RTEMS 6.1
Files | Macros
Set Error Number Support
file  seterr.h
 This header file defines macros to set errno and return minus one.
#define rtems_set_errno_and_return_value(_error, _value)    do { errno = ( _error ); return ( _value ); } while ( 0 )
#define rtems_set_errno_and_return_minus_one(_error)    rtems_set_errno_and_return_value( _error, -1 )
◆ rtems_set_errno_and_return_minus_one
#define rtems_set_errno_and_return_minus_one (   _error)     rtems_set_errno_and_return_value( _error, -1 )
This is a helper macro which will set the variable errno and return -1 to the caller. This pattern is common to many POSIX methods.
Parameters
[in]_erroris the error code
◆ rtems_set_errno_and_return_value
#define rtems_set_errno_and_return_value (   _error,
  _value
This is a helper macro which will set the variable errno and return the specified value to the caller.
Parameters
[in]_valueis the value to return
