RTEMS 6.1
This header file provides the kernel character input/output support API. More...
| void | rtems_putc (char c) |
| Outputs the character to the kernel character output device. | |
| void | rtems_put_char (int c, void *unused) |
| Puts the character using rtems_putc() | |
| int | putk (const char *s) |
| Outputs the characters of the string and a newline character to the kernel character output device. | |
| RTEMS_PRINTFLIKE (1, 2) int printk(const char *fmt | |
| Outputs the characters defined by the format string and the arguments to the kernel character output device. | |
| int | vprintk (const char *fmt, va_list ap) |
| Outputs the characters defined by the format string and the variable argument list to the kernel character output device. | |
| int | rtems_printk_printer (void *unused, const char *fmt, va_list ap) |
| int | getchark (void) |
| Tries to dequeue a character from the kernel character input device. | |
| BSP_output_char_function_type | BSP_output_char |
| This function pointer references the kernel character output implementation. | |
| BSP_polling_getchar_function_type | BSP_poll_char |
| This function pointer may reference the kernel character input implementation. | |
