include
rtems.h
1
11
/* COPYRIGHT (c) 1989-2008.
12
* On-Line Applications Research Corporation (OAR).
13
14
* The license and distribution terms for this file may be
15
* found in the file LICENSE in this distribution or at
16
* http://www.rtems.org/license/LICENSE.
17
18
19
#ifndef _RTEMS_H
20
#define _RTEMS_H
21
29
rtems/system.h
30
rtems/rtems/status.h
31
rtems/rtems/types.h
32
33
#include <rtems/config.h>
34
rtems/debug.h
35
rtems/init.h
36
rtems/rtems/options.h
37
rtems/rtems/tasks.h
38
rtems/rtems/intr.h
39
rtems/rtems/barrier.h
40
rtems/rtems/cache.h
41
rtems/rtems/clock.h
42
rtems/extension.h
43
rtems/rtems/timer.h
44
rtems/rtems/sem.h
45
rtems/rtems/message.h
46
rtems/rtems/event.h
47
rtems/rtems/signal.h
48
rtems/rtems/event.h
49
rtems/rtems/object.h
50
rtems/rtems/part.h
51
rtems/rtems/region.h
52
rtems/rtems/dpmem.h
53
rtems/io.h
54
rtems/fatal.h
55
rtems/rtems/ratemon.h
56
#if defined(RTEMS_MULTIPROCESSING)
57
rtems/rtems/mp.h
58
#endif
59
rtems/rtems/smp.h
60
61
rtems/rtems/support.h
62
63
#ifdef __cplusplus
64
extern
"C"
65
#endif
66
70
const
char
rtems_get_version_string
void
71
76
#define RTEMS_HAS_HARDWARE_FP CPU_HARDWARE_FP
77
78
79
* CONSTANTS WHICH MAY BE USED IN OBJECT NAME TO ID SEARCHES
80
81
85
#define RTEMS_SEARCH_ALL_NODES OBJECTS_SEARCH_ALL_NODES
86
91
#define RTEMS_SEARCH_OTHER_NODES OBJECTS_SEARCH_OTHER_NODES
92
96
#define RTEMS_SEARCH_LOCAL_NODE OBJECTS_SEARCH_LOCAL_NODE
97
104
#define RTEMS_WHO_AM_I OBJECTS_WHO_AM_I
105
106
107
* Parameters and return Id's for _Objects_Get_next
108
109
114
#define RTEMS_OBJECT_ID_INITIAL_INDEX OBJECTS_ID_INITIAL_INDEX
115
120
#define RTEMS_OBJECT_ID_FINAL_INDEX OBJECTS_ID_FINAL_INDEX
121
129
#define RTEMS_OBJECT_ID_INITIAL(_api, _class, _node) \
130
OBJECTS_ID_INITIAL(_api, _class, _node)
131
135
#define RTEMS_OBJECT_ID_FINAL OBJECTS_ID_FINAL
136
147
#define RTEMS_MINIMUM_STACK_SIZE STACK_MINIMUM_SIZE
148
163
#define RTEMS_CONFIGURED_MINIMUM_STACK_SIZE 0
164
170
#define RTEMS_NO_TIMEOUT WATCHDOG_NO_TIMEOUT
171
175
#define RTEMS_MINIMUM_PACKET_SIZE MP_PACKET_MINIMUM_PACKET_SIZE
176
184
#define RTEMS_MINIMUN_HETERO_CONVERSION MP_PACKET_MINIMUN_HETERO_CONVERSION
185
186
#ifdef __cplusplus
187
188
#endif
189
192
#endif
193
/* end of include file */
support.h
init.h
Constants and Structures Associated with the Initialization Manager.
fatal.h
Fatal API.
dpmem.h
io.h
Classic Input/Output Manager API.
const char * rtems_get_version_string(void)
Returns the pointer to the RTEMS version string.
Definition:
getversionstring.c:25
message.h
clock.h
sem.h
Classic Semaphores API.
barrier.h
ratemon.h
cache.h
event.h
tasks.h
mp.h
extension.h
User Extensions API.
intr.h
debug.h
Information Related to the Debug Support Within RTEMS.
status.h
region.h
signal.h
Signals API.
timer.h
system.h
Information Included in Every Function in the Executive.
types.h
options.h
object.h
part.h
smp.h
SMP Services API.
