#define | TMS570_FLASH_FRDCNTL_RWAIT(val) BSP_FLD32(val,8, 11) |
#define | TMS570_FLASH_FRDCNTL_RWAIT_GET(reg) BSP_FLD32GET(reg,8, 11) |
#define | TMS570_FLASH_FRDCNTL_RWAIT_SET(reg, val) BSP_FLD32SET(reg, val,8, 11) |
#define | TMS570_FLASH_FRDCNTL_ASWSTEN BSP_BIT32(4) |
#define | TMS570_FLASH_FRDCNTL_ENPIPE BSP_BIT32(0) |
#define | TMS570_FLASH_FEDACTRL1_SUSP_IGNR BSP_BIT32(24) |
#define | TMS570_FLASH_FEDACTRL1_EDACMODE(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_FEDACTRL1_EOFEN BSP_BIT32(10) |
#define | TMS570_FLASH_FEDACTRL1_EZFEN BSP_BIT32(9) |
#define | TMS570_FLASH_FEDACTRL1_EPEN BSP_BIT32(8) |
#define | TMS570_FLASH_FEDACTRL1_EDACEN(val) BSP_FLD32(val,0, 3) |
#define | TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_FCORERRCNT_FERRCNT(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31) |
#define | TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31) |
#define | TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg, val) BSP_FLD32SET(reg, val,3, 31) |
#define | TMS570_FLASH_FCORERRADD_B_OFF(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_FCORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_FCORERRADD_B_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_FCORERRPOS_BUS2 BSP_BIT32(9) |
#define | TMS570_FLASH_FCORERRPOS_TYPE BSP_BIT32(8) |
#define | TMS570_FLASH_FCORERRPOS_ERR_POS(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FEDACSTATUS_Reserved(val) BSP_FLD32(val,26, 31) |
#define | TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg) BSP_FLD32GET(reg,26, 31) |
#define | TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg, val) BSP_FLD32SET(reg, val,26, 31) |
#define | TMS570_FLASH_FEDACSTATUS_FSM_DONE BSP_BIT32(24) |
#define | TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G BSP_BIT32(19) |
#define | TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_ BSP_BIT32(18) |
#define | TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR BSP_BIT32(17) |
#define | TMS570_FLASH_FEDACSTATUS_B2_COR_ERR BSP_BIT32(16) |
#define | TMS570_FLASH_FEDACSTATUS_D_UNC_ERR BSP_BIT32(12) |
#define | TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR BSP_BIT32(11) |
#define | TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR BSP_BIT32(10) |
#define | TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR BSP_BIT32(8) |
#define | TMS570_FLASH_FEDACSTATUS_D_CORR_ERR BSP_BIT32(3) |
#define | TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG BSP_BIT32(2) |
#define | TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG BSP_BIT32(1) |
#define | TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG BSP_BIT32(0) |
#define | TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31) |
#define | TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31) |
#define | TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg, val) BSP_FLD32SET(reg, val,3, 31) |
#define | TMS570_FLASH_FUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val) BSP_FLD32(val,29, 31) |
#define | TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31) |
#define | TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg, val) BSP_FLD32SET(reg, val,29, 31) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val) BSP_FLD32(val,24, 27) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_FLASH_FEDACSDIS_BankID1(val) BSP_FLD32(val,21, 23) |
#define | TMS570_FLASH_FEDACSDIS_BankID1_GET(reg) BSP_FLD32GET(reg,21, 23) |
#define | TMS570_FLASH_FEDACSDIS_BankID1_SET(reg, val) BSP_FLD32SET(reg, val,21, 23) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val) BSP_FLD32(val,13, 15) |
#define | TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15) |
#define | TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg, val) BSP_FLD32SET(reg, val,13, 15) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val) BSP_FLD32(val,8, 11) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg) BSP_FLD32GET(reg,8, 11) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg, val) BSP_FLD32SET(reg, val,8, 11) |
#define | TMS570_FLASH_FEDACSDIS_BankID0(val) BSP_FLD32(val,5, 7) |
#define | TMS570_FLASH_FEDACSDIS_BankID0_GET(reg) BSP_FLD32GET(reg,5, 7) |
#define | TMS570_FLASH_FEDACSDIS_BankID0_SET(reg, val) BSP_FLD32SET(reg, val,5, 7) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0(val) BSP_FLD32(val,0, 3) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val) BSP_FLD32(val,4, 31) |
#define | TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31) |
#define | TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg, val) BSP_FLD32SET(reg, val,4, 31) |
#define | TMS570_FLASH_FPRIMADDTAG_0(val) BSP_FLD32(val,0, 3) |
#define | TMS570_FLASH_FPRIMADDTAG_0_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_FLASH_FPRIMADDTAG_0_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val) BSP_FLD32(val,4, 31) |
#define | TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg) BSP_FLD32GET(reg,4, 31) |
#define | TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg, val) BSP_FLD32SET(reg, val,4, 31) |
#define | TMS570_FLASH_FBPROT_PROTL1DIS BSP_BIT32(0) |
#define | TMS570_FLASH_FBSE_BSE(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_FBSE_BSE_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_FBSE_BSE_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_FBBUSY_BUSY(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FBBUSY_BUSY_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FBBUSY_BUSY_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FBAC_OTPPROTDIS(val) BSP_FLD32(val,16, 23) |
#define | TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_FLASH_FBAC_15_8(val) BSP_FLD32(val,8, 15) |
#define | TMS570_FLASH_FBAC_15_8_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_FLASH_FBAC_15_8_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_FLASH_FBAC_VREADST(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FBAC_VREADST_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FBAC_VREADST_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR7(val) BSP_FLD32(val,14, 15) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg) BSP_FLD32GET(reg,14, 15) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg, val) BSP_FLD32SET(reg, val,14, 15) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR1(val) BSP_FLD32(val,2, 3) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg) BSP_FLD32GET(reg,2, 3) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg, val) BSP_FLD32SET(reg, val,2, 3) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR0(val) BSP_FLD32(val,0, 1) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg) BSP_FLD32GET(reg,0, 1) |
#define | TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg, val) BSP_FLD32SET(reg, val,0, 1) |
#define | TMS570_FLASH_FBPRDY_BANKBUSY(val) BSP_FLD32(val,16, 23) |
#define | TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_FLASH_FBPRDY_PUMPRDY BSP_BIT32(15) |
#define | TMS570_FLASH_FBPRDY_BANKRDY(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FBPRDY_BANKRDY_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FBPRDY_BANKRDY_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FPAC1_PSLEEP(val) BSP_FLD32(val,16, 26) |
#define | TMS570_FLASH_FPAC1_PSLEEP_GET(reg) BSP_FLD32GET(reg,16, 26) |
#define | TMS570_FLASH_FPAC1_PSLEEP_SET(reg, val) BSP_FLD32SET(reg, val,16, 26) |
#define | TMS570_FLASH_FPAC1_PUMPPWR BSP_BIT32(0) |
#define | TMS570_FLASH_FPAC2_PAGP(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_FPAC2_PAGP_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_FPAC2_PAGP_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_FMAC_BANK(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_FMAC_BANK_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_FMAC_BANK_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_FMSTAT_ILA BSP_BIT32(14) |
#define | TMS570_FLASH_FMSTAT_PGV BSP_BIT32(12) |
#define | TMS570_FLASH_FMSTAT_EV BSP_BIT32(10) |
#define | TMS570_FLASH_FMSTAT_BUSY BSP_BIT32(8) |
#define | TMS570_FLASH_FMSTAT_ERS BSP_BIT32(7) |
#define | TMS570_FLASH_FMSTAT_PGM BSP_BIT32(6) |
#define | TMS570_FLASH_FMSTAT_INVDAT BSP_BIT32(5) |
#define | TMS570_FLASH_FMSTAT_CSTAT BSP_BIT32(4) |
#define | TMS570_FLASH_FMSTAT_VOLTSTAT BSP_BIT32(3) |
#define | TMS570_FLASH_FMSTAT_ESUSP BSP_BIT32(2) |
#define | TMS570_FLASH_FMSTAT_PSUSP BSP_BIT32(1) |
#define | TMS570_FLASH_FMSTAT_SLOCK BSP_BIT32(0) |
#define | TMS570_FLASH_FEMUECC_EMU_ECC(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FEMUADDR_EMU_ADDR(val) BSP_FLD32(val,3, 21) |
#define | TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg) BSP_FLD32GET(reg,3, 21) |
#define | TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg, val) BSP_FLD32SET(reg, val,3, 21) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_TRIG BSP_BIT32(24) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val) BSP_FLD32(val,12, 14) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg) BSP_FLD32GET(reg,12, 14) |
#define | TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg, val) BSP_FLD32SET(reg, val,12, 14) |
#define | TMS570_FLASH_FRAWECC_PIPE_BUF BSP_BIT32(8) |
#define | TMS570_FLASH_FRAWECC_RAW_ECC(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FPAROVR_BNK_INV_PAR BSP_BIT32(16) |
#define | TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val) BSP_FLD32(val,12, 15) |
#define | TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg) BSP_FLD32GET(reg,12, 15) |
#define | TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg, val) BSP_FLD32SET(reg, val,12, 15) |
#define | TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val) BSP_FLD32(val,9, 11) |
#define | TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg) BSP_FLD32GET(reg,9, 11) |
#define | TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg, val) BSP_FLD32SET(reg, val,9, 11) |
#define | TMS570_FLASH_FPAROVR_ADD_INV_PAR BSP_BIT32(8) |
#define | TMS570_FLASH_FPAROVR_DAT_INV_PAR(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val) BSP_FLD32(val,29, 31) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg) BSP_FLD32GET(reg,29, 31) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg, val) BSP_FLD32SET(reg, val,29, 31) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val) BSP_FLD32(val,24, 27) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3(val) BSP_FLD32(val,21, 23) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg) BSP_FLD32GET(reg,21, 23) |
#define | TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg, val) BSP_FLD32SET(reg, val,21, 23) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val) BSP_FLD32(val,13, 15) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg) BSP_FLD32GET(reg,13, 15) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg, val) BSP_FLD32SET(reg, val,13, 15) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val) BSP_FLD32(val,8, 11) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg) BSP_FLD32GET(reg,8, 11) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg, val) BSP_FLD32SET(reg, val,8, 11) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2(val) BSP_FLD32(val,5, 7) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg) BSP_FLD32GET(reg,5, 7) |
#define | TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg, val) BSP_FLD32SET(reg, val,5, 7) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2(val) BSP_FLD32(val,0, 3) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_FLASH_FSMWRENA_WR_ENA(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_FSMSECTOR_SECT_ERASED(val) BSP_FLD32(val,16, 31) |
#define | TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg) BSP_FLD32GET(reg,16, 31) |
#define | TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg, val) BSP_FLD32SET(reg, val,16, 31) |
#define | TMS570_FLASH_EEPROMCONFIG_EWAIT(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN BSP_BIT32(8) |
#define | TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_EECTRL1_EDACMODE(val) BSP_FLD32(val,16, 19) |
#define | TMS570_FLASH_EECTRL1_EDACMODE_GET(reg) BSP_FLD32GET(reg,16, 19) |
#define | TMS570_FLASH_EECTRL1_EDACMODE_SET(reg, val) BSP_FLD32SET(reg, val,16, 19) |
#define | TMS570_FLASH_EECTRL1_EE_EOFEN BSP_BIT32(10) |
#define | TMS570_FLASH_EECTRL1_EE_EZFEN BSP_BIT32(9) |
#define | TMS570_FLASH_EECTRL1_EE_EPEN BSP_BIT32(8) |
#define | TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val) BSP_FLD32(val,0, 15) |
#define | TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val) BSP_FLD32(val,3, 31) |
#define | TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31) |
#define | TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg, val) BSP_FLD32SET(reg, val,3, 31) |
#define | TMS570_FLASH_EECORERRADD_B_OFF(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_EECORERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_EECORERRADD_B_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_EECORERRPOS_TYPE BSP_BIT32(8) |
#define | TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val) BSP_FLD32(val,0, 7) |
#define | TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_FLASH_EESTATUS_EE_D_UNC_ERR BSP_BIT32(12) |
#define | TMS570_FLASH_EESTATUS_EE_UNC_ERR BSP_BIT32(8) |
#define | TMS570_FLASH_EESTATUS_EE_CMG BSP_BIT32(6) |
#define | TMS570_FLASH_EESTATUS_EE_CME BSP_BIT32(4) |
#define | TMS570_FLASH_EESTATUS_EE_D_COR_ERR BSP_BIT32(3) |
#define | TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG BSP_BIT32(2) |
#define | TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG BSP_BIT32(1) |
#define | TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG BSP_BIT32(0) |
#define | TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val) BSP_FLD32(val,3, 31) |
#define | TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg) BSP_FLD32GET(reg,3, 31) |
#define | TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg, val) BSP_FLD32SET(reg, val,3, 31) |
#define | TMS570_FLASH_EEUNCERRADD_B_OFF(val) BSP_FLD32(val,0, 2) |
#define | TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg) BSP_FLD32GET(reg,0, 2) |
#define | TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 2) |
#define | TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val) BSP_FLD32(val,20, 31) |
#define | TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,20, 31) |
#define | TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg, val) BSP_FLD32SET(reg, val,20, 31) |
#define | TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val) BSP_FLD32(val,4, 15) |
#define | TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg) BSP_FLD32GET(reg,4, 15) |
#define | TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg, val) BSP_FLD32SET(reg, val,4, 15) |
