Data Structures | Functions
sem.h File Reference
Classic Semaphores API. More...
#include <rtems/rtems/options.h>
#include <rtems/rtems/attr.h>
#include <rtems/score/coremutex.h>
#include <rtems/score/coresem.h>
#include <rtems/score/mrsp.h>
Include dependency graph for sem.h:
struct  Semaphore_Control
 The following defines the control block used to manage each semaphore. More...
rtems_status_code rtems_semaphore_create (rtems_name name, uint32_t count, rtems_attribute attribute_set, rtems_task_priority priority_ceiling, rtems_id *id)
 rtems_semaphore_create More...
rtems_status_code rtems_semaphore_ident (rtems_name name, uint32_t node, rtems_id *id)
 RTEMS Semaphore Name to Id. More...
rtems_status_code rtems_semaphore_delete (rtems_id id)
 RTEMS Delete Semaphore. More...
rtems_status_code rtems_semaphore_obtain (rtems_id id, rtems_option option_set, rtems_interval timeout)
 RTEMS Obtain Semaphore. More...
rtems_status_code rtems_semaphore_release (rtems_id id)
 RTEMS Semaphore Release. More...
rtems_status_code rtems_semaphore_flush (rtems_id id)
 RTEMS Semaphore Flush. More...
rtems_status_code rtems_semaphore_set_priority (rtems_id semaphore_id, rtems_id scheduler_id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
 Sets the priority value with respect to the specified scheduler of a semaphore. More...
This include file contains all the constants and structures associated with the Semaphore Manager. This manager utilizes standard Dijkstra counting semaphores to provide synchronization and mutual exclusion capabilities.
Directives provided are:
