#define | TMS570_HTU_GC_VBUSHOLD BSP_BIT32(24) |
#define | TMS570_HTU_GC_HTUEN BSP_BIT32(16) |
#define | TMS570_HTU_GC_DEBM BSP_BIT32(8) |
#define | TMS570_HTU_GC_HTURES BSP_BIT32(0) |
#define | TMS570_HTU_CPENA_CPENA(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_CPENA_CPENA_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_CPENA_CPENA_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_BUSY0_BUSY0A BSP_BIT32(24) |
#define | TMS570_HTU_BUSY0_BUSY0B BSP_BIT32(16) |
#define | TMS570_HTU_BUSY0_BUSY1A BSP_BIT32(8) |
#define | TMS570_HTU_BUSY0_BUSY1B BSP_BIT32(0) |
#define | TMS570_HTU_BUSY1_BUSY2A BSP_BIT32(24) |
#define | TMS570_HTU_BUSY1_BUSY2B BSP_BIT32(16) |
#define | TMS570_HTU_BUSY1_BUSY3A BSP_BIT32(8) |
#define | TMS570_HTU_BUSY1_BUSY3B BSP_BIT32(0) |
#define | TMS570_HTU_BUSY2_BUSY4A BSP_BIT32(24) |
#define | TMS570_HTU_BUSY2_BUSY4B BSP_BIT32(16) |
#define | TMS570_HTU_BUSY2_BUSY5A BSP_BIT32(8) |
#define | TMS570_HTU_BUSY2_BUSY5B BSP_BIT32(0) |
#define | TMS570_HTU_BUSY3_BUSY6A BSP_BIT32(24) |
#define | TMS570_HTU_BUSY3_BUSY6B BSP_BIT32(16) |
#define | TMS570_HTU_BUSY3_BUSY7A BSP_BIT32(8) |
#define | TMS570_HTU_BUSY3_BUSY7B BSP_BIT32(0) |
#define | TMS570_HTU_ACPE_ERRF BSP_BIT32(31) |
#define | TMS570_HTU_RLBECTRL_BERINTENA BSP_BIT32(16) |
#define | TMS570_HTU_RLBECTRL_CORL BSP_BIT32(8) |
#define | TMS570_HTU_RLBECTRL_RLINTENA BSP_BIT32(0) |
#define | TMS570_HTU_BFINTS_BFINTENA(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_BFINTS_BFINTENA_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_BFINTS_BFINTENA_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_BFINTC_BFINTDIS(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_BFINTC_BFINTDIS_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_BFINTC_BFINTDIS_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_INTOFF0_INTTYPE0(val) BSP_FLD32(val,8, 10) |
#define | TMS570_HTU_INTOFF0_INTTYPE0_GET(reg) BSP_FLD32GET(reg,8, 10) |
#define | TMS570_HTU_INTOFF0_INTTYPE0_SET(reg, val) BSP_FLD32SET(reg, val,8, 10) |
#define | TMS570_HTU_INTOFF0_CPOFF0(val) BSP_FLD32(val,0, 4) |
#define | TMS570_HTU_INTOFF0_CPOFF0_GET(reg) BSP_FLD32GET(reg,0, 4) |
#define | TMS570_HTU_INTOFF0_CPOFF0_SET(reg, val) BSP_FLD32SET(reg, val,0, 4) |
#define | TMS570_HTU_INTOFF1_INTTYPE1(val) BSP_FLD32(val,8, 10) |
#define | TMS570_HTU_INTOFF1_INTTYPE1_GET(reg) BSP_FLD32GET(reg,8, 10) |
#define | TMS570_HTU_INTOFF1_INTTYPE1_SET(reg, val) BSP_FLD32SET(reg, val,8, 10) |
#define | TMS570_HTU_INTOFF1_CPOFF1(val) BSP_FLD32(val,0, 4) |
#define | TMS570_HTU_INTOFF1_CPOFF1_GET(reg) BSP_FLD32GET(reg,0, 4) |
#define | TMS570_HTU_INTOFF1_CPOFF1_SET(reg, val) BSP_FLD32SET(reg, val,0, 4) |
#define | TMS570_HTU_BIM_BIM(val) BSP_FLD32(val,0, 7) |
#define | TMS570_HTU_BIM_BIM_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_HTU_BIM_BIM_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_HTU_RLOSTFL_CPRLFL(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_RLOSTFL_CPRLFL_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_RLOSTFL_CPRLFL_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_BFINTFL_BFINTFL(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_BFINTFL_BFINTFL_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_BFINTFL_BFINTFL_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_BERINTFL_BERINTFL(val) BSP_FLD32(val,0, 15) |
#define | TMS570_HTU_BERINTFL_BERINTFL_GET(reg) BSP_FLD32GET(reg,0, 15) |
#define | TMS570_HTU_BERINTFL_BERINTFL_SET(reg, val) BSP_FLD32SET(reg, val,0, 15) |
#define | TMS570_HTU_DCTRL_CPNUM(val) BSP_FLD32(val,24, 27) |
#define | TMS570_HTU_DCTRL_CPNUM_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_HTU_DCTRL_CPNUM_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_HTU_DCTRL_HTUDBGS BSP_BIT32(16) |
#define | TMS570_HTU_DCTRL_DBREN BSP_BIT32(0) |
#define | TMS570_HTU_ID_CLASS(val) BSP_FLD32(val,16, 23) |
#define | TMS570_HTU_ID_CLASS_GET(reg) BSP_FLD32GET(reg,16, 23) |
#define | TMS570_HTU_ID_CLASS_SET(reg, val) BSP_FLD32SET(reg, val,16, 23) |
#define | TMS570_HTU_ID_TYPE(val) BSP_FLD32(val,8, 15) |
#define | TMS570_HTU_ID_TYPE_GET(reg) BSP_FLD32GET(reg,8, 15) |
#define | TMS570_HTU_ID_TYPE_SET(reg, val) BSP_FLD32SET(reg, val,8, 15) |
#define | TMS570_HTU_ID_REV(val) BSP_FLD32(val,0, 7) |
#define | TMS570_HTU_ID_REV_GET(reg) BSP_FLD32GET(reg,0, 7) |
#define | TMS570_HTU_ID_REV_SET(reg, val) BSP_FLD32SET(reg, val,0, 7) |
#define | TMS570_HTU_PCR_COPE BSP_BIT32(16) |
#define | TMS570_HTU_PCR_TEST BSP_BIT32(8) |
#define | TMS570_HTU_PCR_PARITY_ENA(val) BSP_FLD32(val,0, 3) |
#define | TMS570_HTU_PCR_PARITY_ENA_GET(reg) BSP_FLD32GET(reg,0, 3) |
#define | TMS570_HTU_PCR_PARITY_ENA_SET(reg, val) BSP_FLD32SET(reg, val,0, 3) |
#define | TMS570_HTU_PAR_PEFT BSP_BIT32(16) |
#define | TMS570_HTU_PAR_PAOFF(val) BSP_FLD32(val,0, 8) |
#define | TMS570_HTU_PAR_PAOFF_GET(reg) BSP_FLD32GET(reg,0, 8) |
#define | TMS570_HTU_PAR_PAOFF_SET(reg, val) BSP_FLD32SET(reg, val,0, 8) |
#define | TMS570_HTU_MPCS_CPNUM0(val) BSP_FLD32(val,24, 27) |
#define | TMS570_HTU_MPCS_CPNUM0_GET(reg) BSP_FLD32GET(reg,24, 27) |
#define | TMS570_HTU_MPCS_CPNUM0_SET(reg, val) BSP_FLD32SET(reg, val,24, 27) |
#define | TMS570_HTU_MPCS_MPEFT1 BSP_BIT32(17) |
#define | TMS570_HTU_MPCS_MPEFT0 BSP_BIT32(16) |
#define | TMS570_HTU_MPCS_CPNUM1(val) BSP_FLD32(val,8, 11) |
#define | TMS570_HTU_MPCS_CPNUM1_GET(reg) BSP_FLD32GET(reg,8, 11) |
#define | TMS570_HTU_MPCS_CPNUM1_SET(reg, val) BSP_FLD32SET(reg, val,8, 11) |
