io.h File Reference
Classic Input/Output Manager API. More...
Include dependency graph for io.h:
struct  rtems_driver_address_table
struct  rtems_driver_name_t
#define SAPI_IO_EXTERN   extern
typedef uint32_t rtems_device_major_number
typedef uint32_t rtems_device_minor_number
typedef rtems_status_code rtems_device_driver
typedef rtems_device_driver(* rtems_device_driver_entry) (rtems_device_major_number, rtems_device_minor_number, void *)
rtems_status_code rtems_io_initialize (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 IO driver initialization. More...
rtems_status_code rtems_io_open (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Opening for the IO manager. More...
rtems_status_code rtems_io_close (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Closing for the IO manager. More...
rtems_status_code rtems_io_read (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Reading for the IO manager. More...
rtems_status_code rtems_io_write (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Writing for the IO manager. More...
rtems_status_code rtems_io_control (rtems_device_major_number major, rtems_device_minor_number minor, void *argument)
 Control for the IO manager. More...
rtems_status_code rtems_io_lookup_name (const char *name, rtems_driver_name_t *device_info)
void _IO_Initialize_all_drivers (void)
 Initialization of all device drivers. More...
Device Driver Maintainance
rtems_status_code rtems_io_driver_io_error (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Returns RTEMS_IO_ERROR. More...
rtems_status_code rtems_io_register_driver (rtems_device_major_number major, const rtems_driver_address_table *driver_table, rtems_device_major_number *registered_major)
 Registers and initializes the device with the device driver table driver_table and major number major. More...
rtems_status_code rtems_io_unregister_driver (rtems_device_major_number major)
 Unregister a driver from the device driver table. More...
rtems_status_code rtems_io_register_name (const char *device_name, rtems_device_major_number major, rtems_device_minor_number minor)
 Registers the name device_name in the file system for the device with number tuple major and minor. More...
const size_t _IO_Number_of_drivers
rtems_driver_address_table _IO_Driver_address_table []
bool _IO_All_drivers_initialized
This file emulates the old Classic RTEMS IO manager directives which register and lookup names using the in-memory filesystem.
◆ _IO_Initialize_all_drivers()
void _IO_Initialize_all_drivers ( void  )
Initializes all device drivers.
Referenced by rtems_initialize_device_drivers().
◆ rtems_io_lookup_name()
rtems_status_code rtems_io_lookup_name ( const char *  name,
rtems_driver_name_t device_info
Deprecated:
Use stat() instead.
References RTEMS_SUCCESSFUL.
