#include <stdint.h>#include <rtems/score/heap.h>#include <rtems/score/object.h>#include <rtems/score/priority.h>#include <rtems/score/watchdog.h>#include <rtems/rtems/modes.h>
| struct | rtems_time_of_day |
| Data structure to manage and manipulate calendar time. More... | |
| #define | RTEMS_ID_NONE OBJECTS_ID_NONE |
| Invalid object identifier value. More... | |
Typedefs | |
| typedef uint32_t | rtems_name |
| Classic API object name type. More... | |
| typedef Objects_Id | rtems_id |
| Used to manage and manipulate RTEMS object identifiers. | |
| typedef Context_Control | rtems_context |
| Public name for task context area. | |
| typedef Context_Control_fp | rtems_context_fp |
| Public name for task floating point context area. | |
| typedef CPU_Interrupt_frame | rtems_interrupt_frame |
| Defines the format of the interrupt stack frame as it appears to a user ISR. More... | |
| typedef Heap_Information_block | region_information_block |
| Information structure returned by the Heap Handler via the Region Manager. | |
| typedef Watchdog_Interval | rtems_interval |
| Used to manage and manipulate intervals specified by clock ticks. | |
| typedef struct timespec | rtems_thread_cpu_usage_t |
| Represents the CPU usage per thread. More... | |
| typedef Modes_Control | rtems_mode |
| Task mode type. | |
