User Extensions API. More...
#include <rtems/score/userext.h>
struct | Extension_Control |
Typedefs | |
typedef User_extensions_routine | rtems_extension |
typedef User_extensions_thread_create_extension | rtems_task_create_extension |
typedef User_extensions_thread_delete_extension | rtems_task_delete_extension |
typedef User_extensions_thread_start_extension | rtems_task_start_extension |
typedef User_extensions_thread_restart_extension | rtems_task_restart_extension |
typedef User_extensions_thread_switch_extension | rtems_task_switch_extension |
typedef User_extensions_thread_begin_extension | rtems_task_begin_extension |
typedef User_extensions_thread_exitted_extension | rtems_task_exitted_extension |
typedef User_extensions_fatal_extension | rtems_fatal_extension |
typedef User_extensions_Table | rtems_extensions_table |
typedef Internal_errors_Source | rtems_fatal_source |
typedef Internal_errors_t | rtems_fatal_code |
rtems_status_code | rtems_extension_create (rtems_name name, const rtems_extensions_table *extension_table, rtems_id *id) |
Creates an extension set object. More... | |
rtems_status_code | rtems_extension_ident (rtems_name name, rtems_id *id) |
Identifies an extension set object by a name. More... | |
rtems_status_code | rtems_extension_delete (rtems_id id) |
Deletes an extension set object specified by the identifier id. More... | |
