RTEMS 6.1
Typedefs | Enumerations | Functions
hwinit-lc4357-hdk.c File Reference
This source file contains parts of the system initialization. More...
#include <bsp/tms570.h>
#include <bsp/tms570_hwinit.h>
#include <bsp/tms570-pinmux.h>
typedef enum Tms570ClockDisableSources Tms570ClockDisableSources
typedef enum Tms570GhvClockSources Tms570GhvClockSources
enum  Tms570ClockDisableSources {
  TMS570_CLKDIS_SRC_OSC = 0x01 , TMS570_CLKDIS_SRC_PLL1 = 0x02 , TMS570_CLKDIS_SRC_RESERVED = 0x04 , TMS570_CLKDIS_SRC_EXT_CLK1 = 0x08 ,
  TMS570_CLKDIS_SRC_LOW_FREQ_LPO = 0x10 , TMS570_CLKDIS_SRC_HIGH_FREQ_LPO = 0x20 , TMS570_CLKDIS_SRC_PLL2 = 0x40 , TMS570_CLKDIS_SRC_EXT_CLK2 = 0x80
enum  Tms570GhvClockSources {
  TMS570_SYS_CLK_SRC_OSC = 0U , TMS570_SYS_CLK_SRC_PLL1 = 1U , TMS570_SYS_CLK_SRC_EXTERNAL1 = 3U , TMS570_SYS_CLK_SRC_LPO_LOW = 4U ,
  TMS570_SYS_CLK_SRC_LPO_HIGH = 5U , TMS570_SYS_CLK_SRC_PLL2 = 6U , TMS570_SYS_CLK_SRC_EXTERNAL2 = 7U , TMS570_SYS_CLK_SRC_VCLK = 9U
void tms570_pinmux_init (void)
 Initialize the tms570 PINMUX peripheral. This maps signals to pin terminals.
void tms570_emif_sdram_init (void)
 Initialize the External Memory InterFace (EMIF) peripheral.
void tms570_pll_init (void)
 Setup all system PLLs (HCG:setupPLL)
void tms570_map_clock_init (void)
 Initialize the tms570 Global Clock Manager (GCM) registers which sub-divide the input clock source (generally PLL) into the various peripheral clocks (VCLK1-3, etc).
◆ Tms570ClockDisableSources
External high-speed oscillator as clock source.
reserved. not tied to actual clock source
◆ Tms570GhvClockSources
Alias for oscillator clock Source
Alias for Pll1 clock Source
Alias for external clock Source
Alias for low power oscillator low clock Source
Alias for low power oscillator high clock Source
Alias for Pll2 clock Source
Alias for external 2 clock Source
Alias for synchronous VCLK1 clock Source
◆ tms570_map_clock_init()
void tms570_map_clock_init ( void  )
Initialize Clock Tree:
  • Disable / Enable clock domain
  • Setup RTICLK1 and RTICLK2 clocks
  • Setup asynchronous peripheral clock sources for AVCLK1 and AVCLK2
  • Setup synchronous peripheral clock dividers for VCLK1, VCLK2, VCLK3
◆ tms570_pll_init()
void tms570_pll_init ( void  )
Initialize PLLs source divider/multipliers.
  • Setup pll control register 1:
    • Disable reset on oscillator slip (ROS)
    • Enable bypass on pll slip TODO: desired: switches to OSC when PLL slip detected
    • setup Pll output clock divider to max before Lock
    • Disable reset on oscillator fail
    • Setup reference clock divider
    • Setup Pll multiplier
    • PLL1: 16MHz OSC in -> 300MHz PLL1 out
  • Setup pll control register 2
    • Setup spreading rate
    • Setup bandwidth adjustment
    • Setup internal Pll output divider
    • Setup spreading amount
  • Setup pll2 control register :
