RTEMS 6.1
Files | Typedefs | Functions | Variables
Kernel Character I/O Support
The kernel character input/output support is an extension of the I/O Manager to output characters to the kernel character output device and receive characters from the kernel character input device using a polled and non-blocking implementation. More...
file  bspIo.h
 This header file provides the kernel character input/output support API.
file  getchark.c
 This source file contains the implementation of getchark().
file  printk.c
 This source file contains the implementation of printk().
file  printk_plugin.c
 This source file contains the implementation of rtems_printk_printer() and rtems_print_printer_printk().
file  putk.c
 This source file contains the implementation of putk().
file  rtems_put_char.c
 This source file contains the implementation of rtems_put_char().
file  rtems_putc.c
 This source file contains the implementation of rtems_putc().
file  vprintk.c
 This source file contains the implementation of vprintk().
typedef void(* BSP_output_char_function_type) (char)
 Polled character output functions shall have this type.
typedef int(* BSP_polling_getchar_function_type) (void)
 Polled character input functions shall have this type.
void rtems_putc (char c)
 Outputs the character to the kernel character output device.
void rtems_put_char (int c, void *unused)
 Puts the character using rtems_putc()
int putk (const char *s)
 Outputs the characters of the string and a newline character to the kernel character output device.
 RTEMS_PRINTFLIKE (1, 2) int printk(const char *fmt
 Outputs the characters defined by the format string and the arguments to the kernel character output device.
int vprintk (const char *fmt, va_list ap)
 Outputs the characters defined by the format string and the variable argument list to the kernel character output device.
int rtems_printk_printer (void *unused, const char *fmt, va_list ap)
int getchark (void)
 Tries to dequeue a character from the kernel character input device.
BSP_output_char_function_type BSP_output_char
 This function pointer references the kernel character output implementation.
BSP_polling_getchar_function_type BSP_poll_char
 This function pointer may reference the kernel character input implementation.
The directives may be used to print debug and test information. The kernel character input/output support should work even if no Console Driver is configured, see CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER. The kernel character input and output device is provided by the BSP. Applications may change the device.
◆ getchark()
int getchark ( void  )
The directive tries to dequeue a character from the kernel character input device using the polled character input implementation referenced by BSP_poll_char if it is available.
Return values
-1The BSP_poll_char pointer was equal to NULL.
-1There was no character enqueued on the kernel character input device.
Returns
Returns the character least recently enqueued on the kernel character input device as an unsigned character value.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within any runtime context.
  • The directive will not cause the calling task to be preempted.
◆ putk()
int putk ( const char *  s)
Parameters
sis the string to output.
Returns
Returns the number of characters output to the kernel character output device.
Notes
The directive may be used to print debug and test information. It uses rtems_putc() to output the characters. This directive performs a character translation from NL to CR followed by NR.
If the kernel character output device is concurrently accessed, then interleaved output may occur.
Constraints
Kernel putk (e.g. puts) function requiring minimal infrastrure.
◆ RTEMS_PRINTFLIKE()
RTEMS_PRINTFLIKE ( ,
) const
Parameters
fmtis a printf()-style format string.
...is a list of optional parameters required by the format string.
Returns
Notes
Constraints
  • Formatting of floating point numbers is not supported.
◆ rtems_printk_printer()
int rtems_printk_printer ( void *  unused,
const char *  fmt,
va_list  ap
Parameters
unusedis an unused argument.
apis the variable argument list required by the format string.
Returns
Notes
Constraints
◆ rtems_put_char()
void rtems_put_char ( int  c,
void *  unused
Parameters
cis the character to output.
Notes
The directive is provided to support the RTEMS Testing Framework.
Constraints
◆ rtems_putc()
void rtems_putc ( char  c)
Parameters
The directive outputs the character specified by c to the kernel character output device using the polled character output implementation provided by BSP_output_char. The directive performs a character translation from NL to CR followed by NR.
Constraints
◆ vprintk()
int vprintk ( const char *  fmt,
va_list  ap
Parameters
Returns
Notes
Constraints
Variable Documentation
◆ BSP_output_char
extern
This function pointer shall never be NULL. It shall be provided by the BSP and statically initialized. The referenced function shall output exactly the character specified by the parameter. In particular, it shall not perform character translations, for example NL to CR followed by NR. The function shall not block.
◆ BSP_poll_char
extern
This function pointer may be NULL. It may reference a function provided by the BSP. Referenced functions shall dequeue the least recently received character from the device and return it as an unsigned character. If no character is enqueued on the device, then the function shall immediately return the value minus one.
