rtems_flashdisk Struct Reference
The virtual block table holds the mapping for blocks as seen by the disk drivers to the device, segment and page numbers of the physical device. More...
Collaboration diagram for rtems_flashdisk:
Collaboration graph
[legend]
rtems_device_major_number major
 The driver's major number. More...
rtems_device_minor_number minor
 The driver's minor number. More...
uint32_t flags
 configuration flags. More...
uint32_t compact_segs
 Max segs to compact at once. More...
uint32_t avail_compact_segs
 The number of segments when compaction occurs when writing. More...
uint32_t block_size
 The block size for this disk. More...
rtems_fdisk_block_ctlblocks
 The block to segment-page mappings. More...
uint32_t block_count
 The number of avail. More...
uint32_t unavail_blocks
 The number of unavail blocks. More...
uint32_t starvation_threshold
 Erased blocks starvation threshold. More...
uint32_t erased_blocks
 The number of erased blocks. More...
rtems_fdisk_device_ctldevices
 The flash devices for this disk. More...
uint32_t device_count
 The number of flash devices. More...
rtems_fdisk_segment_ctl_queue available
 The queue of segments with available pages. More...
rtems_fdisk_segment_ctl_queue used
 The list of segments with all pages used. More...
rtems_fdisk_segment_ctl_queue erase
 The list of segments to be erased. More...
rtems_fdisk_segment_ctl_queue failed
 The list of segments that failed when being erased. More...
rtems_id lock
 Mutex for threading protection. More...
uint8_t * copy_buffer
 Copy buf used during compacting.
uint32_t info_level
 The info trace level. More...
uint32_t starvations
 Erased blocks starvations counter. More...
Field Documentation
◆ avail_compact_segs
uint32_t rtems_flashdisk::avail_compact_segs
◆ available
rtems_fdisk_segment_ctl_queue rtems_flashdisk::available
◆ block_count
uint32_t rtems_flashdisk::block_count
blocks.
◆ block_size
uint32_t rtems_flashdisk::block_size
◆ blocks
rtems_fdisk_block_ctl* rtems_flashdisk::blocks
◆ compact_segs
uint32_t rtems_flashdisk::compact_segs
◆ device_count
uint32_t rtems_flashdisk::device_count
◆ devices
rtems_fdisk_device_ctl* rtems_flashdisk::devices
◆ erase
rtems_fdisk_segment_ctl_queue rtems_flashdisk::erase
◆ erased_blocks
uint32_t rtems_flashdisk::erased_blocks
◆ failed
rtems_fdisk_segment_ctl_queue rtems_flashdisk::failed
◆ flags
uint32_t rtems_flashdisk::flags
◆ info_level
uint32_t rtems_flashdisk::info_level
◆ lock
rtems_id rtems_flashdisk::lock
◆ major
rtems_device_major_number rtems_flashdisk::major
◆ minor
rtems_device_minor_number rtems_flashdisk::minor
◆ starvation_threshold
uint32_t rtems_flashdisk::starvation_threshold
◆ starvations
uint32_t rtems_flashdisk::starvations
◆ unavail_blocks
uint32_t rtems_flashdisk::unavail_blocks
◆ used
rtems_fdisk_segment_ctl_queue rtems_flashdisk::used
