#define | TMS570_TCRAM_RAMCTRL_EMU_TRACE_DIS BSP_BIT32(30) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE(val) BSP_FLD32(val,24, 27) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_OVERRIDE_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE(val) BSP_FLD32(val,16, 19) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_TCRAM_RAMCTRL_ADDR_PARITY_DISABLE_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_TCRAM_RAMCTRL_ECC_WR_EN BSP_BIT32(8) |
#define | TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN(val) BSP_FLD32(val,0, 3) |
#define | TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_TCRAM_RAMCTRL_ECC_DETECT_EN_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD(val) BSP_FLD32(val,0, 15) |
#define | TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_TCRAM_RAMTHRESHOLD_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR(val) BSP_FLD32(val,0, 15) |
#define | TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_TCRAM_RAMOCCUR_SINGLE_ERROR_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_TCRAM_RAMINTCTRL_SERR_EN BSP_BIT32(0) |
#define | TMS570_TCRAM_RAMERRSTATUS_WADDR_PAR_FAIL BSP_BIT32(9) |
#define | TMS570_TCRAM_RAMERRSTATUS_RADDR_PAR_FAIL BSP_BIT32(8) |
#define | TMS570_TCRAM_RAMERRSTATUS_DERR BSP_BIT32(5) |
#define | TMS570_TCRAM_RAMERRSTATUS_ADDR_COMP_LOGIC_FAIL BSP_BIT32(4) |
#define | TMS570_TCRAM_RAMERRSTATUS_ADDR_DEC_FAIL BSP_BIT32(2) |
#define | TMS570_TCRAM_RAMERRSTATUS_SERR BSP_BIT32(0) |
#define | TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS(val) BSP_FLD32(val,3, 17) |
#define | TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS_GET(reg) BSP_FLD32GET(reg,3, 17) |
#define | TMS570_TCRAM_RAMSERRADDR_SINGLE_ERROR_ADDRESS_SET(reg, val) BSP_FLD32SET(reg, val,3, 17) |
#define | TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE(val) BSP_FLD32(val,3, 22) |
#define | TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE_GET(reg) BSP_FLD32GET(reg,3, 22) |
#define | TMS570_TCRAM_RAMUERRADDR_UNCORRECTABLE_SET(reg, val) BSP_FLD32SET(reg, val,3, 22) |
#define | TMS570_TCRAM_RAMTEST_TRIGGER BSP_BIT32(8) |
#define | TMS570_TCRAM_RAMTEST_TEST_MODE(val) BSP_FLD32(val,6, 7) |
#define | TMS570_TCRAM_RAMTEST_TEST_MODE_GET(reg) BSP_FLD32GET(reg,6, 7) |
#define | TMS570_TCRAM_RAMTEST_TEST_MODE_SET(reg, val) BSP_FLD32SET(reg, val,6, 7) |
#define | TMS570_TCRAM_RAMTEST_TEST_ENABLE(val) BSP_FLD32(val,0, 3) |
#define | TMS570_TCRAM_RAMTEST_TEST_ENABLE_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_TCRAM_RAMTEST_TEST_ENABLE_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_TCRAM_RAMADDRDECVECT_ECC_SELECT BSP_BIT32(26) |
#define | TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT(val) BSP_FLD32(val,0, 15) |
#define | TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_TCRAM_RAMADDRDECVECT_RAM_CHIP_SELECT_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY(val) BSP_FLD32(val,3, 22) |
#define | TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY_GET(reg) BSP_FLD32GET(reg,3, 22) |
#define | TMS570_TCRAM_RAMPERADDR_ADDRESS_PARITY_SET(reg, val) BSP_FLD32SET(reg, val,3, 22) |
This header file provides TCRAM interfaces.
