RTEMS Run-Time Linker ELF Trace Support. More...
#include <stdbool.h>#include <stdint.h>
| #define | RTEMS_RTL_TRACE 1 |
| Set to 1 to build trace support in to the RTL code. | |
| #define | RTEMS_RTL_TRACE_DETAIL (1UL << 0) |
| List of tracing bits for the various parts of the link editor. | |
| #define | RTEMS_RTL_TRACE_WARNING (1UL << 1) |
| #define | RTEMS_RTL_TRACE_LOAD (1UL << 2) |
| #define | RTEMS_RTL_TRACE_UNLOAD (1UL << 3) |
| #define | RTEMS_RTL_TRACE_SECTION (1UL << 4) |
| #define | RTEMS_RTL_TRACE_SYMBOL (1UL << 5) |
| #define | RTEMS_RTL_TRACE_RELOC (1UL << 6) |
| #define | RTEMS_RTL_TRACE_GLOBAL_SYM (1UL << 7) |
| #define | RTEMS_RTL_TRACE_LOAD_SECT (1UL << 8) |
| #define | RTEMS_RTL_TRACE_ALLOCATOR (1UL << 9) |
| #define | RTEMS_RTL_TRACE_UNRESOLVED (1UL << 10) |
| #define | RTEMS_RTL_TRACE_CACHE (1UL << 11) |
| #define | RTEMS_RTL_TRACE_ALL (0xffffffffUL & ~(RTEMS_RTL_TRACE_CACHE)) |
Typedefs | |
| typedef uint32_t | rtems_rtl_trace_mask |
| The type of the mask. | |
| bool | rtems_rtl_trace (rtems_rtl_trace_mask mask) |
| Call to check if this part is bring traced. More... | |
| rtems_rtl_trace_mask | rtems_rtl_trace_set_mask (rtems_rtl_trace_mask mask) |
| Set the mask. More... | |
| rtems_rtl_trace_mask | rtems_rtl_trace_clear_mask (rtems_rtl_trace_mask mask) |
| Clear the mask. More... | |
| int | rtems_rtl_trace_shell_command (int argc, char *argv[]) |
| Add shell trace shell command. | |
| bool rtems_rtl_trace | ( | rtems_rtl_trace_mask | mask | ) |
If RTEMS_RTL_TRACE is defined to 0 the code is dead code elminiated when built with -Os, -O2, or higher.
| mask | The part of the API to trace. |
| true | Tracing is active for the mask. |
| false | Do not trace. |
Referenced by rtems_rtl_elf_relocate_rela(), rtems_rtl_load_object(), rtems_rtl_obj_cache_close(), rtems_rtl_obj_cache_flush(), rtems_rtl_obj_load_sections(), rtems_rtl_unload_object(), and rtems_rtl_unresolved_resolve().
| rtems_rtl_trace_mask rtems_rtl_trace_clear_mask | ( | rtems_rtl_trace_mask | mask | ) |
Clear the mask.
| mask | The mask bits to clear. |
| rtems_rtl_trace_mask rtems_rtl_trace_set_mask | ( | rtems_rtl_trace_mask | mask | ) |
Set the mask.
| mask | The mask bits to set. |
