RTEMS Run-Time Link Editor. More...
#include <stdlib.h>#include <stdio.h>#include <string.h>#include <rtems/libio_.h>#include <rtems/rtl/rtl.h>#include "rtl-allocator.h"#include "rtl-error.h"#include "rtl-string.h"#include "rtl-trace.h"
| #define | RTEMS_MUTEX_ATTRIBS |
| Semaphore configuration to create a mutex. More... | |
| #define | RTEMS_RTL_ELF_SYMBOL_CACHE (2048) |
| Symbol table cache size. More... | |
| #define | RTEMS_RTL_ELF_STRING_CACHE (2048) |
| String table cache size. | |
| #define | RTEMS_RTL_ELF_RELOC_CACHE (2048) |
| Relocations table cache size. | |
| #define | RTEMS_RTL_COMP_OUTPUT (2048) |
| Decompression output buffer. | |
| void | rtems_rtl_base_global_syms_init (void) |
| Define a default base global symbol loader function that is weak so a real table can be linked in when the user wants one. | |
| rtems_rtl_data_t * | rtems_rtl_data (void) |
| Get the RTL data with out locking. More... | |
| rtems_rtl_symbols_t * | rtems_rtl_global_symbols (void) |
| Get the RTL global symbol table with out locking. More... | |
| rtems_rtl_unresolved_t * | rtems_rtl_unresolved (void) |
| Get the RTL resolved table with out locking. More... | |
| void | rtems_rtl_obj_caches (rtems_rtl_obj_cache_t **symbols, rtems_rtl_obj_cache_t **strings, rtems_rtl_obj_cache_t **relocs) |
| Get the RTL symbols, strings, or relocations object file caches. More... | |
| void | rtems_rtl_obj_caches_flush (void) |
| Flush all the object file caches. | |
| void | rtems_rtl_obj_comp (rtems_rtl_obj_comp_t **decomp, rtems_rtl_obj_cache_t *cache, int fd, int compression, off_t offset) |
| Get the RTL decompressor setting the cache and the offset in the file the compressed stream starts. More... | |
| rtems_rtl_data_t * | rtems_rtl_lock (void) |
| Lock the Run-time Linker. More... | |
| bool | rtems_rtl_unlock (void) |
| Unlock the Run-time Linker. More... | |
| rtems_rtl_obj_t * | rtems_rtl_check_handle (void *handle) |
| Check a pointer is a valid object file descriptor returning the pointer as that type. More... | |
| rtems_rtl_obj_t * | rtems_rtl_find_obj (const char *name) |
| Find the object given a file name. More... | |
| rtems_rtl_obj_t * | rtems_rtl_load_object (const char *name, int mode) |
| Load an object file into memory relocating it. More... | |
| bool | rtems_rtl_unload_object (rtems_rtl_obj_t *obj) |
| Unload an object file. More... | |
| void | rtems_rtl_run_ctors (rtems_rtl_obj_t *obj) |
| Run any constructor functions the object file may contain. More... | |
| bool | rtems_rtl_path_append (const char *path) |
| Append the path to the search path. More... | |
| bool | rtems_rtl_path_prepend (const char *path) |
| Prepend the path to the search path. More... | |
| void | rtems_rtl_base_sym_global_add (const unsigned char *esyms, unsigned int size) |
| Add an exported symbol table to the global symbol table. More... | |
| rtems_rtl_obj_t * | rtems_rtl_baseimage (void) |
| Return the object file descriptor for the base image. More... | |
This is the RTL implementation.
| #define RTEMS_MUTEX_ATTRIBS |
| #define RTEMS_RTL_ELF_SYMBOL_CACHE (2048) |
They can be big so the cache needs space to work.
| void rtems_rtl_base_sym_global_add | ( | const unsigned char * | esyms, |
| unsigned int | count | ||
This call is normally used by an object file when loaded that contains a global symbol table.
| esyms | The exported symbol table. |
| count | The size of the exported symbol table. |
| rtems_rtl_obj_t* rtems_rtl_baseimage | ( | void | ) |
The object file descriptor returned is created when the run time linker is initialised.
Assumes the RTL has been locked.
| rtems_rtl_obj_t* rtems_rtl_check_handle | ( | void * | handle | ) |
| handle | Pointer to the object file to be validated. |
References rtems_rtl_data_s::objects, rtems_chain_first(), and rtems_chain_is_tail().
| rtems_rtl_data_t* rtems_rtl_data | ( | void | ) |
This call assumes the RTL is locked.
| NULL | The RTL data is not initialised. |
| rtems_rtl_obj_t* rtems_rtl_find_obj | ( | const char * | name | ) |
| name | The name of the object file. |
| NULL | No object file with that name found. |
References rtems_rtl_data_s::objects, rtems_chain_first(), rtems_chain_is_tail(), and rtems_rtl_parse_name().
| rtems_rtl_symbols_t* rtems_rtl_global_symbols | ( | void | ) |
This call assmes the RTL is locked.
References rtems_rtl_data_s::globals, and rtems_rtl_set_error().
Referenced by rtems_rtl_symbol_global_find().
| rtems_rtl_obj_t* rtems_rtl_load_object | ( | const char * | name, |
| int | mode | ||
It will not be resolved against other symbols in other object files or the base image.
The name can be a file name for an object file or it can be encoded to reference an archive of object modules (static library). This encoding is specific to RTEMS and allows dependences to specify an archive without the searching overhead normally incurred by linkers locating object files in an archive. The file name format rules are:
| mode | The mode of the load as defined by the dlopen call. |
References rtems_rtl_trace().
| rtems_rtl_data_t* rtems_rtl_lock | ( | void | ) |
| NULL | The RTL data could not be initialised or locked. Typically this means the lock could not be created. |
| void rtems_rtl_obj_caches | ( | rtems_rtl_obj_cache_t ** | symbols, |
| rtems_rtl_obj_cache_t ** | strings, | ||
| rtems_rtl_obj_cache_t ** | relocs | ||
| symbols | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
| strings | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
| relocs | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
References rtems_rtl_data_s::relocs, rtems_rtl_data_s::strings, and rtems_rtl_data_s::symbols.
Referenced by rtems_rtl_elf_file_check(), rtems_rtl_elf_file_load(), and rtems_rtl_rap_file_load().
| void rtems_rtl_obj_comp | ( | rtems_rtl_obj_comp_t ** | decomp, |
| rtems_rtl_obj_cache_t * | cache, | ||
| int | fd, | ||
| int | compression, | ||
| off_t | offset | ||
| decomp | Pointer to the location to set the compressor into. Returns NULL is rtl is not initialised. |
| cache | The cache to read the file with. Saves needing an extrs buffer. |
| offset | The offset in the file the compressed stream starts. |
References rtems_rtl_data_s::decomp, and rtems_rtl_obj_comp_set().
| bool rtems_rtl_path_append | ( | const char * | path | ) |
| path | The path to append. |
| false | The path could not be appended. |
| true | The path was appended. |
| bool rtems_rtl_path_prepend | ( | const char * | path | ) |
| path | The path to prepend. |
| false | The path could not be prepended. |
| true | The path was prepended. |
| void rtems_rtl_run_ctors | ( | rtems_rtl_obj_t * | obj | ) |
This call assumes the linker is unlocked.
| obj | The object file. |
References rtems_rtl_obj_run_ctors().
| bool rtems_rtl_unload_object | ( | rtems_rtl_obj_t * | obj | ) |
This only happens when the user count is 0.
| obj | The object file descriptor. |
| true | The object file has been unloaded. |
| false | The object file could not be unloaded. |
| bool rtems_rtl_unlock | ( | void | ) |
References rtems_rtl_data_s::lock, rtems_semaphore_release(), and RTEMS_SUCCESSFUL.
| rtems_rtl_unresolved_t* rtems_rtl_unresolved | ( | void | ) |
References rtems_rtl_set_error(), and rtems_rtl_data_s::unresolved.
Referenced by rtems_rtl_unresolved_interate(), and rtems_rtl_unresolved_remove().
