21 #ifndef _RTEMS_SCORE_CORESEM_H 22 #define _RTEMS_SCORE_CORESEM_H This specifies that threads will wait for the semaphore in FIFO order.
Definition: coresem.h:45
CORE_semaphore_Disciplines discipline
This field indicates whether threads waiting on the semaphore block in FIFO or priority order...
Definition: coresem.h:62
The following defines the control block used to manage each counting semaphore.
Definition: coresem.h:69
Blocking disciplines for a semaphore.
Definition: coresem.h:43
This is the structure used to manage sets of tasks which are blocked waiting to acquire a resource...
Definition: threadq.h:171
Constants and Structures Needed to Declare a Thread Queue.
The following defines the control block used to manage the attributes of each semaphore.
Definition: coresem.h:56
This specifies that threads will wait for the semaphore in priority order.
Definition: coresem.h:49
CORE_semaphore_Attributes Attributes
This element is the set of attributes which define this instance's behavior.
Definition: coresem.h:77
Thread_queue_Control Wait_queue
This field is the Waiting Queue used to manage the set of tasks which are blocked waiting to obtain t...
Definition: coresem.h:73
uint32_t count
This element contains the current count of this semaphore.
Definition: coresem.h:79
uint32_t maximum_count
This element indicates the maximum count this semaphore may have.
Definition: coresem.h:58
