tasks.h File Reference
#include <rtems/rtems/event.h>
#include <rtems/rtems/asr.h>
#include <rtems/rtems/attr.h>
Include dependency graph for tasks.h:
struct  rtems_initialization_tasks_table
 The following records define the Initialization Tasks Table. More...
struct  RTEMS_API_Control
 This is the API specific information required by each thread for the RTEMS API to function correctly. More...
#define RTEMS_SELF   OBJECTS_ID_OF_SELF
 Constant to be used as the ID of current task.
#define RTEMS_YIELD_PROCESSOR   WATCHDOG_NO_TIMEOUT
 This constant is passed to the rtems_task_wake_after directive as the interval when a task wishes to yield the CPU.
#define RTEMS_NO_PRIORITY   RTEMS_CURRENT_PRIORITY
 This is the constant used with the rtems_task_set_priority directive to indicate that the caller wants to obtain its current priority rather than set it as the name of the directive indicates.
#define RTEMS_MINIMUM_PRIORITY   (PRIORITY_MINIMUM + 1)
 This constant is the least valid value for a Classic API task priority.
#define RTEMS_MAXIMUM_PRIORITY   PRIORITY_MAXIMUM
 This constant is the maximum valid value for a Classic API task priority. More...
#define RTEMS_CURRENT_PRIORITY   PRIORITY_MINIMUM
 The following constant is passed to rtems_task_set_priority when the caller wants to obtain the current priority.
#define RTEMS_NOTEPAD_FIRST   0
 This is used to indicate the lowest numbered notepad.
#define RTEMS_NOTEPAD_0   0
 This is used to indicate the notepad location 0. More...
#define RTEMS_NOTEPAD_1   1
 This is used to indicate the notepad location 1. More...
#define RTEMS_NOTEPAD_2   2
 This is used to indicate the notepad location 2. More...
#define RTEMS_NOTEPAD_3   3
 This is used to indicate the notepad location 3. More...
#define RTEMS_NOTEPAD_4   4
 This is used to indicate the notepad location 4. More...
#define RTEMS_NOTEPAD_5   5
 This is used to indicate the notepad location 5. More...
#define RTEMS_NOTEPAD_6   6
 This is used to indicate the notepad location 6. More...
#define RTEMS_NOTEPAD_7   7
 This is used to indicate the notepad location 7. More...
#define RTEMS_NOTEPAD_8   8
 This is used to indicate the notepad location 8. More...
#define RTEMS_NOTEPAD_9   9
 This is used to indicate the notepad location 9. More...
#define RTEMS_NOTEPAD_10   10
 This is used to indicate the notepad location 10. More...
#define RTEMS_NOTEPAD_11   11
 This is used to indicate the notepad location 11. More...
#define RTEMS_NOTEPAD_12   12
 This is used to indicate the notepad location 12. More...
#define RTEMS_NOTEPAD_13   13
 This is used to indicate the notepad location 13. More...
#define RTEMS_NOTEPAD_14   14
 This is used to indicate the notepad location 14. More...
#define RTEMS_NOTEPAD_15   15
 This is used to indicate the notepad location 15. More...
#define RTEMS_NOTEPAD_LAST   RTEMS_NOTEPAD_15
 This is used to indicate the highest numbered notepad. More...
#define RTEMS_NUMBER_NOTEPADS   (RTEMS_NOTEPAD_LAST+1)
 This is used to indicate the number of notepads available. More...
typedef Priority_Control rtems_task_priority
 Define the type for an RTEMS API task priority.
typedef Thread_Control rtems_tcb
 External API name for Thread_Control.
typedef void rtems_task
 The following defines the "return type" of an RTEMS task.
typedef Thread_Entry_numeric_type rtems_task_argument
 The following defines the argument to an RTEMS task.
typedef rtems_task(* rtems_task_entry) (rtems_task_argument)
 The following defines the type for the entry point of an RTEMS task.
rtems_status_code rtems_task_create (rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
 RTEMS Task Create. More...
rtems_status_code rtems_task_ident (rtems_name name, uint32_t node, rtems_id *id)
 RTEMS Task Name to Id. More...
rtems_status_code rtems_task_delete (rtems_id id)
 RTEMS Delete Task. More...
rtems_status_code rtems_task_get_note (rtems_id id, uint32_t notepad, uint32_t *note)
 RTEMS Get Task Node. More...
rtems_status_code rtems_task_set_note (rtems_id id, uint32_t notepad, uint32_t note)
 RTEMS Set Task Note. More...
rtems_status_code rtems_task_mode (rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set)
 RTEMS Task Mode. More...
rtems_status_code rtems_task_restart (rtems_id id, uint32_t arg)
 RTEMS Task Restart. More...
rtems_status_code rtems_task_suspend (rtems_id id)
 RTEMS Suspend Task. More...
rtems_status_code rtems_task_resume (rtems_id id)
 RTEMS Resume Task. More...
rtems_status_code rtems_task_set_priority (rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
 RTEMS Set Task Priority. More...
rtems_status_code rtems_task_start (rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument)
 RTEMS Start Task. More...
rtems_status_code rtems_task_wake_when (rtems_time_of_day *time_buffer)
 RTEMS Task Wake When. More...
rtems_status_code rtems_task_wake_after (rtems_interval ticks)
 RTEMS Task Wake After. More...
rtems_status_code rtems_task_is_suspended (rtems_id id)
 rtems_task_is_suspended More...
rtems_status_code rtems_task_variable_add (rtems_id tid, void **ptr, void(*dtor)(void *))
 RTEMS Add Task Variable. More...
rtems_status_code rtems_task_variable_get (rtems_id tid, void **ptr, void **result)
 Get a per-task variable. More...
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr)
 RTEMS Delete Task Variable. More...
rtems_status_code rtems_task_get_scheduler (rtems_id task_id, rtems_id *scheduler_id)
 Gets the scheduler of a task. More...
rtems_status_code rtems_task_set_scheduler (rtems_id task_id, rtems_id scheduler_id)
 Sets the scheduler of a task. More...
rtems_id rtems_task_self (void)
 RTEMS Get Self Task Id. More...
rtems_status_code rtems_scheduler_ident (rtems_name name, rtems_id *id)
 Identifies a scheduler by its name. More...
void _RTEMS_tasks_Initialize_user_tasks_body (void)
 _RTEMS_tasks_Initialize_user_tasks_body More...
void(* _RTEMS_tasks_Initialize_user_tasks_p )(void)
 When the user configures a set of Classic API initialization tasks, This variable will point to the method used to initialize them. More...
◆ _RTEMS_tasks_Initialize_user_tasks_body()
void _RTEMS_tasks_Initialize_user_tasks_body ( void  )
This routine creates and starts all configured user initialization threads.
Input parameters: NONE
Output parameters: NONE
RTEMS Task Manager
Variable Documentation
◆ _RTEMS_tasks_Initialize_user_tasks_p
void(* _RTEMS_tasks_Initialize_user_tasks_p) (void)
Note
It is instantiated and initialized by confdefs.h based upon application requirements.
Referenced by _RTEMS_tasks_Initialize_user_tasks().
