Enumerations | Functions
clock.h File Reference
#include <rtems/score/tod.h>
#include <rtems/config.h>
#include <rtems/score/timecounterimpl.h>
#include <sys/time.h>
Include dependency graph for clock.h:
enum  rtems_clock_get_options {
  RTEMS_CLOCK_GET_TOD, RTEMS_CLOCK_GET_SECONDS_SINCE_EPOCH, RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, RTEMS_CLOCK_GET_TICKS_PER_SECOND,
  RTEMS_CLOCK_GET_TIME_VALUE
 List of things which can be returned by the rtems_clock_get directive. More...
rtems_status_code rtems_clock_get (rtems_clock_get_options option, void *time_buffer)
 Obtain Current Time of Day. More...
rtems_status_code rtems_clock_get_tod (rtems_time_of_day *time_buffer)
 Obtain Current Time of Day (Classic TOD) More...
rtems_status_code rtems_clock_get_tod_timeval (struct timeval *time)
 Obtain TOD in struct timeval Format. More...
rtems_status_code rtems_clock_get_seconds_since_epoch (rtems_interval *the_interval)
 Obtain Seconds Since Epoch. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_get_ticks_since_boot (void)
 Gets the current ticks counter value. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_tick_later (rtems_interval delta)
 Returns the ticks counter value delta ticks in the future. More...
RTEMS_INLINE_ROUTINE rtems_interval rtems_clock_tick_later_usec (rtems_interval delta_in_usec)
 Returns the ticks counter value at least delta microseconds in the future. More...
RTEMS_INLINE_ROUTINE bool rtems_clock_tick_before (rtems_interval tick)
 Returns true if the current ticks counter value indicates a time before the time specified by the tick value and false otherwise. More...
rtems_interval rtems_clock_get_ticks_per_second (void)
 Obtain Ticks Per Seconds. More...
rtems_status_code rtems_clock_set (const rtems_time_of_day *time_buffer)
 Set the Current TOD. More...
rtems_status_code rtems_clock_tick (void)
 Announce a Clock Tick. More...
rtems_status_code rtems_clock_get_uptime (struct timespec *uptime)
 Obtain the System Uptime. More...
void rtems_clock_get_uptime_timeval (struct timeval *uptime)
 Gets the System Uptime in the Struct Timeval Format. More...
RTEMS_INLINE_ROUTINE time_t rtems_clock_get_uptime_seconds (void)
 Returns the system uptime in seconds. More...
uint64_t rtems_clock_get_uptime_nanoseconds (void)
 Returns the system uptime in nanoseconds. More...
bool _TOD_Validate (const rtems_time_of_day *the_tod)
 TOD Validate. More...
Watchdog_Interval _TOD_To_seconds (const rtems_time_of_day *the_tod)
 TOD to Seconds. More...
