:
bool rtems_rtl_trace (rtems_rtl_trace_mask mask)
 Call to check if this part is bring traced. More...
rtems_rtl_trace_mask rtems_rtl_trace_set_mask (rtems_rtl_trace_mask mask)
 Set the mask. More...
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask (rtems_rtl_trace_mask mask)
 Clear the mask. More...
int rtems_rtl_trace_shell_command (int argc, char *argv[])
 Add shell trace shell command.
A configurable tracer for the RTL. See the header file for the enable and disable.
◆ rtems_rtl_trace()
bool rtems_rtl_trace ( rtems_rtl_trace_mask  mask)
If RTEMS_RTL_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
Parameters
maskThe part of the API to trace.
Return values
trueTracing is active for the mask.
falseDo not trace.
Referenced by rtems_rtl_elf_relocate_rela(), rtems_rtl_load_object(), rtems_rtl_obj_cache_close(), rtems_rtl_obj_cache_flush(), rtems_rtl_obj_load_sections(), rtems_rtl_unload_object(), and rtems_rtl_unresolved_resolve().
◆ rtems_rtl_trace_clear_mask()
rtems_rtl_trace_mask rtems_rtl_trace_clear_mask ( rtems_rtl_trace_mask  mask)
Clear the mask.
Parameters
maskThe mask bits to clear.
Returns
The previous mask.
◆ rtems_rtl_trace_set_mask()
rtems_rtl_trace_mask rtems_rtl_trace_set_mask ( rtems_rtl_trace_mask  mask)
Set the mask.
Parameters
maskThe mask bits to set.
Returns
The previous mask.
