#define | TMS570_PLL_PLLCTL3_ODPLL2(val) BSP_FLD32(val,29, 31) |
#define | TMS570_PLL_PLLCTL3_ODPLL2_GET(reg) BSP_FLD32GET(reg,29, 31) |
#define | TMS570_PLL_PLLCTL3_ODPLL2_SET(reg, val) BSP_FLD32SET(reg, val,29, 31) |
#define | TMS570_PLL_PLLCTL3_PLLDIV2(val) BSP_FLD32(val,24, 28) |
#define | TMS570_PLL_PLLCTL3_PLLDIV2_GET(reg) BSP_FLD32GET(reg,24, 28) |
#define | TMS570_PLL_PLLCTL3_PLLDIV2_SET(reg, val) BSP_FLD32SET(reg, val,24, 28) |
#define | TMS570_PLL_PLLCTL3_REFCLKDIV2(val) BSP_FLD32(val,16, 21) |
#define | TMS570_PLL_PLLCTL3_REFCLKDIV2_GET(reg) BSP_FLD32GET(reg,16, 21) |
#define | TMS570_PLL_PLLCTL3_REFCLKDIV2_SET(reg, val) BSP_FLD32SET(reg, val,16, 21) |
#define | TMS570_PLL_PLLCTL3_PLLMUL2(val) BSP_FLD32(val,0, 15) |
#define | TMS570_PLL_PLLCTL3_PLLMUL2_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_PLL_PLLCTL3_PLLMUL2_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT(val) BSP_FLD32(val,8, 13) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_GET(reg) BSP_FLD32GET(reg,8, 13) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_COUNT_SET(reg, val) BSP_FLD32SET(reg, val,8, 13) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY(val) BSP_FLD32(val,0, 3) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_PLL_CLKSLIP_PLL1_SLIP_FILTER_KEY_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX(val) BSP_FLD32(val,8, 15) |
#define | TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_PLL_SSWPLL1_CAPTURE_WINDOW_INDEX_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_PLL_SSWPLL1_COUNTER_READ_READY BSP_BIT32(6) |
#define | TMS570_PLL_SSWPLL1_COUNTER_RESET BSP_BIT32(5) |
#define | TMS570_PLL_SSWPLL1_COUNTER_EN BSP_BIT32(4) |
#define | TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS(val) BSP_FLD32(val,1, 3) |
#define | TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_GET(reg) BSP_FLD32GET(reg,1, 3) |
#define | TMS570_PLL_SSWPLL1_TAP_COUNTER_DIS_SET(reg, val) BSP_FLD32SET(reg, val,1, 3) |
#define | TMS570_PLL_SSWPLL1_EXT_COUNTER_EN BSP_BIT32(0) |
#define | TMS570_PLL_CSDIS_CLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7) |
#define | TMS570_PLL_CSDIS_CLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7) |
#define | TMS570_PLL_CSDIS_CLKSR_7_3_OFF_SET(reg, val) BSP_FLD32SET(reg, val,3, 7) |
#define | TMS570_PLL_CSDIS_CLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1) |
#define | TMS570_PLL_CSDIS_CLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_PLL_CSDIS_CLKSR_1_0_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_7_3_OFF_SET(reg, val) BSP_FLD32SET(reg, val,3, 7) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_PLL_CSDISSET_SETCLKSR_1_0_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF(val) BSP_FLD32(val,3, 7) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_GET(reg) BSP_FLD32GET(reg,3, 7) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_7_3_OFF_SET(reg, val) BSP_FLD32SET(reg, val,3, 7) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF(val) BSP_FLD32(val,0, 1) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_PLL_CSDISCLR_CLRCLKSR_1_0_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_PLL_CSVSTAT_CLKSR_7_3V(val) BSP_FLD32(val,3, 7) |
#define | TMS570_PLL_CSVSTAT_CLKSR_7_3V_GET(reg) BSP_FLD32GET(reg,3, 7) |
#define | TMS570_PLL_CSVSTAT_CLKSR_7_3V_SET(reg, val) BSP_FLD32SET(reg, val,3, 7) |
#define | TMS570_PLL_CSVSTAT_CLKSR_1_0V(val) BSP_FLD32(val,0, 1) |
#define | TMS570_PLL_CSVSTAT_CLKSR_1_0V_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_PLL_CSVSTAT_CLKSR_1_0V_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_PLL_PLLCTL1_ROS BSP_BIT32(31) |
#define | TMS570_PLL_PLLCTL1_MASK_SLIP(val) BSP_FLD32(val,29, 30) |
#define | TMS570_PLL_PLLCTL1_MASK_SLIP_GET(reg) BSP_FLD32GET(reg,29, 30) |
#define | TMS570_PLL_PLLCTL1_MASK_SLIP_SET(reg, val) BSP_FLD32SET(reg, val,29, 30) |
#define | TMS570_PLL_PLLCTL1_PLLDIV(val) BSP_FLD32(val,24, 28) |
#define | TMS570_PLL_PLLCTL1_PLLDIV_GET(reg) BSP_FLD32GET(reg,24, 28) |
#define | TMS570_PLL_PLLCTL1_PLLDIV_SET(reg, val) BSP_FLD32SET(reg, val,24, 28) |
#define | TMS570_PLL_PLLCTL1_ROF BSP_BIT32(23) |
#define | TMS570_PLL_PLLCTL1_REFCLKDIV(val) BSP_FLD32(val,16, 21) |
#define | TMS570_PLL_PLLCTL1_REFCLKDIV_GET(reg) BSP_FLD32GET(reg,16, 21) |
#define | TMS570_PLL_PLLCTL1_REFCLKDIV_SET(reg, val) BSP_FLD32SET(reg, val,16, 21) |
#define | TMS570_PLL_PLLCTL1_PLLMUL(val) BSP_FLD32(val,0, 15) |
#define | TMS570_PLL_PLLCTL1_PLLMUL_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_PLL_PLLCTL1_PLLMUL_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_PLL_PLLCTL2_FMENA BSP_BIT32(31) |
#define | TMS570_PLL_PLLCTL2_SPREADINGRATE(val) BSP_FLD32(val,22, 30) |
#define | TMS570_PLL_PLLCTL2_SPREADINGRATE_GET(reg) BSP_FLD32GET(reg,22, 30) |
#define | TMS570_PLL_PLLCTL2_SPREADINGRATE_SET(reg, val) BSP_FLD32SET(reg, val,22, 30) |
#define | TMS570_PLL_PLLCTL2_MULMOD(val) BSP_FLD32(val,12, 20) |
#define | TMS570_PLL_PLLCTL2_MULMOD_GET(reg) BSP_FLD32GET(reg,12, 20) |
#define | TMS570_PLL_PLLCTL2_MULMOD_SET(reg, val) BSP_FLD32SET(reg, val,12, 20) |
#define | TMS570_PLL_PLLCTL2_ODPLL(val) BSP_FLD32(val,9, 11) |
#define | TMS570_PLL_PLLCTL2_ODPLL_GET(reg) BSP_FLD32GET(reg,9, 11) |
#define | TMS570_PLL_PLLCTL2_ODPLL_SET(reg, val) BSP_FLD32SET(reg, val,9, 11) |
#define | TMS570_PLL_PLLCTL2_SPR_AMOUNT(val) BSP_FLD32(val,0, 8) |
#define | TMS570_PLL_PLLCTL2_SPR_AMOUNT_GET(reg) BSP_FLD32GET(reg,0, 8) |
#define | TMS570_PLL_PLLCTL2_SPR_AMOUNT_SET(reg, val) BSP_FLD32SET(reg, val,0, 8) |
#define | TMS570_PLL_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24) |
#define | TMS570_PLL_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16) |
#define | TMS570_PLL_LPOMONCTL_HFTRIM(val) BSP_FLD32(val,8, 12) |
#define | TMS570_PLL_LPOMONCTL_HFTRIM_GET(reg) BSP_FLD32GET(reg,8, 12) |
#define | TMS570_PLL_LPOMONCTL_HFTRIM_SET(reg, val) BSP_FLD32SET(reg, val,8, 12) |
#define | TMS570_PLL_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26) |
#define | TMS570_PLL_CLKTEST_RANGEDETCTRL BSP_BIT32(25) |
#define | TMS570_PLL_CLKTEST_RANGEDETENASSEL BSP_BIT32(24) |
#define | TMS570_PLL_CLKTEST_CLK_TEST_EN(val) BSP_FLD32(val,16, 19) |
#define | TMS570_PLL_CLKTEST_CLK_TEST_EN_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_PLL_CLKTEST_CLK_TEST_EN_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_PLL_GPREG1_EMIF_FUNC BSP_BIT32(31) |
#define | TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) BSP_FLD32(val,20, 25) |
#define | TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) BSP_FLD32GET(reg,20, 25) |
#define | TMS570_PLL_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg, val) BSP_FLD32SET(reg, val,20, 25) |
#define | TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) BSP_FLD32(val,16, 19) |
#define | TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_PLL_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) BSP_FLD32(val,0, 15) |
#define | TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_PLL_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_PLL_GLBSTAT_FBSLIP BSP_BIT32(9) |
#define | TMS570_PLL_GLBSTAT_RFSLIP BSP_BIT32(8) |
#define | TMS570_PLL_GLBSTAT_OSCFAIL BSP_BIT32(0) |
