include
attr.h
1
13
/* COPYRIGHT (c) 1989-2008.
14
* On-Line Applications Research Corporation (OAR).
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef _RTEMS_RTEMS_ATTR_H
22
#define _RTEMS_RTEMS_ATTR_H
23
24
rtems/score/basedefs.h
25
26
#ifdef __cplusplus
27
extern
"C"
28
#endif
29
44
typedef
uint32_t
rtems_attribute
45
48
#define RTEMS_DEFAULT_ATTRIBUTES 0x00000000
49
53
#define RTEMS_LOCAL 0x00000000
54
58
#define RTEMS_GLOBAL 0x00000002
59
64
#define RTEMS_FIFO 0x00000000
65
70
#define RTEMS_PRIORITY 0x00000004
71
72
/******************** RTEMS Task Specific Attributes *********************/
73
79
#define RTEMS_NO_FLOATING_POINT 0x00000000
80
86
#define RTEMS_FLOATING_POINT 0x00000001
87
88
/***************** RTEMS Semaphore Specific Attributes ********************/
89
94
#define RTEMS_SEMAPHORE_CLASS 0x00000030
95
100
#define RTEMS_COUNTING_SEMAPHORE 0x00000000
101
106
#define RTEMS_BINARY_SEMAPHORE 0x00000010
107
112
#define RTEMS_SIMPLE_BINARY_SEMAPHORE 0x00000020
113
118
#define RTEMS_NO_INHERIT_PRIORITY 0x00000000
119
126
#define RTEMS_INHERIT_PRIORITY 0x00000040
127
132
#define RTEMS_NO_PRIORITY_CEILING 0x00000000
133
140
#define RTEMS_PRIORITY_CEILING 0x00000080
141
146
#define RTEMS_NO_MULTIPROCESSOR_RESOURCE_SHARING 0x00000000
147
154
#define RTEMS_MULTIPROCESSOR_RESOURCE_SHARING 0x00000100
155
156
/******************** RTEMS Barrier Specific Attributes ********************/
157
162
#define RTEMS_BARRIER_AUTOMATIC_RELEASE 0x00000010
163
168
#define RTEMS_BARRIER_MANUAL_RELEASE 0x00000000
169
170
/**************** RTEMS Internal Task Specific Attributes ****************/
171
176
#define RTEMS_APPLICATION_TASK 0x00000000
177
182
#define RTEMS_SYSTEM_TASK 0x00008000
183
186
#ifdef __cplusplus
187
188
#endif
189
190
#endif
191
/* end of include file */
rtems_attribute
uint32_t rtems_attribute
This defines the type used to contain Classic API attributes.
Definition:
attr.h:44
basedefs.h
Basic Definitions.
