#define | TMS570_DCAN_CTL_WUBA BSP_BIT32(25) |
#define | TMS570_DCAN_CTL_PDR BSP_BIT32(24) |
#define | TMS570_DCAN_CTL_DE3 BSP_BIT32(20) |
#define | TMS570_DCAN_CTL_DE2 BSP_BIT32(19) |
#define | TMS570_DCAN_CTL_DE1 BSP_BIT32(18) |
#define | TMS570_DCAN_CTL_IE1 BSP_BIT32(17) |
#define | TMS570_DCAN_CTL_InitDbg BSP_BIT32(16) |
#define | TMS570_DCAN_CTL_SWR BSP_BIT32(15) |
#define | TMS570_DCAN_CTL_PMD(val) BSP_FLD32(val,10, 13) |
#define | TMS570_DCAN_CTL_PMD_GET(reg) BSP_FLD32GET(reg,10, 13) |
#define | TMS570_DCAN_CTL_PMD_SET(reg, val) BSP_FLD32SET(reg, val,10, 13) |
#define | TMS570_DCAN_CTL_ABO BSP_BIT32(9) |
#define | TMS570_DCAN_CTL_IDS BSP_BIT32(8) |
#define | TMS570_DCAN_CTL_Test BSP_BIT32(7) |
#define | TMS570_DCAN_CTL_CCE BSP_BIT32(6) |
#define | TMS570_DCAN_CTL_DAR BSP_BIT32(5) |
#define | TMS570_DCAN_CTL_EIE BSP_BIT32(3) |
#define | TMS570_DCAN_CTL_SIE BSP_BIT32(2) |
#define | TMS570_DCAN_CTL_IE0 BSP_BIT32(1) |
#define | TMS570_DCAN_CTL_Init BSP_BIT32(0) |
#define | TMS570_DCAN_ES_PDA BSP_BIT32(10) |
#define | TMS570_DCAN_ES_WakeUp_Pnd BSP_BIT32(9) |
#define | TMS570_DCAN_ES_PER BSP_BIT32(8) |
#define | TMS570_DCAN_ES_BOff BSP_BIT32(7) |
#define | TMS570_DCAN_ES_EWarn BSP_BIT32(6) |
#define | TMS570_DCAN_ES_EPass BSP_BIT32(5) |
#define | TMS570_DCAN_ES_RxOK BSP_BIT32(4) |
#define | TMS570_DCAN_ES_TxOK BSP_BIT32(3) |
#define | TMS570_DCAN_ES_LEC(val) BSP_FLD32(val,0, 2) |
#define | TMS570_DCAN_ES_LEC_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_DCAN_ES_LEC_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_DCAN_ERRC_RP BSP_BIT32(15) |
#define | TMS570_DCAN_ERRC_REC(val) BSP_FLD32(val,8, 14) |
#define | TMS570_DCAN_ERRC_REC_GET(reg) BSP_FLD32GET(reg,8, 14) |
#define | TMS570_DCAN_ERRC_REC_SET(reg, val) BSP_FLD32SET(reg, val,8, 14) |
#define | TMS570_DCAN_ERRC_TEC(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_ERRC_TEC_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_ERRC_TEC_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_BTR_BRPE(val) BSP_FLD32(val,16, 19) |
#define | TMS570_DCAN_BTR_BRPE_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_DCAN_BTR_BRPE_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_DCAN_BTR_TSeg2(val) BSP_FLD32(val,12, 14) |
#define | TMS570_DCAN_BTR_TSeg2_GET(reg) BSP_FLD32GET(reg,12, 14) |
#define | TMS570_DCAN_BTR_TSeg2_SET(reg, val) BSP_FLD32SET(reg, val,12, 14) |
#define | TMS570_DCAN_BTR_TSeg1(val) BSP_FLD32(val,8, 11) |
#define | TMS570_DCAN_BTR_TSeg1_GET(reg) BSP_FLD32GET(reg,8, 11) |
#define | TMS570_DCAN_BTR_TSeg1_SET(reg, val) BSP_FLD32SET(reg, val,8, 11) |
#define | TMS570_DCAN_BTR_SJW(val) BSP_FLD32(val,6, 7) |
#define | TMS570_DCAN_BTR_SJW_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_DCAN_BTR_SJW_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_DCAN_BTR_BRP(val) BSP_FLD32(val,0, 5) |
#define | TMS570_DCAN_BTR_BRP_GET(reg) BSP_FLD32GET(reg,0, 5) |
#define | TMS570_DCAN_BTR_BRP_SET(reg, val) BSP_FLD32SET(reg, val,0, 5) |
#define | TMS570_DCAN_INT_Int1ID(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_INT_Int1ID_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_INT_Int1ID_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_INT_Int0ID(val) BSP_FLD32(val,0, 15) |
#define | TMS570_DCAN_INT_Int0ID_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_DCAN_INT_Int0ID_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_DCAN_TEST_RDA BSP_BIT32(9) |
#define | TMS570_DCAN_TEST_EXL BSP_BIT32(8) |
#define | TMS570_DCAN_TEST_Rx BSP_BIT32(7) |
#define | TMS570_DCAN_TEST_Tx(val) BSP_FLD32(val,5, 6) |
#define | TMS570_DCAN_TEST_Tx_GET(reg) BSP_FLD32GET(reg,5, 6) |
#define | TMS570_DCAN_TEST_Tx_SET(reg, val) BSP_FLD32SET(reg, val,5, 6) |
#define | TMS570_DCAN_TEST_LBack BSP_BIT32(4) |
#define | TMS570_DCAN_TEST_Silent BSP_BIT32(3) |
#define | TMS570_DCAN_PERR_Word_Number(val) BSP_FLD32(val,8, 10) |
#define | TMS570_DCAN_PERR_Word_Number_GET(reg) BSP_FLD32GET(reg,8, 10) |
#define | TMS570_DCAN_PERR_Word_Number_SET(reg, val) BSP_FLD32SET(reg, val,8, 10) |
#define | TMS570_DCAN_PERR_Message_Number(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_PERR_Message_Number_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_PERR_Message_Number_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_TXRQX_TxRqstReg8(val) BSP_FLD32(val,14, 15) |
#define | TMS570_DCAN_TXRQX_TxRqstReg8_GET(reg) BSP_FLD32GET(reg,14, 15) |
#define | TMS570_DCAN_TXRQX_TxRqstReg8_SET(reg, val) BSP_FLD32SET(reg, val,14, 15) |
#define | TMS570_DCAN_TXRQX_TxRqstReg7(val) BSP_FLD32(val,12, 13) |
#define | TMS570_DCAN_TXRQX_TxRqstReg7_GET(reg) BSP_FLD32GET(reg,12, 13) |
#define | TMS570_DCAN_TXRQX_TxRqstReg7_SET(reg, val) BSP_FLD32SET(reg, val,12, 13) |
#define | TMS570_DCAN_TXRQX_TxRqstReg6(val) BSP_FLD32(val,10, 11) |
#define | TMS570_DCAN_TXRQX_TxRqstReg6_GET(reg) BSP_FLD32GET(reg,10, 11) |
#define | TMS570_DCAN_TXRQX_TxRqstReg6_SET(reg, val) BSP_FLD32SET(reg, val,10, 11) |
#define | TMS570_DCAN_TXRQX_TxRqstReg5(val) BSP_FLD32(val,8, 9) |
#define | TMS570_DCAN_TXRQX_TxRqstReg5_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_DCAN_TXRQX_TxRqstReg5_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_DCAN_TXRQX_TxRqstReg4(val) BSP_FLD32(val,6, 7) |
#define | TMS570_DCAN_TXRQX_TxRqstReg4_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_DCAN_TXRQX_TxRqstReg4_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_DCAN_TXRQX_TxRqstReg3(val) BSP_FLD32(val,4, 5) |
#define | TMS570_DCAN_TXRQX_TxRqstReg3_GET(reg) BSP_FLD32GET(reg,4, 5) |
#define | TMS570_DCAN_TXRQX_TxRqstReg3_SET(reg, val) BSP_FLD32SET(reg, val,4, 5) |
#define | TMS570_DCAN_TXRQX_TxRqstReg2(val) BSP_FLD32(val,2, 3) |
#define | TMS570_DCAN_TXRQX_TxRqstReg2_GET(reg) BSP_FLD32GET(reg,2, 3) |
#define | TMS570_DCAN_TXRQX_TxRqstReg2_SET(reg, val) BSP_FLD32SET(reg, val,2, 3) |
#define | TMS570_DCAN_TXRQX_TxRqstReg1(val) BSP_FLD32(val,0, 1) |
#define | TMS570_DCAN_TXRQX_TxRqstReg1_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_DCAN_TXRQX_TxRqstReg1_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_DCAN_NWDATX_NewDatReg8(val) BSP_FLD32(val,14, 15) |
#define | TMS570_DCAN_NWDATX_NewDatReg8_GET(reg) BSP_FLD32GET(reg,14, 15) |
#define | TMS570_DCAN_NWDATX_NewDatReg8_SET(reg, val) BSP_FLD32SET(reg, val,14, 15) |
#define | TMS570_DCAN_NWDATX_NewDatReg7(val) BSP_FLD32(val,12, 13) |
#define | TMS570_DCAN_NWDATX_NewDatReg7_GET(reg) BSP_FLD32GET(reg,12, 13) |
#define | TMS570_DCAN_NWDATX_NewDatReg7_SET(reg, val) BSP_FLD32SET(reg, val,12, 13) |
#define | TMS570_DCAN_NWDATX_NewDatReg6(val) BSP_FLD32(val,10, 11) |
#define | TMS570_DCAN_NWDATX_NewDatReg6_GET(reg) BSP_FLD32GET(reg,10, 11) |
#define | TMS570_DCAN_NWDATX_NewDatReg6_SET(reg, val) BSP_FLD32SET(reg, val,10, 11) |
#define | TMS570_DCAN_NWDATX_NewDatReg5(val) BSP_FLD32(val,8, 9) |
#define | TMS570_DCAN_NWDATX_NewDatReg5_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_DCAN_NWDATX_NewDatReg5_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_DCAN_NWDATX_NewDatReg4(val) BSP_FLD32(val,6, 7) |
#define | TMS570_DCAN_NWDATX_NewDatReg4_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_DCAN_NWDATX_NewDatReg4_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_DCAN_NWDATX_NewDatReg3(val) BSP_FLD32(val,4, 5) |
#define | TMS570_DCAN_NWDATX_NewDatReg3_GET(reg) BSP_FLD32GET(reg,4, 5) |
#define | TMS570_DCAN_NWDATX_NewDatReg3_SET(reg, val) BSP_FLD32SET(reg, val,4, 5) |
#define | TMS570_DCAN_NWDATX_NewDatReg2(val) BSP_FLD32(val,2, 3) |
#define | TMS570_DCAN_NWDATX_NewDatReg2_GET(reg) BSP_FLD32GET(reg,2, 3) |
#define | TMS570_DCAN_NWDATX_NewDatReg2_SET(reg, val) BSP_FLD32SET(reg, val,2, 3) |
#define | TMS570_DCAN_NWDATX_NewDatReg1(val) BSP_FLD32(val,0, 1) |
#define | TMS570_DCAN_NWDATX_NewDatReg1_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_DCAN_NWDATX_NewDatReg1_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_DCAN_INTPNDX_IntPndReg8(val) BSP_FLD32(val,14, 15) |
#define | TMS570_DCAN_INTPNDX_IntPndReg8_GET(reg) BSP_FLD32GET(reg,14, 15) |
#define | TMS570_DCAN_INTPNDX_IntPndReg8_SET(reg, val) BSP_FLD32SET(reg, val,14, 15) |
#define | TMS570_DCAN_INTPNDX_IntPndReg7(val) BSP_FLD32(val,12, 13) |
#define | TMS570_DCAN_INTPNDX_IntPndReg7_GET(reg) BSP_FLD32GET(reg,12, 13) |
#define | TMS570_DCAN_INTPNDX_IntPndReg7_SET(reg, val) BSP_FLD32SET(reg, val,12, 13) |
#define | TMS570_DCAN_INTPNDX_IntPndReg6(val) BSP_FLD32(val,10, 11) |
#define | TMS570_DCAN_INTPNDX_IntPndReg6_GET(reg) BSP_FLD32GET(reg,10, 11) |
#define | TMS570_DCAN_INTPNDX_IntPndReg6_SET(reg, val) BSP_FLD32SET(reg, val,10, 11) |
#define | TMS570_DCAN_INTPNDX_IntPndReg5(val) BSP_FLD32(val,8, 9) |
#define | TMS570_DCAN_INTPNDX_IntPndReg5_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_DCAN_INTPNDX_IntPndReg5_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_DCAN_INTPNDX_IntPndReg4(val) BSP_FLD32(val,6, 7) |
#define | TMS570_DCAN_INTPNDX_IntPndReg4_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_DCAN_INTPNDX_IntPndReg4_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_DCAN_INTPNDX_IntPndReg3(val) BSP_FLD32(val,4, 5) |
#define | TMS570_DCAN_INTPNDX_IntPndReg3_GET(reg) BSP_FLD32GET(reg,4, 5) |
#define | TMS570_DCAN_INTPNDX_IntPndReg3_SET(reg, val) BSP_FLD32SET(reg, val,4, 5) |
#define | TMS570_DCAN_INTPNDX_IntPndReg2(val) BSP_FLD32(val,2, 3) |
#define | TMS570_DCAN_INTPNDX_IntPndReg2_GET(reg) BSP_FLD32GET(reg,2, 3) |
#define | TMS570_DCAN_INTPNDX_IntPndReg2_SET(reg, val) BSP_FLD32SET(reg, val,2, 3) |
#define | TMS570_DCAN_INTPNDX_IntPndReg1(val) BSP_FLD32(val,0, 1) |
#define | TMS570_DCAN_INTPNDX_IntPndReg1_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_DCAN_INTPNDX_IntPndReg1_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_DCAN_MSGVALX_MsgValReg8(val) BSP_FLD32(val,14, 15) |
#define | TMS570_DCAN_MSGVALX_MsgValReg8_GET(reg) BSP_FLD32GET(reg,14, 15) |
#define | TMS570_DCAN_MSGVALX_MsgValReg8_SET(reg, val) BSP_FLD32SET(reg, val,14, 15) |
#define | TMS570_DCAN_MSGVALX_MsgValReg7(val) BSP_FLD32(val,12, 13) |
#define | TMS570_DCAN_MSGVALX_MsgValReg7_GET(reg) BSP_FLD32GET(reg,12, 13) |
#define | TMS570_DCAN_MSGVALX_MsgValReg7_SET(reg, val) BSP_FLD32SET(reg, val,12, 13) |
#define | TMS570_DCAN_MSGVALX_MsgValReg6(val) BSP_FLD32(val,10, 11) |
#define | TMS570_DCAN_MSGVALX_MsgValReg6_GET(reg) BSP_FLD32GET(reg,10, 11) |
#define | TMS570_DCAN_MSGVALX_MsgValReg6_SET(reg, val) BSP_FLD32SET(reg, val,10, 11) |
#define | TMS570_DCAN_MSGVALX_MsgValReg5(val) BSP_FLD32(val,8, 9) |
#define | TMS570_DCAN_MSGVALX_MsgValReg5_GET(reg) BSP_FLD32GET(reg,8, 9) |
#define | TMS570_DCAN_MSGVALX_MsgValReg5_SET(reg, val) BSP_FLD32SET(reg, val,8, 9) |
#define | TMS570_DCAN_MSGVALX_MsgValReg4(val) BSP_FLD32(val,6, 7) |
#define | TMS570_DCAN_MSGVALX_MsgValReg4_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_DCAN_MSGVALX_MsgValReg4_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_DCAN_MSGVALX_MsgValReg3(val) BSP_FLD32(val,4, 5) |
#define | TMS570_DCAN_MSGVALX_MsgValReg3_GET(reg) BSP_FLD32GET(reg,4, 5) |
#define | TMS570_DCAN_MSGVALX_MsgValReg3_SET(reg, val) BSP_FLD32SET(reg, val,4, 5) |
#define | TMS570_DCAN_MSGVALX_MsgValReg2(val) BSP_FLD32(val,2, 3) |
#define | TMS570_DCAN_MSGVALX_MsgValReg2_GET(reg) BSP_FLD32GET(reg,2, 3) |
#define | TMS570_DCAN_MSGVALX_MsgValReg2_SET(reg, val) BSP_FLD32SET(reg, val,2, 3) |
#define | TMS570_DCAN_MSGVALX_MsgValReg1(val) BSP_FLD32(val,0, 1) |
#define | TMS570_DCAN_MSGVALX_MsgValReg1_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_DCAN_MSGVALX_MsgValReg1_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_DCAN_IF1CMD_WR_RD BSP_BIT32(23) |
#define | TMS570_DCAN_IF1CMD_Mask BSP_BIT32(22) |
#define | TMS570_DCAN_IF1CMD_Arb BSP_BIT32(21) |
#define | TMS570_DCAN_IF1CMD_Control BSP_BIT32(20) |
#define | TMS570_DCAN_IF1CMD_ClrIntPnd BSP_BIT32(19) |
#define | TMS570_DCAN_IF1CMD_TxRqst_NewDat BSP_BIT32(18) |
#define | TMS570_DCAN_IF1CMD_Data_A BSP_BIT32(17) |
#define | TMS570_DCAN_IF1CMD_Data_B BSP_BIT32(16) |
#define | TMS570_DCAN_IF1CMD_Busy BSP_BIT32(15) |
#define | TMS570_DCAN_IF1CMD_DMA_Active BSP_BIT32(14) |
#define | TMS570_DCAN_IF1CMD_Message_Number(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF1CMD_Message_Number_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF1CMD_Message_Number_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF1MSK_MXtd BSP_BIT32(31) |
#define | TMS570_DCAN_IF1MSK_MDir BSP_BIT32(30) |
#define | TMS570_DCAN_IF1MSK_Msk(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF1MSK_Msk_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF1MSK_Msk_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF1ARB_MsgVal BSP_BIT32(31) |
#define | TMS570_DCAN_IF1ARB_Xtd BSP_BIT32(30) |
#define | TMS570_DCAN_IF1ARB_Dir BSP_BIT32(29) |
#define | TMS570_DCAN_IF1ARB_ID(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF1ARB_ID_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF1ARB_ID_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF1MCTL_NewDat BSP_BIT32(15) |
#define | TMS570_DCAN_IF1MCTL_MsgLst BSP_BIT32(14) |
#define | TMS570_DCAN_IF1MCTL_IntPnd BSP_BIT32(13) |
#define | TMS570_DCAN_IF1MCTL_UMask BSP_BIT32(12) |
#define | TMS570_DCAN_IF1MCTL_TxIE BSP_BIT32(11) |
#define | TMS570_DCAN_IF1MCTL_RxIE BSP_BIT32(10) |
#define | TMS570_DCAN_IF1MCTL_RmtEn BSP_BIT32(9) |
#define | TMS570_DCAN_IF1MCTL_TxRqst BSP_BIT32(8) |
#define | TMS570_DCAN_IF1MCTL_EoB BSP_BIT32(7) |
#define | TMS570_DCAN_IF1MCTL_DLC(val) BSP_FLD32(val,0, 3) |
#define | TMS570_DCAN_IF1MCTL_DLC_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_DCAN_IF1MCTL_DLC_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_DCAN_IF1DATA_Data0(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF1DATA_Data0_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF1DATA_Data0_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF1DATA_Data1(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF1DATA_Data1_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF1DATA_Data1_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF1DATA_Data2(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF1DATA_Data2_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF1DATA_Data2_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF1DATA_Data3(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF1DATA_Data3_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF1DATA_Data3_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_IF1DATB_Data4(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF1DATB_Data4_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF1DATB_Data4_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF1DATB_Data5(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF1DATB_Data5_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF1DATB_Data5_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF1DATB_Data6(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF1DATB_Data6_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF1DATB_Data6_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF1DATB_Data7(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF1DATB_Data7_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF1DATB_Data7_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_IF2CMD_WR_RD BSP_BIT32(23) |
#define | TMS570_DCAN_IF2CMD_Mask BSP_BIT32(22) |
#define | TMS570_DCAN_IF2CMD_Arb BSP_BIT32(21) |
#define | TMS570_DCAN_IF2CMD_Control BSP_BIT32(20) |
#define | TMS570_DCAN_IF2CMD_ClrIntPnd BSP_BIT32(19) |
#define | TMS570_DCAN_IF2CMD_TxRqst_NewDat BSP_BIT32(18) |
#define | TMS570_DCAN_IF2CMD_Data_A BSP_BIT32(17) |
#define | TMS570_DCAN_IF2CMD_Data_B BSP_BIT32(16) |
#define | TMS570_DCAN_IF2CMD_Busy BSP_BIT32(15) |
#define | TMS570_DCAN_IF2CMD_DMA_Active BSP_BIT32(14) |
#define | TMS570_DCAN_IF2CMD_Message_Number(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF2CMD_Message_Number_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF2CMD_Message_Number_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF2MSK_MXtd BSP_BIT32(31) |
#define | TMS570_DCAN_IF2MSK_MDir BSP_BIT32(30) |
#define | TMS570_DCAN_IF2MSK_Msk(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF2MSK_Msk_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF2MSK_Msk_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF2ARB_MsgVal BSP_BIT32(31) |
#define | TMS570_DCAN_IF2ARB_Xtd BSP_BIT32(30) |
#define | TMS570_DCAN_IF2ARB_Dir BSP_BIT32(29) |
#define | TMS570_DCAN_IF2ARB_ID(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF2ARB_ID_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF2ARB_ID_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF2MCTL_NewDat BSP_BIT32(15) |
#define | TMS570_DCAN_IF2MCTL_MsgLst BSP_BIT32(14) |
#define | TMS570_DCAN_IF2MCTL_IntPnd BSP_BIT32(13) |
#define | TMS570_DCAN_IF2MCTL_UMask BSP_BIT32(12) |
#define | TMS570_DCAN_IF2MCTL_TxIE BSP_BIT32(11) |
#define | TMS570_DCAN_IF2MCTL_RxIE BSP_BIT32(10) |
#define | TMS570_DCAN_IF2MCTL_RmtEn BSP_BIT32(9) |
#define | TMS570_DCAN_IF2MCTL_TxRqst BSP_BIT32(8) |
#define | TMS570_DCAN_IF2MCTL_EoB BSP_BIT32(7) |
#define | TMS570_DCAN_IF2MCTL_DLC(val) BSP_FLD32(val,0, 3) |
#define | TMS570_DCAN_IF2MCTL_DLC_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_DCAN_IF2MCTL_DLC_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_DCAN_IF2DATA_Data0(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF2DATA_Data0_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF2DATA_Data0_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF2DATA_Data1(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF2DATA_Data1_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF2DATA_Data1_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF2DATA_Data2(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF2DATA_Data2_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF2DATA_Data2_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF2DATA_Data3(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF2DATA_Data3_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF2DATA_Data3_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_IF2DATB_Data4(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF2DATB_Data4_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF2DATB_Data4_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF2DATB_Data5(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF2DATB_Data5_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF2DATB_Data5_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF2DATB_Data6(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF2DATB_Data6_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF2DATB_Data6_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF2DATB_Data7(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF2DATB_Data7_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF2DATB_Data7_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_IF3OBS_IF3_Upd BSP_BIT32(15) |
#define | TMS570_DCAN_IF3OBS_IF3_SDB BSP_BIT32(12) |
#define | TMS570_DCAN_IF3OBS_IF3_SDA BSP_BIT32(11) |
#define | TMS570_DCAN_IF3OBS_IF3_SC BSP_BIT32(10) |
#define | TMS570_DCAN_IF3OBS_IF3_SA BSP_BIT32(9) |
#define | TMS570_DCAN_IF3OBS_IF3_SM BSP_BIT32(8) |
#define | TMS570_DCAN_IF3OBS_Data_B BSP_BIT32(4) |
#define | TMS570_DCAN_IF3OBS_Data_A BSP_BIT32(3) |
#define | TMS570_DCAN_IF3OBS_Ctrl BSP_BIT32(2) |
#define | TMS570_DCAN_IF3OBS_Arb BSP_BIT32(1) |
#define | TMS570_DCAN_IF3OBS_Mask BSP_BIT32(0) |
#define | TMS570_DCAN_IF3MSK_MXtd BSP_BIT32(31) |
#define | TMS570_DCAN_IF3MSK_MDir BSP_BIT32(30) |
#define | TMS570_DCAN_IF3MSK_Msk(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF3MSK_Msk_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF3MSK_Msk_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF3ARB_MsgVal BSP_BIT32(31) |
#define | TMS570_DCAN_IF3ARB_Xtd BSP_BIT32(30) |
#define | TMS570_DCAN_IF3ARB_Dir BSP_BIT32(29) |
#define | TMS570_DCAN_IF3ARB_ID(val) BSP_FLD32(val,0, 28) |
#define | TMS570_DCAN_IF3ARB_ID_GET(reg) BSP_FLD32GET(reg,0, 28) |
#define | TMS570_DCAN_IF3ARB_ID_SET(reg, val) BSP_FLD32SET(reg, val,0, 28) |
#define | TMS570_DCAN_IF3MCTL_NewDat BSP_BIT32(15) |
#define | TMS570_DCAN_IF3MCTL_MsgLst BSP_BIT32(14) |
#define | TMS570_DCAN_IF3MCTL_IntPnd BSP_BIT32(13) |
#define | TMS570_DCAN_IF3MCTL_UMask BSP_BIT32(12) |
#define | TMS570_DCAN_IF3MCTL_TxIE BSP_BIT32(11) |
#define | TMS570_DCAN_IF3MCTL_RxIE BSP_BIT32(10) |
#define | TMS570_DCAN_IF3MCTL_RmtEn BSP_BIT32(9) |
#define | TMS570_DCAN_IF3MCTL_TxRqst BSP_BIT32(8) |
#define | TMS570_DCAN_IF3MCTL_EoB BSP_BIT32(7) |
#define | TMS570_DCAN_IF3MCTL_DLC(val) BSP_FLD32(val,0, 3) |
#define | TMS570_DCAN_IF3MCTL_DLC_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_DCAN_IF3MCTL_DLC_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_DCAN_IF3DATA_Data0(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF3DATA_Data0_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF3DATA_Data0_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF3DATA_Data1(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF3DATA_Data1_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF3DATA_Data1_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF3DATA_Data2(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF3DATA_Data2_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF3DATA_Data2_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF3DATA_Data3(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF3DATA_Data3_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF3DATA_Data3_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_IF3DATB_Data4(val) BSP_FLD32(val,0, 7) |
#define | TMS570_DCAN_IF3DATB_Data4_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_DCAN_IF3DATB_Data4_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_DCAN_IF3DATB_Data5(val) BSP_FLD32(val,8, 15) |
#define | TMS570_DCAN_IF3DATB_Data5_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_DCAN_IF3DATB_Data5_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_DCAN_IF3DATB_Data6(val) BSP_FLD32(val,16, 23) |
#define | TMS570_DCAN_IF3DATB_Data6_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_DCAN_IF3DATB_Data6_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_DCAN_IF3DATB_Data7(val) BSP_FLD32(val,24, 31) |
#define | TMS570_DCAN_IF3DATB_Data7_GET(reg) BSP_FLD32GET(reg,24, 31) |
#define | TMS570_DCAN_IF3DATB_Data7_SET(reg, val) BSP_FLD32SET(reg, val,24, 31) |
#define | TMS570_DCAN_TIOC_PU BSP_BIT32(18) |
#define | TMS570_DCAN_TIOC_PD BSP_BIT32(17) |
#define | TMS570_DCAN_TIOC_OD BSP_BIT32(16) |
#define | TMS570_DCAN_TIOC_Func BSP_BIT32(3) |
#define | TMS570_DCAN_TIOC_Dir BSP_BIT32(2) |
#define | TMS570_DCAN_TIOC_Out BSP_BIT32(1) |
#define | TMS570_DCAN_RIOC_PU BSP_BIT32(18) |
#define | TMS570_DCAN_RIOC_PD BSP_BIT32(17) |
#define | TMS570_DCAN_RIOC_OD BSP_BIT32(16) |
#define | TMS570_DCAN_RIOC_Func BSP_BIT32(3) |
#define | TMS570_DCAN_RIOC_Dir BSP_BIT32(2) |
#define | TMS570_DCAN_RIOC_Out BSP_BIT32(1) |
#define | TMS570_DCAN_RIOC_In BSP_BIT32(0) |
