RTEMS Run-Time Linker ELF Headers. More...
bool | rtems_rtl_rap_file_check (rtems_rtl_obj_t *obj, int fd) |
The RAP format check handler. More... | |
bool | rtems_rtl_rap_file_load (rtems_rtl_obj_t *obj, int fd) |
The RAP format load handler. More... | |
bool | rtems_rtl_rap_file_unload (rtems_rtl_obj_t *obj) |
The RAP format unload handler. More... | |
rtems_rtl_loader_format_t * | rtems_rtl_rap_file_sig (void) |
The RAP format signature handler. More... | |
bool rtems_rtl_rap_file_check | ( | rtems_rtl_obj_t * | obj, |
int | fd | ||
obj | The object being checked. |
fd | The file descriptor. |
bool rtems_rtl_rap_file_load | ( | rtems_rtl_obj_t * | obj, |
int | fd | ||
obj | The object to load. |
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
References rtems_rtl_rap_s::file, rtems_rtl_obj_s::ooffset, rtems_rtl_obj_cache_read(), and rtems_rtl_obj_caches().
rtems_rtl_loader_format_t* rtems_rtl_rap_file_sig | ( | void | ) |
bool rtems_rtl_rap_file_unload | ( | rtems_rtl_obj_t * | obj | ) |
obj | The object to unload. |
