This source file contains errata SSWF021#45 workaround implementation.
More...
#define | SYS_CLKSRC_PLL1 0x00000002U |
#define | SYS_CLKSRC_PLL2 0x00000040U |
#define | SYS_CLKCNTRL_PENA 0x00000100U |
#define | ESM_SR1_PLL1SLIP 0x400U |
#define | ESM_SR4_PLL2SLIP 0x400U |
#define | PLL1 0x08 |
#define | PLL2 0x80 |
#define | dcc1CNT1_CLKSRC_PLL1 0x0000A000U |
#define | dcc1CNT1_CLKSRC_PLL2 0x0000A001U |
| uint32_t | _errata_SSWF021_45_both_plls (uint32_t count) |
| | This handles the errata for PLL1 and PLL2. This function is called in device startup.
| uint32_t | _errata_SSWF021_45_pll1 (uint32_t count) |
| | This handles the errata for PLL1. This function is called in device startup.
| uint32_t | _errata_SSWF021_45_pll2 (uint32_t count) |
| | This handles the errata for PLL2. This function is called in device startup.
◆ _errata_SSWF021_45_both_plls()
| uint32_t _errata_SSWF021_45_both_plls |
uint32_t |
count | ) |
- Parameters
| [in] | count | : Number of retries until both PLLs are locked successfully Minimum value recommended is 5 |
- Returns
- 0 = Success (the PLL or both PLLs have successfully locked and then been disabled) 1 = PLL1 failed to successfully lock in "count" tries 2 = PLL2 failed to successfully lock in "count" tries 3 = Neither PLL1 nor PLL2 successfully locked in "count" tries 4 = The workaround function was not able to disable at least one of the PLLs. The most likely reason is that a PLL is already being used as a clock source. This can be caused by the workaround function being called from the wrong place in the code.
◆ _errata_SSWF021_45_pll1()
| uint32_t _errata_SSWF021_45_pll1 |
uint32_t |
count | ) |
- Parameters
| [in] | count | : Number of retries until both PLL1 is locked successfully Minimum value recommended is 5 |
- Returns
◆ _errata_SSWF021_45_pll2()
| uint32_t _errata_SSWF021_45_pll2 |
uint32_t |
count | ) |
- Parameters
| [in] | count | : Number of retries until PLL2 is locked successfully Minimum value recommended is 5 |
- Returns
