RTEMS 6.1
This header file provides interfaces of the parity selftest support. More...
#include <stdint.h>Go to the source code of this file.
| struct | tms570_selftest_par_desc |
| #define | TMS570_SELFTEST_PAR_CR_KEY 0xA |
Typedefs | |
| typedef struct tms570_selftest_par_desc | tms570_selftest_par_desc_t |
| typedef void | tms570_selftest_par_fnc_t(const tms570_selftest_par_desc_t *desc) |
| void | tms570_selftest_par_check_std (const tms570_selftest_par_desc_t *desc) |
| run test to check that parity protection works for modules with common setup structure. | |
| void | tms570_selftest_par_check_can (const tms570_selftest_par_desc_t *desc) |
| run test to check that parity protection works for CAN modules RAM | |
| void | tms570_selftest_par_check_mibspi (const tms570_selftest_par_desc_t *desc) |
| run test to check that parity protection works for MibSPI modules RAM | |
| void | tms570_selftest_par_run (const tms570_selftest_par_desc_t *const *desc_arr, int desc_cnt) |
| run parity protection mechanism check for set of modules described by list. | |
| const tms570_selftest_par_desc_t | tms570_selftest_par_het1_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_htu1_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_het2_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_htu2_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_adc1_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_adc2_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_can1_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_can2_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_can3_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_vim_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_dma_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_spi1_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_spi3_desc |
| const tms570_selftest_par_desc_t | tms570_selftest_par_spi5_desc |
| const tms570_selftest_par_desc_t *const | tms570_selftest_par_list [] |
| const int | tms570_selftest_par_list_size |
| #define TMS570_SELFTEST_PAR_CR_KEY 0xA |
The magic number used to switch most of the peripherals into parity protection test mode
| void tms570_selftest_par_check_can | ( | const tms570_selftest_par_desc_t * | desc | ) |
| [in] | desc | module registers addresses end ESM channels descriptor |
The descriptor provides address of the module registers and address of internal RAM memory and corresponding parity area test access window.
| void tms570_selftest_par_check_mibspi | ( | const tms570_selftest_par_desc_t * | desc | ) |
| void tms570_selftest_par_check_std | ( | const tms570_selftest_par_desc_t * | desc | ) |
The descriptor provides address of the module registers and address of internal RAM memory and corresponding parity area test access window. This test function is usable for HETx, HTUx, ADC, DMA and VIM TMS570 peripherals.
| void tms570_selftest_par_run | ( | const tms570_selftest_par_desc_t *const * | desc_arr, |
| int | desc_cnt | ||
| [in] | desc_arr | array of pointers to descriptors providing addresses and ESM channels for individual peripherals. |
| [in] | desc_cnt | count of pointers in the array |
