| #define | rtems_interrupt_disable(_isr_cookie) _ISR_Disable(_isr_cookie) |
| | Disable RTEMS Interrupt. More...
| #define | rtems_interrupt_enable(_isr_cookie) _ISR_Enable(_isr_cookie) |
| | Enable RTEMS Interrupt. More...
| #define | rtems_interrupt_flash(_isr_cookie) _ISR_Flash(_isr_cookie) |
| | Flash RTEMS Interrupt. More...
| #define | rtems_interrupt_local_disable(_isr_cookie) _ISR_Disable_without_giant( _isr_cookie ) |
| | This macro disables the interrupts on the current processor. More...
| #define | rtems_interrupt_local_enable(_isr_cookie) _ISR_Enable_without_giant( _isr_cookie ) |
| | This macro restores the previous interrupt level on the current processor. More...
| #define | rtems_interrupt_is_in_progress() _ISR_Is_in_progress() |
| | RTEMS Interrupt Is in Progress. More...
| #define | rtems_interrupt_cause(_interrupt_to_cause) |
| | This routine generates an interrupt. More...
| #define | rtems_interrupt_clear(_interrupt_to_clear) |
| | This routine clears the specified interrupt. More...
| #define | RTEMS_INTERRUPT_LOCK_MEMBER(_designator) ISR_LOCK_MEMBER( _designator ) |
| | Defines an interrupt lock member. More...
| #define | RTEMS_INTERRUPT_LOCK_DECLARE(_qualifier, _designator) ISR_LOCK_DECLARE( _qualifier, _designator ) |
| | Declares an interrupt lock variable. More...
| #define | RTEMS_INTERRUPT_LOCK_DEFINE(_qualifier, _designator, _name) ISR_LOCK_DEFINE( _qualifier, _designator, _name ) |
| | Defines an interrupt lock variable. More...
| #define | RTEMS_INTERRUPT_LOCK_REFERENCE(_designator, _target) ISR_LOCK_REFERENCE( _designator, _target ) |
| | Defines an interrupt lock variable reference. More...
| #define | RTEMS_INTERRUPT_LOCK_INITIALIZER(_name) ISR_LOCK_INITIALIZER( _name ) |
| | Initializer for static initialization of interrupt locks. More...
| #define | rtems_interrupt_lock_initialize(_lock, _name) _ISR_lock_Initialize( _lock, _name ) |
| | Initializes an interrupt lock. More...
| #define | rtems_interrupt_lock_destroy(_lock) _ISR_lock_Destroy( _lock ) |
| | Destroys an interrupt lock. More...
| #define | rtems_interrupt_lock_acquire(_lock, _lock_context) _ISR_lock_ISR_disable_and_acquire( _lock, _lock_context ) |
| | Acquires an interrupt lock. More...
| #define | rtems_interrupt_lock_release(_lock, _lock_context) _ISR_lock_Release_and_ISR_enable( _lock, _lock_context ) |
| | Releases an interrupt lock. More...
| #define | rtems_interrupt_lock_acquire_isr(_lock, _lock_context) _ISR_lock_Acquire( _lock, _lock_context ) |
| | Acquires an interrupt lock in the corresponding interrupt service routine. More...
| #define | rtems_interrupt_lock_release_isr(_lock, _lock_context) _ISR_lock_Release( _lock, _lock_context ) |
| | Releases an interrupt lock in the corresponding interrupt service routine. More...
