Data Structures | Functions
dpmem.h File Reference
Include dependency graph for dpmem.h:
struct  Dual_ported_memory_Control
 The following structure defines the port control block. More...
rtems_status_code rtems_port_create (rtems_name name, void *internal_start, void *external_start, uint32_t length, rtems_id *id)
 Creates a port into a dual-ported memory area. More...
rtems_status_code rtems_port_ident (rtems_name name, rtems_id *id)
 RTEMS Port Name to Id. More...
rtems_status_code rtems_port_delete (rtems_id id)
 RTEMS Delete Port. More...
rtems_status_code rtems_port_external_to_internal (rtems_id id, void *external, void **internal)
 RTEMS Port External to Internal. More...
rtems_status_code rtems_port_internal_to_external (rtems_id id, void *internal, void **external)
 RTEMS Port Internal to External. More...
