Semaphore_Control Struct Reference
The following defines the control block used to manage each semaphore. More...
#include <sem.h>
Collaboration diagram for Semaphore_Control:
Collaboration graph
[legend]
Objects_Control Object
 This field is the object management portion of a Semaphore instance. More...
rtems_attribute attribute_set
 This is the Classic API attribute provided to the create directive. More...
union {
   CORE_mutex_Control   mutex
 This is the SuperCore Mutex instance associated with this Classic API Semaphore instance.
   CORE_semaphore_Control   semaphore
 This is the SuperCore Semaphore instance associated with this Classic API Semaphore instance.
Core_control
 This contains the memory associated with the SuperCore Semaphore or Mutex instance that provides the primary functionality of each Classic API Semaphore instance. More...
Field Documentation
◆ attribute_set
rtems_attribute Semaphore_Control::attribute_set
It is translated into behavioral attributes on the SuperCore Semaphore or Mutex instance.
Referenced by rtems_semaphore_create().
◆ Core_control
union { ... } Semaphore_Control::Core_control
The structure used is dependent on the attributes specified by the user on the create directive.
Note
Only one of these has meaning in a particular Classic API Semaphore instance.
◆ Object
Objects_Control Semaphore_Control::Object
Referenced by _Semaphore_Free(), and rtems_semaphore_create().
