rtems_status_code | rtems_region_create (rtems_name name, void *starting_address, uintptr_t length, uintptr_t page_size, rtems_attribute attribute_set, rtems_id *id) |
| rtems_region_create More...
rtems_status_code | rtems_region_extend (rtems_id id, void *starting_address, uintptr_t length) |
| RTEMS Extend Region. More...
rtems_status_code | rtems_region_ident (rtems_name name, rtems_id *id) |
| RTEMS Region Name to Id. More...
rtems_status_code | rtems_region_get_information (rtems_id id, Heap_Information_block *the_info) |
| RTEMS Get Region Information. More...
rtems_status_code | rtems_region_get_free_information (rtems_id id, Heap_Information_block *the_info) |
| RTEMS Get Region Free Information. More...
rtems_status_code | rtems_region_delete (rtems_id id) |
| RTEMS Delete Region. More...
rtems_status_code | rtems_region_get_segment (rtems_id id, uintptr_t size, rtems_option option_set, rtems_interval timeout, void **segment) |
| RTEMS Get Region Segment. More...
rtems_status_code | rtems_region_get_segment_size (rtems_id id, void *segment, uintptr_t *size) |
| RTEMS Get Region Segment Size. More...
rtems_status_code | rtems_region_return_segment (rtems_id id, void *segment) |
| RTEMS Return Region Segment. More...
rtems_status_code | rtems_region_resize_segment (rtems_id id, void *segment, uintptr_t size, uintptr_t *old_size) |
| Resize RTEMS Region Segment. More...
