include
intr.h
1
13
/* COPYRIGHT (c) 1989-2013.
14
* On-Line Applications Research Corporation (OAR).
15
16
* The license and distribution terms for this file may be
17
* found in the file LICENSE in this distribution or at
18
* http://www.rtems.org/license/LICENSE.
19
20
21
#ifndef _RTEMS_RTEMS_INTR_H
22
#define _RTEMS_RTEMS_INTR_H
23
24
#ifdef __cplusplus
25
extern
"C"
26
#endif
27
28
rtems/rtems/status.h
29
rtems/score/isr.h
30
rtems/score/isrlock.h
31
45
typedef
ISR_Level
rtems_interrupt_level
46
50
typedef
ISR_Vector_number
rtems_vector_number
51
55
typedef
ISR_Handler
rtems_isr
56
57
#if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
58
59
typedef
ISR_Handler_entry rtems_isr_entry;
60
61
#else
62
67
typedef
rtems_isr
( *rtems_isr_entry )(
68
rtems_vector_number
69
70
85
rtems_status_code
rtems_interrupt_catch(
86
rtems_isr_entry new_isr_handler,
87
rtems_vector_number vector,
88
rtems_isr_entry *old_isr_handler
89
90
#endif
91
92
#if !defined(RTEMS_SMP)
93
102
#define rtems_interrupt_disable( _isr_cookie ) \
103
_ISR_Disable(_isr_cookie)
104
113
#define rtems_interrupt_enable( _isr_cookie ) \
114
_ISR_Enable(_isr_cookie)
115
125
#define rtems_interrupt_flash( _isr_cookie ) \
126
_ISR_Flash(_isr_cookie)
127
128
#endif
/* RTEMS_SMP */
129
141
#define rtems_interrupt_local_disable( _isr_cookie ) \
142
_ISR_Disable_without_giant( _isr_cookie )
143
151
#define rtems_interrupt_local_enable( _isr_cookie ) \
152
_ISR_Enable_without_giant( _isr_cookie )
153
161
#define rtems_interrupt_is_in_progress() \
162
_ISR_Is_in_progress()
163
169
#define rtems_interrupt_cause( _interrupt_to_cause )
170
176
#define rtems_interrupt_clear( _interrupt_to_clear )
177
198
typedef
ISR_lock_Control
rtems_interrupt_lock
199
203
typedef
ISR_lock_Context
rtems_interrupt_lock_context
204
212
#define RTEMS_INTERRUPT_LOCK_MEMBER( _designator ) \
213
ISR_LOCK_MEMBER( _designator )
214
223
#define RTEMS_INTERRUPT_LOCK_DECLARE( _qualifier, _designator ) \
224
ISR_LOCK_DECLARE( _qualifier, _designator )
225
236
#define RTEMS_INTERRUPT_LOCK_DEFINE( _qualifier, _designator, _name ) \
237
ISR_LOCK_DEFINE( _qualifier, _designator, _name )
238
247
#define RTEMS_INTERRUPT_LOCK_REFERENCE( _designator, _target ) \
248
ISR_LOCK_REFERENCE( _designator, _target )
249
256
#define RTEMS_INTERRUPT_LOCK_INITIALIZER( _name ) ISR_LOCK_INITIALIZER( _name )
257
268
#define rtems_interrupt_lock_initialize( _lock, _name ) \
269
_ISR_lock_Initialize( _lock, _name )
270
278
#define rtems_interrupt_lock_destroy( _lock ) \
279
_ISR_lock_Destroy( _lock )
280
295
#define rtems_interrupt_lock_acquire( _lock, _lock_context ) \
296
_ISR_lock_ISR_disable_and_acquire( _lock, _lock_context )
297
312
#define rtems_interrupt_lock_release( _lock, _lock_context ) \
313
_ISR_lock_Release_and_ISR_enable( _lock, _lock_context )
314
332
#define rtems_interrupt_lock_acquire_isr( _lock, _lock_context ) \
333
_ISR_lock_Acquire( _lock, _lock_context )
334
348
#define rtems_interrupt_lock_release_isr( _lock, _lock_context ) \
349
_ISR_lock_Release( _lock, _lock_context )
350
353
#ifdef __cplusplus
354
355
#endif
356
359
#endif
360
/* end of include file */
ISR_Vector_number
uint32_t ISR_Vector_number
The following type defines the type used to manage the vectors.
Definition:
isr.h:46
isr.h
Data Related to the Management of Processor Interrupt Levels.
rtems_vector_number
ISR_Vector_number rtems_vector_number
Control block type used to manage the vectors.
Definition:
intr.h:50
ISR_lock_Control
ISR lock control.
Definition:
isrlock.h:56
ISR_lock_Context rtems_interrupt_lock_context
Local interrupt lock context for acquire and release pairs.
Definition:
intr.h:203
rtems_isr
ISR_Handler rtems_isr
Return type for interrupt handler.
Definition:
intr.h:55
rtems_status_code
rtems_status_code
Classic API Status.
Definition:
status.h:46
ISR_Level
uint32_t ISR_Level
The following type defines the control block used to manage the interrupt level portion of the status...
Definition:
isrlevel.h:42
status.h
ISR_Level rtems_interrupt_level
Interrupt level type.
Definition:
intr.h:45
ISR_Handler
void ISR_Handler
Return type for ISR Handler.
Definition:
isr.h:51
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:65
isrlock.h
ISR Locks.
ISR_lock_Control rtems_interrupt_lock
Interrupt lock control.
Definition:
intr.h:198
