RTEMS 6.1
Unsigned 32-Bit Integer Checks
Checks for unsigned 32-bit integers (uint32_t). More...
#define T_eq_u32(a, e)   T_flags_eq_ulong(a, e, 0)
#define T_assert_eq_u32(a, e)   T_flags_eq_ulong(a, e, T_CHECK_STOP)
#define T_quiet_eq_u32(a, e)   T_flags_eq_ulong(a, e, T_CHECK_QUIET)
#define T_step_eq_u32(s, a, e)   T_flags_eq_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_eq_u32(s, a, e)    T_flags_eq_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ne_u32(a, e)   T_flags_ne_ulong(a, e, 0)
#define T_assert_ne_u32(a, e)   T_flags_ne_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ne_u32(a, e)   T_flags_ne_ulong(a, e, T_CHECK_QUIET)
#define T_step_ne_u32(s, a, e)   T_flags_ne_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ne_u32(s, a, e)    T_flags_ne_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_ge_u32(a, e)   T_flags_ge_ulong(a, e, 0)
#define T_assert_ge_u32(a, e)   T_flags_ge_ulong(a, e, T_CHECK_STOP)
#define T_quiet_ge_u32(a, e)   T_flags_ge_ulong(a, e, T_CHECK_QUIET)
#define T_step_ge_u32(s, a, e)   T_flags_ge_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_ge_u32(s, a, e)    T_flags_ge_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_gt_u32(a, e)   T_flags_gt_ulong(a, e, 0)
#define T_assert_gt_u32(a, e)   T_flags_gt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_gt_u32(a, e)   T_flags_gt_ulong(a, e, T_CHECK_QUIET)
#define T_step_gt_u32(s, a, e)   T_flags_gt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_gt_u32(s, a, e)    T_flags_gt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_le_u32(a, e)   T_flags_le_ulong(a, e, 0)
#define T_assert_le_u32(a, e)   T_flags_le_ulong(a, e, T_CHECK_STOP)
#define T_quiet_le_u32(a, e)   T_flags_le_ulong(a, e, T_CHECK_QUIET)
#define T_step_le_u32(s, a, e)   T_flags_le_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_le_u32(s, a, e)    T_flags_le_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
#define T_lt_u32(a, e)   T_flags_lt_ulong(a, e, 0)
#define T_assert_lt_u32(a, e)   T_flags_lt_ulong(a, e, T_CHECK_STOP)
#define T_quiet_lt_u32(a, e)   T_flags_lt_ulong(a, e, T_CHECK_QUIET)
#define T_step_lt_u32(s, a, e)   T_flags_lt_ulong(a, e, T_CHECK_STEP(s))
#define T_step_assert_lt_u32(s, a, e)    T_flags_lt_ulong(a, e, T_CHECK_STEP(s) | T_CHECK_STOP)
