| file | clock.c |
| | This source file contains the Clock Driver implementation.
| file | printk-support.c |
| | This source file contains the definition of BSP_output_char and BSP_poll_char.
| file | tms570-sci.c |
| | This source file contains the Console Driver implementation using the Serial Communication Interface (SCI).
| file | bsp.h |
| | This header file provides BSP-specific interfaces.
| file | irq.h |
| | This header file provides TMS570 interrupt definitions.
| file | system-clocks.h |
| | This header file provides a free-running timer interface.
| file | errata_SSWF021_45.h |
| | This header file provides errata SSWF021#45 interfaces.
| file | reg_adc.h |
| | This header file provides ADC interfaces.
| file | reg_ccmsr.h |
| | This header file provides CCMSR interfaces.
| file | reg_crc.h |
| | This header file provides CRC interfaces.
| file | reg_dcan.h |
| | This header file provides DCAN interfaces.
| file | reg_dcc.h |
| | This header file provides DCC interfaces.
| file | reg_dma.h |
| | This header file provides DMA interfaces.
| file | reg_dmm.h |
| | This header file provides DMM interfaces.
| file | reg_efuse.h |
| | This header file provides EFUSE interfaces.
| file | reg_emacc.h |
| | This header file provides EMACC interfaces.
| file | reg_emacm.h |
| | This header file provides EMACM interfaces.
| file | reg_emif.h |
| | This header file provides EMIF interfaces.
| file | reg_esm.h |
| | This header file provides ESM interfaces.
| file | reg_flash.h |
| | This header file provides flash interfaces.
| file | reg_flex_ray.h |
| | This header file provides FlexRay interfaces.
| file | reg_gio.h |
| | This header file provides GIO interfaces.
| file | reg_htu.h |
| | This header file provides HTU interfaces.
| file | reg_i2c.h |
| | This header file provides I2C interfaces.
| file | reg_iomm.h |
| | This header file provides IOMM interfaces.
| file | reg_lin.h |
| | This header file provides LIN interfaces.
| file | reg_mdio.h |
| | This header file provides MDIO interfaces.
| file | reg_n2het.h |
| | This header file provides N2HET interfaces.
| file | reg_pbist.h |
| | This header file provides PBIST interfaces.
| file | reg_pcr.h |
| | This header file provides PCR interfaces.
| file | reg_pll.h |
| | This header file provides PLL interfaces.
| file | reg_pmm.h |
| | This header file provides PMM interfaces.
| file | reg_pom.h |
| | This header file provides POM interfaces.
| file | reg_rti.h |
| | This header file provides RTI interfaces.
| file | reg_rtp.h |
| | This header file provides RTP interfaces.
| file | reg_sci.h |
| | This header file provides SCI interfaces.
| file | reg_spi.h |
| | This header file provides SPI interfaces.
| file | reg_stc.h |
| | This header file provides STC interfaces.
| file | reg_sys.h |
| | This header file provides SYS interfaces.
| file | reg_sys2.h |
| | This header file provides SYS2 interfaces.
| file | reg_tcr.h |
| | This header file provides TCR interfaces.
| file | reg_tcram.h |
| | This header file provides TCRAM interfaces.
| file | reg_vim.h |
| | This header file provides VIM interfaces.
| file | tms570-pinmux.h |
| | This header file provides interfaces of the I/O Multiplexing Module (IOMM) support.
| file | tms570-pins.h |
| | This header file selects the pin mapping according to the selected chip.
| file | tms570-pom.h |
| | This header file provides interfaces of the Parameter Overlay Module (POM) support.
| file | tms570-sci-driver.h |
| | This header file provides interfaces of the SCI support.
| file | tms570.h |
| | This header file provides TMS570 interfaces.
| file | tms570_hwinit.h |
| | This header file provides interfaces of the hardware initialization support.
| file | tms570_selftest.h |
| | This header file provides TMS570 selftest error codes, addresses and functions.
| file | tms570_selftest_parity.h |
| | This header file provides interfaces of the parity selftest support.
| file | tms570lc4357-pins.h |
| | This header file provides pin mappings for the TMS570LC4357.
| file | tms570ls3137zwt-pins.h |
| | This header file provides pin mappings for the TMS570LS3137ZWT.
| file | tm27.h |
| | This header file provides a TM27 support implementation.
| file | irq.c |
| | This source file contains the interrupt controller support implementation.
| file | bspreset.c |
| | This source file contains the bsp_reset() implementation.
| file | bspstart.c |
| | This source file contains the bsp_start() implementation.
| file | bspstarthooks-hwinit.c |
| | This source file contains the bsp_start_hook_0() implementation.
| file | bspstarthooks.c |
| | This source file contains the bsp_start_hook_1(0 implementation.
| file | errata_SSWF021_45.c |
| | This source file contains errata SSWF021#45 workaround implementation.
| file | fail_notification.c |
| | This source file contains the default bsp_selftest_fail_notification() and tms570_memory_port0_fail_notification() implementations.
| file | hwinit-lc4357-hdk.c |
| | This source file contains parts of the system initialization.
| file | hwinit-ls3137-hdk.c |
| file | init_esm.c |
| | This source file contains the error signaling module initialization.
| file | init_system.c |
| file | pinmux.c |
| | This source file contains the I/O Multiplexing Module (IOMM) support implementation.
| file | tms570-pom.c |
| | This source file contains the Parameter Overlay Module (POM) support implementation.
| file | tms570_selftest.c |
| | This source file contains the selftest support implementation.
| file | tms570_selftest_par_can.c |
| | This source file contains the CAN module parity based protection support.
| file | tms570_selftest_par_mibspi.c |
| | This source file contains the MibSPI module parity based protection support.
| file | tms570_selftest_par_std.c |
| | This source file contains the HETx, HTUx, ADC, DMA and VIM module parity based protection support.
| file | tms570_selftest_parity.c |
| | This source file contains parts of the parity based protection support.
| file | tms570_tcram_tests.c |
| | This source file contains TCRAM selftest functions.
TMS570 Board Support Package.
