| enum | T_scheduler_operation {
T_SCHEDULER_NOP
, T_SCHEDULER_ADD_PROCESSOR
, T_SCHEDULER_ANY
, T_SCHEDULER_ASK_FOR_HELP
T_SCHEDULER_BLOCK
, T_SCHEDULER_CANCEL_JOB
, T_SCHEDULER_CLEAN_STICKY
, T_SCHEDULER_INITIALIZE
T_SCHEDULER_MAKE_STICKY
, T_SCHEDULER_MAP_PRIORITY
, T_SCHEDULER_NODE_DESTROY
, T_SCHEDULER_NODE_INITIALIZE
T_SCHEDULER_PIN
, T_SCHEDULER_RECONSIDER_HELP_REQUEST
, T_SCHEDULER_RELEASE_JOB
, T_SCHEDULER_REMOVE_PROCESSOR
T_SCHEDULER_SCHEDULE
, T_SCHEDULER_SET_AFFINITY
, T_SCHEDULER_START_IDLE
, T_SCHEDULER_UNBLOCK
T_SCHEDULER_UNMAP_PRIORITY
, T_SCHEDULER_UNPIN
, T_SCHEDULER_UPDATE_PRIORITY
, T_SCHEDULER_WITHDRAW_NODE
T_SCHEDULER_YIELD
| enum | T_scheduler_when { T_SCHEDULER_BEFORE
, T_SCHEDULER_AFTER
| enum | T_verbosity { T_QUIET
, T_NORMAL
, T_VERBOSE
T_scheduler_log * | T_scheduler_record (T_scheduler_log *) |
T_scheduler_log * | T_scheduler_record_2 (T_scheduler_log_2 *) |
T_scheduler_log * | T_scheduler_record_4 (T_scheduler_log_4 *) |
T_scheduler_log * | T_scheduler_record_10 (T_scheduler_log_10 *) |
T_scheduler_log * | T_scheduler_record_20 (T_scheduler_log_20 *) |
T_scheduler_log * | T_scheduler_record_40 (T_scheduler_log_40 *) |
void | T_scheduler_set_event_handler (T_scheduler_event_handler, void *) |
const T_scheduler_event * | T_scheduler_next (T_scheduler_header *, T_scheduler_operation, size_t *) |
const T_scheduler_event * | T_scheduler_next_any (T_scheduler_header *, size_t *) |
void | T_scheduler_initialize (const Scheduler_Control *) |
void | T_scheduler_schedule (const Scheduler_Control *, Thread_Control *) |
void | T_scheduler_yield (const Scheduler_Control *, Thread_Control *, Scheduler_Node *) |
void | T_scheduler_block (const Scheduler_Control *, Thread_Control *, Scheduler_Node *) |
void | T_scheduler_unblock (const Scheduler_Control *, Thread_Control *, Scheduler_Node *) |
void | T_scheduler_update_priority (const Scheduler_Control *, Thread_Control *, Scheduler_Node *) |
Priority_Control | T_scheduler_map_priority (const Scheduler_Control *, Priority_Control) |
Priority_Control | T_scheduler_unmap_priority (const Scheduler_Control *, Priority_Control) |
void | T_scheduler_node_initialize (const Scheduler_Control *, Scheduler_Node *, Thread_Control *, Priority_Control) |
void | T_scheduler_node_destroy (const Scheduler_Control *, Scheduler_Node *) |
void | T_scheduler_release_job (const Scheduler_Control *, Thread_Control *, Priority_Node *, uint64_t, Thread_queue_Context *) |
void | T_scheduler_cancel_job (const Scheduler_Control *, Thread_Control *, Priority_Node *, Thread_queue_Context *) |
void | T_scheduler_start_idle (const Scheduler_Control *, Thread_Control *, struct Per_CPU_Control *) |
The RTEMS Test Framework helps you to write tests.
