RTEMS 6.1
This group contains the Application Programming Interfaces (APIs) of RTEMS. More...
Modules | |
| Application Configuration Information | |
| The application configuration information group provides an API to get the configuration of an application. | |
| Application Configuration Options | |
| Associativity Routines | |
| BSD Compatibility Support | |
| Base Definitions | |
| This group contains basic macros and defines to give access to compiler-specific features. | |
| CPU Usage Reporting | |
| The CPU usage reporting directives can be used to report and reset the CPU usage of threads. | |
| Classic | |
| This group contains the Classic API managers. | |
| Dynamic Memory Allocation | |
| This group contains non-standard interfaces to use dynamic memory allocation. | |
| Free-Running Counter and Busy Wait Delay | |
| Free-running counter and busy wait delay functions. | |
| Hash Algorithms | |
| This group contains interfaces to hash algorithms. | |
| IO | |
| IO. | |
| Linker Sets | |
| This group contains the linker sets API. | |
| Profiling Support | |
| The profiling support offers functions to report profiling information available in the system. | |
| RTEMS Application Loader | |
| RTEMS Runtime Link Editor | |
| RTEMS Test Framework | |
| The RTEMS Test Framework helps you to write tests. | |
| Red-Black Tree Heap | |
| The red-black tree heap provides a memory allocator using a red-black tree to maintain blocks of memory. | |
| Self-Contained Objects | |
| This group contains the self-contained objects API. | |
| Set Error Number Support | |
| Status Checks | |
| System Initialization Support | |
| The system initialization support provides an ordered invocation of system initialization handlers registered in a linker set. | |
| System Library | |
| This group contains the system library APIs of RTEMS. | |
| Test Support | |
| Test support functions. | |
| Tracing | |
| Tracing. | |
This group contains the RTEMS Application Programming Interface (API).
