drvmgr_bus_ops Struct Reference
Bus operations. More...
#include <drvmgr.h>
int(* init [DRVMGR_LEVEL_MAX])(struct drvmgr_bus *)
int(* remove )(struct drvmgr_bus *)
int(* unite )(struct drvmgr_drv *, struct drvmgr_dev *)
 Unite Hardware Device with Driver.
int(* int_register )(struct drvmgr_dev *, int index, const char *info, drvmgr_isr isr, void *arg)
int(* int_unregister )(struct drvmgr_dev *, int index, drvmgr_isr isr, void *arg)
int(* int_clear )(struct drvmgr_dev *, int index)
int(* int_mask )(struct drvmgr_dev *, int index)
int(* int_unmask )(struct drvmgr_dev *, int index)
int(* get_params )(struct drvmgr_dev *, struct drvmgr_bus_params *)
int(* get_freq )(struct drvmgr_dev *, int, unsigned int *)
void(* get_info_dev )(struct drvmgr_dev *, void(*print)(void *p, char *str), void *p)
 Function called to request information about a device. More...
Bus operations.
Field Documentation
◆ get_info_dev
void(* drvmgr_bus_ops::get_info_dev) (struct drvmgr_dev *, void(*print)(void *p, char *str), void *p)
The bus driver interpret the bus-specific information about the device.
